Old 07-25-2004, 07:08 PM   #1
Unsung Boxer
Member#: 37196
Default Hogged out RS injectors
a while back someone was doing some experiments w/ RS injectors. From what I understood, he was drilling out the pentum to increase flow rate. And they were suppsed to get flow tested.
How did this ever turn out? Were they consistant? Did the injectors have a good spray pattern? Did they actually work in the vehicle?
I am interested in this because I have never understood why an aftermarket injector should cost so much compared to a stock one... when in all actuality, it is an almost identicl electromagnetic valve that just allows more flow.
Anyhoo, what were the results?
Unsung Boxer is offline   Reply With Quote
Old 07-25-2004, 07:53 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
ill tell u something jake
i bought super small drill bits from mcmaster
i was about to have an experience jewler drill out my set of wrx injs i had but before i did my friend got his results back from RC
his were shot, 2 worked, 2 were destroyed because a few of the holes went past the sealing section of the piston or something like that
be cuurful
Old 07-26-2004, 09:05 AM   #3
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
That was me.I have not put the motor together and in the car yet.Project is on hold.Here's the link.Any questions feel free to ask.
http://forums.nasioc.com/forums/show...ight=injectors
Later,Tod
todnar is offline   Reply With Quote
Semi Part Out (Turbo, Injectors, Manifold, v7 Cluster, Inlet, etc.) dan avoN7 Private 'For Sale' Classifieds 22 11-15-2004 01:57 PM
Swapping out fuel injectors (for STI's) Vector92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-04-2004 02:12 PM
2.5 RS injector/WRX injector specs? STi - IMPREZA Newbies & FAQs 1 09-24-2003 11:54 AM
Maxing out stock injectors Santo Domingo 2.5 RS Normally Aspirated with bolt-on Forced Induction Powertrain 12 05-01-2003 02:09 PM
TD05 or TD06 max out my injectors @ 10psi? BLCK DVL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-03-2002 02:32 AM
