Old 07-27-2004, 01:11 PM   #26
STiLL WILL
Member#: 37581
2004 SZ55'd STi
375whp on 91/404whp on 95
Wow, all on 93 pump huh. VERY impressive! Now how about some pics of the installed GT30?
-Matt
STiLL WILL is offline   Reply With Quote
Old 07-27-2004, 03:02 PM   #27
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
The numbers are very impressive, but I'm concerned with how HP is falling off like mad at the top. Looks very unhealthy! Must feel like it's dying if you catch a gear in the upper 5k's.
Regardless, grats Dan! Good to see things working out with the kit!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-27-2004, 03:05 PM   #28
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Jorge (RiftsWRX)
www.ProjectWRX.com
*cough* small ports *cough*
Old 07-27-2004, 03:12 PM   #29
Julio
Member#: 6363
10 Sec. Club
Element - Crawford
Definately it needs some porting, and/or cams.
Dan: I know we have talked... Congrats.
I know you have your "biggest" monster still under the sleeve! hehe
Julio is offline   Reply With Quote
Old 07-27-2004, 03:56 PM   #30
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Could be valve float. Thats what i ran into but not until 2 bar of boost.
C
AZScoobie is offline   Reply With Quote
Old 07-27-2004, 10:26 PM   #31
AntonioS
Member#: 23233
2000 2.5RS-T
white
mmmmmmmm on pump gas is a little bit hard to believe and only at 23psi, lets see some time slips and see if the numbers at the dyno are visible at the track
AntonioS is offline   Reply With Quote
Old 07-28-2004, 01:25 AM   #32
odin1
Member#: 29362
2008 2008 sti
stage 2
My sentiments exactly and the lag is hard to take. Dan's been saying all along that these gt30's were going to be super responsive. At 4000 rpm it's making less than 200whp and the power dies off precipitously past 6000 rpm. At the same rpm and on a dyno dynamics dyno, (very low readingdyno) an sr50 on only 91 oct pump makes 260 whp. At 3500 rpm, the gt30 makes 115whp and the sr50 makes 180whp. It's only at peak hp that the gt30 shines, but the area under the curve leaves a lot to be desired in this state of tune. Not a very big window of power. If your caught out in the wrong gear or lower than 4500 rpm and floor it, the race will be over quickly. Imho, this combo needs more develpement, atleast forthe street. No offence meant, just some observations.
odin1 is offline   Reply With Quote
Old 07-28-2004, 01:54 AM   #33
mlambert
Member#: 13831
examine the dyno plot alittle more, maybe youll see jesus!
mlambert is offline   Reply With Quote
Old 07-28-2004, 02:03 AM   #34
G-4ce_Banger
Member#: 65760
'04 Impreza WRX
WR Blue Pearl
- WARNING- Noob Question: I know I that you are talking about a STi here but I have a WRX and was wondering about how the rest of the car holds up with that kind of power. I am mostly referring to the axles and tranny, but also anything else that should break with that much power. Is it pretty much just a given that those things would have to be beefed up to hold that kind of power?
G-4ce_Banger is offline   Reply With Quote
Old 07-28-2004, 02:03 AM   #35
odin1
Member#: 29362
2008 2008 sti
stage 2
You're a funny guy. Anything constructive to add?
Old 07-28-2004, 02:24 AM   #36
mlambert
Member#: 13831
Sure, how about... you're stupid and Dan did a fine job making power.
Old 07-28-2004, 02:27 AM   #37
supermarkus
Member#: 6971
2008 WRX STi
SSM
IBTCATFIGHT!
Dammit, too late.
supermarkus is offline   Reply With Quote
Old 07-28-2004, 03:36 AM   #38
odin1
Member#: 29362
2008 2008 sti
stage 2
Grow up. You're on ignore.
Old 07-28-2004, 03:49 AM   #39
1m4dSTI
Member#: 66883
2004 STI
JAVA BLACK
At the same rpm and on a dyno dynamics dyno, (very low readingdyno) an sr50 on only 91 oct pump makes 260 whp. At 3500 rpm, the gt30 makes 115whp and the sr50 makes 180whp. It's only at peak hp that the gt30 shines.
were you refering to my dyno numbers...??..
