Old 07-24-2004, 11:42 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Exclamation Header FAQ: Read if you are thinking of buying one!
Header FAQ
The primary purpose of an aftermarket header on a turbocharged Subaru is to remove or replace the stock exhaust manifold with a better flowing unit.
HP gain is 15HP and 20TQ. This figure is highly debated as different manufacturers use different dynos with different cars with different levels of mods. It also varies because some headers incorporate an uppipe into their design. This makes it nearly impossible to compare the gains of a header without an uppipe vs. a header with an uppipe.
Which manufacturer is best? This topic is highly debated. There have been no reported consistent "bad" headers on the market. Obviously, there may have been bad pipes sold, but not enough to report as "bad" overall.
Who manufactures headers? (Price ranges listed are general, not including sales, specials, etc.)
5Zigen ($500-$999)
alpha werks (<$500)
APS ($500-$999)
Aqua ($1000+)
AVO ($500-$999)
B&B ($500-$999)
Borla (<$500)
BPM ($1000+)
Cusco ($1000+)
DC Sports ($500-$999)
DN Performance ($1000+)
Flatt Racing ($1000+)
Forced Air Technologies (<$500)
Fujitsubo ($500-$999)
Full Race ($1000+)
GP Moto ($500-$999)
GReddy ($500-$999)
Gruppe-S (<$500)
GT Spec (<$500)
HKS ($500-$999)
Invidia ($1000+)
JIC ($1000+)
JUN ($1000+)
Lachaute Performance ($500-$999)
Maxim Works ($1000+)
Megan Racing (<$500)
MRT ($1000+)
Quicktime Performance ($500-$999)
Perrin ($500-$999)
Prosport (<$500)
Skunk2 ($1000+)
Supersprint ($unknown)
SSAutoChrome (<$500)
Syms ($1000+)
Synic Motorsports ($500-$999)
Titek Innovations (<$500)
Tomei ($500-$999)
Vibrant Power (<$500)
XO2Racing (<$500)
XX Tuning (<$500)
ZeroSports ($1000+)
What differences are there with headers? The main difference is exhaust piping length. Headers are made to be unequal length or equal length. Unequal means the piping on the driver's side of the engine will be longer than the passenger's side. Equal means the piping length is equidistant from the engine outlet to the header outlet for all piping.
What about the header comparison? The header comparison idea was started by the NASIOC member downshift1 on this thread and resulted in the publication of the test findings in Speed, Style, & Sound Magazine. An authorized reprint of this article can be found via this link. Larger versions of the dyno plots can be viewed here, here, here, and here. Quite a few headers were tested and the results bring up a lot of interesting data on headers for turbo Subarus.
A newer test was conducted by NASIOC member RainMaker and the results can be found via this link.
What changes will be made to the exhaust sound?
a. Equal length headers: there will be a drastic difference in the exhaust note. It will change from the boxer rumble to a more traditional engine tone. This can be negative for some people as they love the unique sound of a boxer engine.
b. Unequal length headers: there is generally mild to no sound (db) increase or change in tone. Any changes in unequal length headers are generally considered subtle.
I have or soon will have a twin scroll turbo, is that important for header choice decision? Yes. You must use an equal length header specifically designed for a twin scroll turbo, otherwise 100% of the twin scroll turbo's benefits (earlier spool vs. equally sized regular turbo) are gone. While you could use an unequal length or regular equal length header with a twin scrool turbo, you now will have regular turbo spool characteristics or possibly worse.
Which header has the best gains? There is no irrefutable evidence that any header has better gains than another. The consensus, if there is one, is they are all within 5HP or less, gain wise, of each other. That being said, there are extremely wide variations in how each header affects the powerband. This will play a key roll in determining which header best suits your power wants in which powerband.
Are there any downsides to headers? Yes.
a. Some manufacturers' early versions of headers had fitment issues, which could be cause for concern if purchasing a used header.
b. There may be a few manufacturers who still produce headers with possible fitment issues.
c. Increased in turbo spool time. The actual RPM reduction will/may vary with manufacturer/heat wrap or coating/overall header temperature but a good rule of thumb is around a 300 RPM increase (spool comes on later) in spool time.
d. Some newer headers are designed for the STi, so they may require WRX users to use the STi oil pan due to it's different shape.
e. 2006+ saw changes to the placement of the oil filter which can interfere with header fitment, so discuss with your Vendor prior to purchasing headers as to wether they fit correctly or not.
Are there any other benefits from a header? This link contains some very interesting testing of EGT readings from a full exhaust and a header. The results seem to indicate the cause of high EGT readings is due to the poor flow/design of the stock exhaust/exhaust manifold. Though this information isn't 100% foolproof, it offers strong credibility to the thought that headers+exhaust may be the solution to high EGT issues with modified vehicles.
Are there any do it yourself options? Yes. This thread contains a compendium of thoughts and experiences with port matching and port and polishing the stock exhaust manifold. Though there is a lot of theory and speculation there isn't a whole lot of evidence to support this modification having the same impact as a full set of headers. It certainly is a cheap, do it yourself project with few possible negative impacts though. This thread contains DIY porting instructions.
