Old 01-09-2001, 05:25 AM   #1
4x4x4x5
Member#: 3427
2001 2.5 RS
SRP
Post soft brake pedal
I only have 600 miles on my 2001 2.5 RS, but it seems as if the brake pedal is pretty soft. The car seems to stop just fine but just not a lot of brake pedal feel. Is this normal for Subes or do I need to have it looked at ?
Bruce
4x4x4x5 is offline   Reply With Quote
Old 01-09-2001, 05:36 AM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
normal, don't worry
JGard is offline   Reply With Quote
Old 01-09-2001, 06:07 AM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Post
Yeah, It's normal for Subarus. I thought the same thing when I first got mine. If you really can't stand it, get a single stage brake booster, and maybe some SS lines from SPD, TRi, Rallispec, etc.
Old 01-09-2001, 09:56 AM   #4
Ben
Member#: 423
2002 WRX wagon
Post
Maybe its some rust built in between the pad and piston, you could try to remove the metal plate that on the brake pad and remove the rust, it may make the padel feel better!!
Ben is offline   Reply With Quote
Old 01-10-2001, 07:45 AM   #5
Tim K.
Member#: 214
2014 Massey Ferguson
Red
Post
Bleed the brakes. It will help take some of the softness out of the pedal. However, we are blessed with a dual stage booster on our brakes which results in the soft pedal feel. Its what SOA thought we wanted... *sigh*
Tim K. is offline   Reply With Quote
Old 01-10-2001, 08:43 AM   #6
4x4x4x5
Member#: 3427
2001 2.5 RS
SRP
Post
thanks for all the info guys, I appreciate it. On a related note, would changing to braided stainless steel brake lines help ? I have done that on all my motorcycles over the years but they aren't power assisted systems.
Bruce
Old 01-10-2001, 08:58 AM   #7
mav1c
Hoodbridge!
Member#: 560
Post
Yes, braided stainless lines will help....a LITTLE bit, but the BIG change to a MUCH firmer pedal comes fom the Single Stage Brake Booster. SPD (www.spdusa.com), ISR (www.autocaresubaru.com), and a few others have them.
Old 01-10-2001, 10:50 AM   #8
wop
Member#: 1931
2000 00 impreza 2.2l
wagon
Post
I concur with the brake booster. Here is a portion from a similar topic (four pots / street)
the brake booster would give you a much better pedal feel (as well as saving you some cash from going with the four pots and rotors) According to Mike Shields ( www.spdusa.com ) the booster and new pads is more than sufficient for a road car (he didn't seem to think the lines were needed, and did not have them on his car at the time I went to visit him).
-wop
<font color= black>-wop
hope that helps<font>
[This message has been edited by wop (edited January 10, 2001).]
wop is offline   Reply With Quote
Soft Brake Pedal YooperBaja Baja Forum 7 06-03-2007 02:41 PM
Soft brake pedal DiscoGsus Brakes, Steering & Suspension 3 10-19-2006 03:20 PM
soft brake pedal tcspeer Brakes, Steering & Suspension 4 07-14-2006 11:36 PM
soft brake pedal scuby Brakes, Steering & Suspension 3 10-26-2004 03:01 PM
Soft Brake Pedal Frey Brakes, Steering & Suspension 6 10-17-2000 09:51 AM