1m4dSTI is offline   Reply With Quote
Old 07-28-2004, 08:05 AM   #40
silverstipa
Member#: 42271
2004 STI - FPgreen
Enjoyed by a new owner
Noone will be able to convince you that it is pump gas and 23psi. It is my car, I filled the tank w/ 93 octane, and nothing was added. No games here.
It will see the track all in due time. I have to relearn how to drive this car. The power comes on so hard it is difficult to control the car with all 4 wheels spinning. Also, shift points are going to be critical and need some experimentation.
silverstipa is offline   Reply With Quote
Old 07-28-2004, 08:09 AM   #41
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Any thoughts on adding alcohol injection to give even more safety against knock and increasing the timing?
offset
offset is offline   Reply With Quote
Old 07-28-2004, 08:12 AM   #42
Tuning Factory Inc.
Vendor
Member#: 3600
We ran a GT30R on a WRX and also publushed the results. If you want to see, do a search here or on Cluv WRX. I'm sure the sheets and data are all still posted. We made 352 WHP on pump fuel and over 400 easily on race fuel although due to the completely bone stock engine and trans we stopped at that point. Car was blinding fast and the engine lasted a good 6 months before he broke it runnign race fuel all the time and embarrasing supercharged Mustangs. We are rebuilding it into project Phoenix right now and aiming for a new record. On a WRX you will need to convert to 6 speed or use Kaaz gears. Engine work is recommended eventualy although if you take it wasy with the boost you can run it stock motor for quite some time. I'm eager to test out water injection but I haven't yet. I have no doubt the numbers would improve even more with a little water injection thrown into the mix.
Tuning Factory Inc. is offline   Reply With Quote
Old 07-28-2004, 09:29 AM   #43
totoherbs
Member#: 7321
.... 122 IggPoints
I always took what Dan said as a super responsive for a turbo of its size. Of Of course its not going to be as responsive an sr50 just like the sr50 is no where near as responsive as a gt28.
Old 07-28-2004, 10:41 AM   #44
odin1
Member#: 29362
2008 2008 sti
stage 2
Yes I was. :-). Now that's a very responsive turbo for a large turbo that still makes good hp up top.
Old 07-28-2004, 10:48 AM   #45
odin1
Member#: 29362
2008 2008 sti
stage 2
Originally Posted by totoherbs
I always took what Dan said as a super responsive for a turbo of its size. Of corese its not going to be as responsive an sr50 just like the sr50 is no where near as responsive as a gt28.
An sr50 has a compresor flow which is similar to a gt30. A gt28 is much smaller than either. I was trying to compare apples to apples. Also, since noone has a gt28 on an sti, we don't know how the responsive it will be.
Old 07-28-2004, 11:29 AM   #46
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I drove the whole way from central PA with him in the car. There was nothing in that tank but Sunoco 93 octane.
Jard is offline   Reply With Quote
Old 07-28-2004, 11:48 AM   #47
gpatmac
Member#: 18446
2002 WRX wagon
psm
Dan,
Sending a email.
gpatmac is offline   Reply With Quote
Old 07-28-2004, 01:20 PM   #48
Jimbo
Member#: 28809
2003 WRX Wagon
Platinum Silver Metallic
Stock clutch?!
Jimbo is offline   Reply With Quote
Old 07-28-2004, 01:25 PM   #49
cronic
Member#: 9749
How many Lb/min compressor does the Sr50 use?
cronic is offline   Reply With Quote
Old 07-28-2004, 01:37 PM   #50
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
~50lb/min i believe.
Soon2Bgreat is offline   Reply With Quote
2005 Saabaru - stock 2.0 - Super16G - 352/304 whp/wtq - 93 octane Motion Lab Tuning Proven Power Bragging 53 09-17-2010 10:24 AM
Evo warning... 674 whp on 93 octane + meth Innovative Tuning Proven Power Bragging 54 12-28-2009 12:34 AM
400 WHP, 24.5psi on 93 octane, no meth??? TurboQueef Built Motor Discussion 4 08-13-2008 08:31 PM
Crawford Performance CP35R and Stock Block: 433 whp on 91 Octane Crawford/I-Speed Proven Power Bragging 72 06-22-2006 09:15 PM
Wich turbo for 400 WHP on 91 octane Gas fzturbo Proven Power Bragging 36 01-19-2006 08:18 PM
