Old 07-28-2004, 01:38 PM   #51
1m4dSTI
Member#: 66883
2004 STI
JAVA BLACK
Originally Posted by odin1
Yes I was. :-). Now that's a very responsive turbo for a large turbo that still makes good hp up top.
id have to agree!...great response in every gear..no complaints.
1m4dSTI is offline   Reply With Quote
Old 07-28-2004, 02:02 PM   #52
G-4ce_Banger
Member#: 65760
'04 Impreza WRX
WR Blue Pearl
"Engine work is recommended eventualy although if you take it wasy with the boost you can run it stock motor for quite some time."(sorry, I messed up on the quote I used quick quote and it didn't work the way I thought it would ) If and when I decide to reach hp numbers that high, I would plan to do extensive engine work, but I am mostly curious about any weak links in the driveline. Also by then I would have my wheels (the ones I am looking at would be 18x8) which would add even more stress on the driveline.
G-4ce_Banger is offline   Reply With Quote
Old 07-28-2004, 02:12 PM   #53
silverstipa
Member#: 42271
2004 STI - FPgreen
Enjoyed by a new owner
Originally Posted by Jimbo
Stock clutch?!
No. I have an ACT street clutch.
silverstipa is offline   Reply With Quote
Old 07-28-2004, 02:15 PM   #54
2000vfr800
Member#: 15599
Hey Dan...is "Project Phoenix" going to be ready for the East Coast Subaru Shootout?
2000vfr800 is offline   Reply With Quote
Old 07-28-2004, 06:01 PM   #55
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
SR50;
Compressor Turbine
A/R 0.60 0.82
Inducer 55.0 mm 56.5 mm
Exducer 76.2 mm 53.5 mm
Gods turbo I dont know... there are a whole lot of options for a gt30. What 40 to 60+ comp?
Also, since noone has a gt28 on an sti, we don't know how the responsive it will be.
I dont think its a stretch of the imagination to guess at how responsiveive the gt28 will be on a 2.5L; hell on a 2.0 even a 1.8 its very quite nice.
Old 07-28-2004, 09:50 PM   #56
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
Dan is using a 52lb/min compressor wheel, on the "520" kit, and a 65 lb/min on the 650 kit.
pegdrgr is offline   Reply With Quote
Old 07-29-2004, 01:57 AM   #57
odin1
Member#: 29362
2008 2008 sti
stage 2
Originally Posted by cronic
How many Lb/min compressor does the Sr50 use?
Supposedly 55 lb/min compressor, or 770 cfm at 60 % efficiency. Fp green according to pdxtuning is 49 lb/min compressor. gt28? much less 35-40lbs possibly.
odin1 is offline   Reply With Quote
Old 07-29-2004, 02:11 AM   #58
odin1
Member#: 29362
2008 2008 sti
stage 2
Originally Posted by totoherbs
SR50;
Compressor Turbine
A/R 0.60 0.82
Are u purposely missing the point. We are comparing the responsiveness of large turbos here. Until now, the fp green was considered very responsive for a large turbo. Definitely much more responsive than the gt30 in this dyno. But as I pointed out earlier, the sr50 w/ a 55lb/min compressor outspools and out responds the green and far outspools the gt30. the gt28 is a mosquito in this comparison toto. If it didn't outspool the sr50 ( which it may not. Time will tell ) I'd be surprised. Just as I would expect the vf39 to outspool the gt28. Let's compare the big boys to the big boys. Apples to apples. And while we're at it, I'd love to see this combo on a mustang or dyno dynamics dyno which is where the serious players are. It's a known fact that taking the wheels and tires off greatly reduces reciprocating mass and artificially inflates hp. The higher the hp, the higher the margin of error. These dynos are fine for tuning, convenient because of their portability but this isn't wheel hp, it's hub hp. Big difference. Silverstipa, not knocking your combo at all. I think it's awesome. The 1/4 mile times will tell.
Old 07-29-2004, 06:26 AM   #59
2000vfr800
Member#: 15599
I couldn't have said it better myself.
Old 07-29-2004, 07:38 AM   #60
Tuning Factory Inc.
Vendor
Member#: 3600
Well we read a little lower than Dynojet regardless so I wouldn't say the numbers are necessarily inflated. Oddly, Cobb's Mustang dyno reads very similarly to ours. Project Phoenix will be getting the same block as the one above so hopefully Magnus will be quicker this time. We shall see. It really makes no difference in terms of the dyno type. I think it's mostly in the software on how the numbers stack up against each other.
Tuning Factory Inc. is offline   Reply With Quote
Old 07-29-2004, 07:59 AM   #61
2000vfr800
Member#: 15599
Please....let's not get into another dyno discussion. We've gone over this over and over again.
Let's just leave it at "Those are nice dyno numbers and we are anxious for track numbers."
Old 07-29-2004, 08:22 AM   #62
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Could this have anything to do with Cobb's dyno being at a higher elevation?
offset
offset is offline   Reply With Quote
2005 Saabaru - stock 2.0 - Super16G - 352/304 whp/wtq - 93 octane Motion Lab Tuning Proven Power Bragging 53 09-17-2010 10:24 AM
Evo warning... 674 whp on 93 octane + meth Innovative Tuning Proven Power Bragging 54 12-28-2009 12:34 AM
400 WHP, 24.5psi on 93 octane, no meth??? TurboQueef Built Motor Discussion 4 08-13-2008 08:31 PM
Crawford Performance CP35R and Stock Block: 433 whp on 91 Octane Crawford/I-Speed Proven Power Bragging 72 06-22-2006 09:15 PM
Wich turbo for 400 WHP on 91 octane Gas fzturbo Proven Power Bragging 36 01-19-2006 08:18 PM
Message Board Statistics All times are GMT -4. The time now is 02:59 PM.
