Old 07-25-2004, 09:11 PM   #1
kaos200
Member#: 2692
making this for all the newbs
Specs
EJ257 with SOHC heads approx 8.x:1 (since the sohc has 3cc more volume then the wrx heads according to Cobb)
EJ257 with WRX heads approx 8.x:1
EJ257 with STi heads approx 8.x:1
EDIT: I HAVE REMOVED THE CR ESTIMATES SINCE THERE ARE NOW MANY VARIABLES (EJ255, EJ257s, and differences in cylinder heads).
The block is good to atleast 7500rpm (from personal experience, others may go higher, im not that crazy)
The block is holding up to 20+psi boost, and 450whp so far without much trouble (again, its all in the tuning/setup)
If installing into RS with sohc. parts needed are...
- STi headgaskets
-WRX upper coolant pipe... requires the following
-- coolant line from pepboys/kragen to go to heater core, stock prerouted piece will not work
-- you need to grind some metal off the passenger side cylinder head near where the upper radiator hose attaches to the upper coolant pipe. A die grinder makes quick work of this.
-- you need to lengthen the wires for the coolant temp sensor, since it sits in a different location.
-- you need to do the coolant through throttle body bypass mod, AND remove the little piece of metal that sticks into the throttle body that the coolant goes through, or else it will hit the new upper coolant pipe where it meets the heater core hose. (yank out or cut off, your choice)
OR, use the stock upper coolant pipe, but you need to measure where to cut out a chunk of it since the block has that extra breather, then weld the hole in the pipe shut.
If installing with dohc,
You can use either upper coolant pipe, and if using the one meant for the wrx, you do not need to grind the heads, but the other mods must be done. INCLUDING....
-DOHC Oil dipstick tube, it mounts to the head differently.
-You still need the STi head gaskets.
If using wrx heads, you can use the stock RS intake manifold, and everything else but you must drill out the manifold bolt holes, and shave some of the plastic on the driver's side valve breather piece (hard to describe, black plastic piece that attaches to top of valve cover, well, guess its not THAT hard to describe)
If using STi heads, you MUST use the sti/wrx intake manifold, and rails etc. I had an adaptor made to use my stock RS throttle body, but that was such a pita
So using STi heads, pretty much means you've gone and changed the entire motor setup, and you're going to probably do an ecu swap as well.
If im missing anything just post it and Ill add it so people doing a search can just find it all here.
EDIT: SOMEONE ASKED THE FOLLOWING:
So. Are you saying that if you use wrx heads in an rs that you do not have to do an ecu/harness swap? Just em?
No, if you switch from SOHC to DOHC, you must change the ecu somehow. Either do a wiring swap and go OEM or use a standalone system.
That being said, I had moved away from recommending piggybacks and standalones years ago. I've done so many wiring mergers for people now it's not even funny. Another benefit of that is that for those in smog strict states (like good ol' CA) the swap would be legal.
EVERYONE NOTICE THE ORIGINAL POST WAS FROM 2004!
I INTENDED IT FOR GC MODEL 2.5RS, NOT NEWER MODELS.
kaos200 is offline   Reply With Quote
Old 07-25-2004, 09:48 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
adding this to the Forum FAQ... good job
kastle is offline   Reply With Quote
Old 07-25-2004, 11:06 PM   #3
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & 06 MCS
What about with 2.5 DOHC heads? I searched and found tons of threads, but all of them seemed to be for using wrx heads.
subiekid is offline   Reply With Quote
Old 07-25-2004, 11:27 PM   #4
kaos200
Member#: 2692
I havent had a chance to experiment with them, but I would imagine the only difference is in the intake manifolds. You would need to just use the manifold for the dohc RS, and not the wrx.
Old 07-26-2004, 12:22 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
great post Kian, i am gonna fly you out here when it's time to put one in liz's car
Jeremy
Old 07-26-2004, 12:22 AM   #6
kaos200
Member#: 2692
haha, thats cool, I wanna come visit eventually anyways!
Old 07-27-2004, 11:32 AM   #7
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
awesome post!
HOK is offline   Reply With Quote
Old 07-27-2004, 12:05 PM   #8
Crawford Performance
Member#: 42075
I have put the 2.5 n/a DOHC heads on the STI shortblocks many times.
Use the STI head gaskets and every thing else bolts up.
Quirt Crawford
www.crawfordperformance.com
Crawford Performance is offline   Reply With Quote
Old 09-02-2004, 12:15 AM   #9
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
How much do you need to drill out the bolt holes? do you have any pics showing this by any chance??? I'm thinking of picking up a set of 04 wrx heads mated to a ej257 block with rs Intake manifold...
Any comments?
latinskllz is offline   Reply With Quote
Old 09-02-2004, 12:21 AM   #10
kaos200
Member#: 2692
its a few mm's of shaving, on each end of the manifold (to make it even) and the plastic piece must be shaved a few mm's as well. Its not bad, but you must take your time and do it right.
Old 09-02-2004, 01:20 AM   #11
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
So, a little off topic here, but I think you know the answer. I am putting some USDM Version 8 heads on my ej22t block. Will my MY99 Intake manifold work with these heads?
Drac9 is offline   Reply With Quote
Old 09-02-2004, 01:39 AM   #12
kaos200
Member#: 2692
If you mean USDM STi with AVCS, nope, no dice. The avcs hits the manifold...
