Old 07-26-2004, 10:31 AM   #1
kastkc
Member#: 51141
2013 WRX
PBP
Default P0328, help!
I pulled the code and it means knock sensor 1 circuit high input. Sometime I can clear it, other times not. Only thing I notice is hesitation when accelerating between 2-4K rpn 1st through 4th gear, and its intermitant. The only pattern I am seeing is ,it is more noticable below a 1/4 tank of gas.
What is the cause of this? and how do I fix it? Any factual info would be great, Thanks
kastkc is offline   Reply With Quote
Old 07-26-2004, 12:07 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you probably need a new knock sensor
"KNOCK SENSOR CIRCUIT HIGH INPUT"
this is your code and it will cause knocking and crap driving performance
get a new knock sensor/replace
and you should be good as new
Jamie
www.subiegal.com
Old 07-26-2004, 01:51 PM   #3
kastkc
Member#: 51141
2013 WRX
PBP
I was hoping I wouldnt have to, but figured it was the cause and will look into it further. Any Idea on the cost and were to pick one up on the web?
Thanks
Ryan
Old 07-26-2004, 03:19 PM   #4
jeffg
Member#: 2958
2001 WRX (GC8)
also make sure that when you replace the sensor that you follow the install instructions to the "t" The torque spec is increadably low and over torqueing the bolt will kill the knock sensor.
jeffg is offline   Reply With Quote
Old 07-26-2004, 07:47 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Im assuming you have more than 36k miles?
Jay
Old 07-27-2004, 12:53 AM   #6
kastkc
Member#: 51141
2013 WRX
PBP
HTML Code:
yes, 39,800.
I did a datalog and found it pulled the timing 14 degrees where I felt hesitation when accelerating, between 3100 rpm (20 deg) 3800 rpm (6 deg) 4400 rpm (20 deg). My sample rate on the datalogger isnt the best, so I dont know if the timing was pulled any more than that.
Is this a definate indication of the problem being the sensor?
How involved is it to replace it? I hope to do it myself.
Thanks
Ryan
Old 03-14-2006, 12:13 PM   #7
Hotrodguru
Member#: 37210
2002 Tarmac Bugeye
2012 Hyundai Veloster
Did you ever replace this, did it correct your problem? I'm getting the same code.
Guru
Hotrodguru is offline   Reply With Quote
Old 03-15-2006, 12:44 AM   #8
gnar-kill
Member#: 103849
2002 Impreza RS
I had the P0328 for about 4 months...I kept on clearing the code but 50 miles later...it comes back. I replaced the knock sensor about 3 weeks ago and haven't pulled a code since. I don't really notice a difference before or after but atleast the light went away!
gnar-kill is offline   Reply With Quote
Helping a friend with a 02 WRX CEL p0328 Jkmaynard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-20-2009 08:23 PM
P0328 CEL code X4 SRT Service & Maintenance 12 08-09-2005 10:04 AM
cel p0328 & p1544??? ges311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-29-2003 08:58 AM
P0328-Knock sensor high input?? mofoporn Service & Maintenance 2 08-02-2003 12:30 AM
code P0328 zacek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-20-2002 03:07 PM
