Old 07-23-2004, 09:43 PM   #1
eshtog
Member#: 61938
2006 BMW 330i
Default How do you change the fog liht bulbs on a 04 wrx?
do I have to take off the bumper?
eshtog is offline   Reply With Quote
Old 07-23-2004, 10:49 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
You just need to get access to the bottom of the lights. If you lay on the ground and look at the underside of the car , in the fog light area, you will see two plastic push pins along the very edge of the car. One toward the front of the car and the other further back. Pull those out. Then reach up and pull the rubber under body away from the lights. (no need to remove the whole thing..it's flexible). There are two 10 mm bolts holding the lamp from underneath. Remove those bolts. Take off the plastic front cover around the fog lights by just pulling on it on one edge. Then there is one 10 mm bolt in front and one push pin that needs to be removed. The lamp then just slides off the bracket. Disconnect the connector and open the rubber boot. Replace bulbs and reverse the above.
brunetmj is offline   Reply With Quote
Old 07-23-2004, 10:51 PM   #3
brunetmj
Member#: 8023
2004 2.5 RS
Shoot. It's an 05. Hopefully it's the same.
How do I change H3 fog light bulbs on 2003 WRX? scoobbee Interior & Exterior Modification 9 03-24-2013 08:50 PM
How do you change the fog light? Lagwagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-03-2005 09:25 PM
How do I change the fog light bulbs on an 04 WRX? salvooch Electrical & Lighting 2 10-14-2004 10:54 AM
04 REX how do you change the fog lights? kitbar Interior & Exterior Modification 2 04-12-2004 11:38 PM
How do you change the WRX parking light bulbs? YeeHa Interior & Exterior Modification 5 02-03-2002 05:06 AM