Where do I buy a header? Every Subaru/Import performance store sells headers. For purchasing, support your local economy or the NASIOC Vendors.
What questions should I ask of the retailer or manufacturer before purchasing?
1. Is this header equal or unequal length?
2. Do you provide EGT bung welding? (if applicable to the end user)
3. Do you provide ceramic or other coating services prior to purchase?
4. Does this header include an uppipe?
5. Are there any fitment issues (very important for STi and 2006+ owners)?
How hard is it to install a header? Allow around one hour for install time if using your factory uppipe or have already installed an aftermarket uppipe. Professional installation, depending on your area, is around $75. If using a header with an uppipe, and you still have your factory uppipe, allow around 3 hours for install time. This can depend on many variables. A lift and air tools will significantly speed up the process but aren't entirely necessary. Professional installation, depending on your area, is around $200. Shadetree mechanics will install for around $100.
How do I install a header? Refer to the header manufacturer's instructions.
What about ceramic or other heat wrap coating? Though there are pros and cons to heat retention treatments with exhaust components, the general consensus with headers is that heat retention benefits outweigh the liabilities.
Pros:
Increased heat retention, which is beneficial for exhaust flow.
Reduces underhood temps, which decreases IC heatsoak.
Cons:
Additional expense.
Additional lead time, in the case of coatings.
Increased heat retention, which in some cases, can accelerate metal fatigue, especially at weld joints.
No proven HP increase.
If you plan on using a coating, ensure you are aware of what impact this will have on your header warranty if applicable. Coating or wrapping your header can void exhaust component warranties. If using a ceramic-type coating, ensure it's working heat range is above the known EGT. EGTs can be as high as 1400-1600 degrees in the extremes. Some normal coatings are not rated to this temperature level.
What types of ceramic or other heat wrap coating are available? The two most popular manufacturers of heat wrap are Thermo Tec and DEi. The two most popular coating manufacturers are Jet Hot and Swain Tech Coatings. Wrapping is a DIY project with a shorter life span than the professional only coating with a longer life span.
Excellent coating thread
.pdf file on coatings
Car Craft magazine's testing of Jet Hot
Should I reset my ECU after this mod? It is never a bad idea to perform an ECU reset after a mod. The traditional route is to disconnect the negative battery terminal, press the brake pedal for a few seconds to bleed the system of charge, and reattach. Some use the more advanced Vishnu Reset.
Editors Note
This post was created because I wasn't able to find a good header FAQ. I came up with the text based on LOTS of searching here. Upon reading this you should have an idea of what type of header best suits your needs. The manufacturer is up to you.
If you find an error in this FAQ, please PM me with factual details and I will update this post. Responses such as, "I have XXX's header and it's great!" or "XXX's header leaked after 1 month" are not appreciated here, that is what the Car Parts Review Forum is for.
Old 07-24-2004, 11:47 PM   #2
MDChevyguy
Member#: 51024
2005 Dodge Durango
2004 WRX Just Sold
As always, well done article Unabomber. However I think there is one area that should addressed that wasn't. Is there anything to be said regarding the screws of a header loosening from the engine creating a loose header/exhaust leak over time??
MDChevyguy is offline   Reply With Quote
Old 07-24-2004, 11:53 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Are you talking about those headers that have the old slip joints in the middle of the piping with those weird bracket/clamp/bolted do-hickies?
Old 07-24-2004, 11:59 PM   #4
MDChevyguy
Member#: 51024
2005 Dodge Durango
2004 WRX Just Sold
I'm talking about where the headers bolt into the engine block, with those bolts being the focus of the loosening part. I know traditionally headers were good hp sources, but a pain due to the fact that if you didn't keep an eye on keeping the headers tightened down to the engine block, you would get loosened headers and an exhaust leak.
Old 07-25-2004, 12:03 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I understand what you are talking about, but have never heard of this occurance on a Subaru. From my research here, this has never happened on a Subaru. I could be wrong though, so help a brother out! Aside from this, as you might expect, there are a lot of singular events with headers. As this and all my FAQs are a generalization, I cannot go through each peculiarity with each header type/manufacturer, I only report on common occurances.
Old 07-25-2004, 12:19 AM   #6
railguy
Member#: 53756
Good work again......
railguy is offline   Reply With Quote
Old 07-25-2004, 12:41 AM   #7
ErikAnderson
Member#: 26739
I picked up a used DN performance unequal length header/up pipe set about 8 months ago for 200 bucks + my stock headers and up pipe, then turned around and bought another up pipe and stock header set for 90 bucks shiped (just to have...). Aside for the pain in the ASS install (headers have built in up pipe, with GIANT flex joint in it, you have to unbolt your motor and jack it up VERY high to get it in, and then its with much banging with a rubber mallet) i am a big fan of these headers. my only complaint with them was the funky ammount of in my oppinion useless bungs welded up in the upper regions of the up pipe part. I still had to get a egt bung welded in to a more usable part of them (3 inches down from the exhaust port).
