Old 07-23-2004, 09:33 PM   #1
grantn
Member#: 25398
2005 STi
Default Cel P0102
found problem
ThanX
grantn is offline   Reply With Quote
Old 07-24-2004, 12:01 AM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
P0102 Mass air flow sensor circuit low input
Sounds like that perrin maf is borked. try unplugging the maf and see if the car runs, it will cut out at 4500 rpm though with the maf disconnected.
Jay
Old 07-24-2004, 03:27 AM   #3
grantn
Member#: 25398
2005 STi
It's the same with the maf unpluged.
Old 07-24-2004, 03:13 PM   #4
sonxwrx
Member#: 35781
2011 STI
Spark Silver Metallic
I researching the same CEL code - P0102.
I was having the same problems with starting the car. Actually I was driving on a local street when suddenly the car shut off.
I have an 03 WRX sedan with a PDE uppipe and RSR turboback (80mm piping). I have the stock intake setup and stock BOV.
Seems like there a leak some where ... I'm investigating now but cant tell. Managed to get the car started after resetting the ecu and just letting the car crank the ignition until it starts. Then I just drove it home.
Same problem occurred July 4th evening while trying to drive home. It was raining alot then and last night as well.
I hope my info helps.
sonxwrx is online now   Reply With Quote
Old 07-24-2004, 06:39 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Check for vacuum leaks. specifically your intercooler hoses, see if one blew off.
Jay
CEL code P0113 and P0102 together kingtut12 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 09-22-2016 08:41 AM
I have a CEL that reads p0102 SUBYS R US Rocky Mountains Impreza Club Forum -- RMIC 8 01-19-2009 06:04 PM
P0102 and P0113 CELs KB21 Newbies & FAQs 8 11-11-2008 11:02 AM
UTEC 5.0 and CEL code P0102 AURAz UTEC 16 08-18-2006 01:55 PM
CEL codes P0102 and P0103 both NITROS Service & Maintenance 6 11-15-2005 06:13 PM
