Old 07-26-2004, 01:07 AM   #1
rageatm007
Member#: 64116
Exclamation Check engine light blinking!!!
After installing some stereo equipment today the check engine light came on and I don't know why. Can anyone help me or tell me what they suggest?
rageatm007 is offline   Reply With Quote
Old 07-26-2004, 01:09 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Is it on or blinking? You could go get the code scanned at Autozone and then tell us what it is. Then we'll be able to help you out.
Calvin
cnk is offline   Reply With Quote
Old 07-26-2004, 01:26 AM   #3
ErikAnderson
Member#: 26739
if it is blinking, please tell us when.
if it is blinking while you are driving it could be because you are are knocking, that would be bad.
ErikAnderson is offline   Reply With Quote
Old 07-26-2004, 02:19 AM   #4
Shinji N
Member#: 3987
1999 Miata
Did someone else do the install?
I know in my 2001 2.5rs, there are these two green connectors by the hood release lever that are disconnected. They are for putting the obd2 in test mode or something. If you connect them they make the cel blink.
Shinji N is offline   Reply With Quote
Old 07-26-2004, 02:33 AM   #5
mosqito16
Member#: 42668
2004 JBP WRX Gone W/
The Wind...09 DGM WRX 5DR
ya we found out the hard way about the test connectors
mosqito16 is offline   Reply With Quote
Old 07-26-2004, 07:54 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I'll bet that's it. It is somewhat common for those connectors to get plugged in during a stereo install or other under-dash work, because they look like they are supposed to be connected. But, they're supposed to be left unplugged. They activate a diagnostic mode when connected together.
Help! Check Engine Light + Blinking Cruise Control mindz0f1 General Community 3 02-15-2007 09:35 AM
Check engine light blinking!?! Chonojake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-11-2006 09:06 PM
check engine light blinking jimball21 Tri-State Area Forum 20 01-25-2005 12:31 AM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 5 08-26-2003 09:08 PM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 2 08-26-2003 08:59 PM