So if you find a used set for an honest price, pick them up pronto. Do i think they are worth the 1299 sticker price? Probably not.. you could get a used UTEC and used turbo for that price and make serious power.
Erik
ErikAnderson is offline   Reply With Quote
Old 07-25-2004, 02:03 AM   #8
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Sticky!!
Bishop is offline   Reply With Quote
Old 07-25-2004, 02:36 AM   #9
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Old 07-25-2004, 09:43 AM   #10
bucklidl
Member#: 36765
2007 WRX wagon
2008 FSXT WRB
good job like always
bucklidl is offline   Reply With Quote
Old 07-25-2004, 10:40 PM   #11
Volkov
Member#: 58346
2009 WRX
Default What don't I understand?
Why is reduced turbo spool time listed as a bad thing?
Volkov is offline   Reply With Quote
Old 07-25-2004, 10:43 PM   #12
Volkov
Member#: 58346
2009 WRX
Sorry, won't let me delete the double post.
Old 07-25-2004, 11:02 PM   #13
Brad Pittiful
Member#: 34931
Originally Posted by Unabomber
Header FAQ
how come everyone ive read about getting borla headers say they love the sound and they say they are loud too...i thought borlas were unequal length headers...am i wrong here
and great job as usual
Brad Pittiful is offline   Reply With Quote
Old 07-26-2004, 04:15 AM   #14
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
You are correct. They are unequal length, and they keep the boxer sound.
With the Borla header, my car sounded much meaner inside the cabin, with rumbling noises coming from both the front and the back. It also increased engine vibration, especially with STi engine mounts. With my Borla header, the car would vibrate with the exhaust pulses, which the header enhanced. Outside the cabin, the exhaust note was higher-pitched, and somewhat raspy.
McBain_TP is offline   Reply With Quote
Old 07-26-2004, 07:33 AM   #15
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I got my increase/decrease terms mentally confused, thanks for pointing it out. A header (and there are always exceptions) will generally reduce boost onset by about 300RPM. Put another way, welcome to 300 more RPM of lag. Coating/wrapping, header type, supporting mods, and tuning can get rid of this, but since this is a general FAQ, I have to summarize.
I am actually a Borla user myself. Prior to installation I made specific mental notes as to the sound of my in-cabin and outside the car exhaust. I did this because the wife is not exactly Subaru friendly and this mod needed to be 100% transparent. In my case, the header made zero change inside or outside with regard to extra noise. The only noise they make is low RPM rattle at certain RPMs. The wife has never mentioned it, so I assume it's one of those "If you know you can hear it" sort of things.
Many people do experience sound changes either inside or outside the cabin with their header and as mentioned above, this is a generalization.
Old 07-26-2004, 01:24 PM   #16
Volkov
Member#: 58346
2009 WRX
Default thought so ... and didn't think so
Yep, I thought you had mis-stated increase/decrease turbo spool time.
But, I would have thought that headers improved spool. Important bit of info.
Another 1st class FAQ.
Old 08-02-2004, 10:54 PM   #17
HoOn
Member#: 43270
2004 Impreza WRX
... I did this because the wife is not exactly Subaru friendly and this mod needed to be 100% transparent...
Hahahah Like you my fiancee is not Subaru friendly that's why my mods have to be transparent.
- John
HoOn is offline   Reply With Quote
Old 08-03-2004, 12:33 AM   #18
PhoKingWRX
Member#: 30861
2002 Silver
Perrin Parts Slut
i dont know about yalls but whenever unabomber posts another faq, i get happy and giddy. got dammitz hes the man!
..because the more you know...
PhoKingWRX is offline   Reply With Quote
Old 08-03-2004, 12:57 AM   #19
billllly
Member#: 62116
'02 WRX
blue/gunmetal wheels
Why is this not sticky somewhere yet?
billllly is offline   Reply With Quote
Old 08-03-2004, 01:10 AM   #20
McBain_TP
Member#: 43986
2002 WRX wagon RIP
Before / after header clips
Borla header / Borla Hush: http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
stock header / Hush: http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
Old 08-03-2004, 02:17 AM   #21
Bishop
Member#: 59993
Ass, grass or cash
i can tell the different...sounds not that bad.
Old 08-03-2004, 02:52 AM   #22
McBain_TP
Member#: 43986
2002 WRX wagon RIP
The difference isn't nearly as noticable in the cabin. For a while I actually thought the Borla made it sound deeper and meaner, until I saw the video. Then I was like, "Ewwww, it sounded like that for nine months?!"
Old 08-03-2004, 02:54 AM   #23
iofdetiger
Member#: 60924
amazing faq once again.
iofdetiger is offline   Reply With Quote
Old 08-03-2004, 02:58 AM   #24
Bishop
Member#: 59993
Ass, grass or cash
"ewwww" as in you didn't like the sound before the header or after the header? what other mods are on the car? do you still have your dp cat and 3rd cat in??
Old 09-17-2004, 10:05 PM   #25
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
Green w rust coloration
I would also like to know the answer to this !
wrxsubaruwrx is offline   Reply With Quote
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 10:03 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 111 06-11-2016 09:28 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