Old 09-02-2004, 01:57 AM   #13
Drac9
Member#: 9861
Damn, this is getting more and more expensive by the day. Anyone wanna buy a really nice, shiny, polished 99 manifold? What are my options without changing to new injectors?
Old 09-02-2004, 02:01 AM   #14
kaos200
Member#: 2692
Id say screw the avcs heads, theyre not of much advantage unless avcs is working anyways.
Old 05-17-2007, 02:28 PM   #15
Migo
Member#: 81352
2003 '03 EJ257 wagon
Green
bump...
I did the EJ257 with SOHC heads on a 2003 RS/TS. I bought turbo aftermarket coolant pipes but found it unnecessary, and it's a good thing I didn't spend time on lengthening the coolant temp sensor wires yet, because these were strangely not necessary for swapping the EJ257 on the 2003 RS/TS.
I did hammer the extra breather tube to fit the crossover coolant pipe, and siliconed it shut.
Grinding parts wasn't applicable on this...
I'm assuming that this FAQ is for the older 2.5RS?
Migo is offline   Reply With Quote
Old 05-17-2007, 04:37 PM   #16
kaos200
Member#: 2692
Originally Posted by Migo View Post
bump...
Yes the notes were for the original GC RS's
If anyone would like to note the significant differences in any years after and let me know I'd be glad to modify the original post to reflect the changes.
Kian
edit: Once I get around to it I need to post up the chart I made for wiring in swaps.
Basically a pin by pin/ wire by wire how to for the popular model years.
So much stuff to do... So little time
Old 05-18-2007, 04:16 PM   #17
DZnutz
Member#: 91837
is this a good idea? id assume the breather is there for a reason. possibilty of building up unnecessary pressure by capping it off?
DZnutz is offline   Reply With Quote
Old 05-18-2007, 04:29 PM   #18
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
This is always in debate.
A lot of air flows through it, thats my input.
Old 05-18-2007, 04:40 PM   #19
kaos200
Member#: 2692
I'm definitely against that, it is there for a reason and blocking off that passage can't be good for anything. There are people that have done it, but I'm not sure of the outcome.
Old 05-18-2007, 04:41 PM   #20
turboed22
Member#: 93364
1998 Impreza RS-T
22 SM
I capped it. I was getting a ton of oil through it into my re-circ system
I am using a 22t though
turboed22 is offline   Reply With Quote
Old 05-18-2007, 04:44 PM   #21
4S-TURBO
Member#: 67807
'02 McIntosh stereo
...with a Subaru attached
i may just go down that yellow brick road afterall...
newb question: will a turbo x-member still be necessary to run the sti shortblock because of the oil pan/headers? i'm not too interested in grinding the stock one. thanks.
Old 05-18-2007, 05:06 PM   #22
Migo
Member#: 81352
Green
A few other people actually pull the entire tube out, and weld the hole shut. I'm assuming that it is there for perhaps the extra stress/flow that the STi has compared to the RS, so I wouldn't pick 'yes' or 'no' because my application with my EJ257 is higher compression non-turbo....
But before I siliconed it shut, I had oil spewing everywhere out of that breather. The whole block was covered in oil and the oil was burning off under the hood, creating a large cloud of smoke. Other cars beside me looked quite nervous.
No there's no need for a turbo crossmember unless you want to eventually use turbo exhaust components. I reused my old oil pan and headers. Using a turbo crossmember is mainly for clearing an uppipe.
Old 05-18-2007, 05:26 PM   #23
4S-TURBO
Member#: 67807
'02 McIntosh stereo
which leads me to my next question: is the n/a oil pan sufficient to run, say, a bolt-on turbo kit that's designed for n/a x-member/headers, pushing a bar of boost with the sti s/b and n/a sohc everything else?
thanks migo!
Old 05-18-2007, 06:17 PM   #24
kaos200
Member#: 2692
thanks migo!
It's fine. Depending on what year your model is you may already have a regular wrx (5qt) oil pan, the older RS's came with 4.5 qt pans. The STis pans are different for twin scroll manifold piping (which... they don't even come with...)
Old 08-08-2007, 11:08 PM   #25
dogtranny 2.5rs
Member#: 156136
1992 Turbo Legacy
white
sorry if this is a easy question but with the EJ257
would the DOHC or the SOHC be faster wen only naturally-aspirated
i just got a job and looking for a 1999-2000 2.5rs coupe
new to the forum too thanx
dogtranny 2.5rs is offline   Reply With Quote
'03 EJ20T into 2.5RS - WIRING Q's. WRX 555 STi Subaru Conversions 0 06-19-2004 08:56 PM
Version 4 STi into 2.5RS stiturbo Newbies & FAQs 3 01-04-2004 03:06 PM
Forester 2.5XT Swap into 2.5RS... Sebaflex Subaru Conversions 10 09-28-2003 08:16 PM
wrx sti into 2.5rs swap snyper784 Factory 2.0L Turbo Powertrain 1 12-13-2002 11:41 AM
engine swap into 2.5rs Silver_Fox General Forum Archive 1 03-26-2001 07:04 PM
Message Board Statistics All times are GMT -4. The time now is 04:44 AM.
