Welcome to the North American Subaru Impreza Owners Club Friday August 22, 2014
Old 07-26-2004, 03:45 PM   #1
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Default MBC on an ECUTek reflash
Will this work?
After pondering for over a day why I was getting only 8lbs of boost (low boost mode), now I am only getting 12-13lbs.
Is it safe to run a MBC on a reflashed ECU to hit my target of 19psi on a VF22?
wcbjr is offline   Reply With Quote
Old 07-26-2004, 04:27 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
I would want to find out why I'm getting low boost to begin with instead of trying to up the boost.
Calvin
cnk is offline   Reply With Quote
Old 07-26-2004, 04:40 PM   #3
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I pulled the hose on the wastegate just to see if the wastegate was functioning properly. Got an easy 17psi. So either the EBC is jacked or the reflash isn't controlling the EBC correctly.
Old 07-26-2004, 04:48 PM   #4
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
who flashed your ecu? did you get a vacuum bleeder to put inline between the turbo and the FBC? are you using the stock wastegate lines or the ones that came with the vf22?
MikeWRX-NJ is offline   Reply With Quote
Old 07-26-2004, 04:50 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Vishnu did the reflash, and I received nothing other than my ECU back. I am using the stock lines with the restrictor. Should I take the restrictor out? Seems like that would only lower my boost.
Old 07-26-2004, 05:15 PM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
I will call and ask about my missing bleeder.
Old 07-26-2004, 07:13 PM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Bleeder being overnighted, should be tomorrow.
Old 07-28-2004, 11:01 AM   #8
dust12
Member#: 13417
I'm having the opposite problem. I'm hitting 21 psi and I only want it to get to 15 on the low boost setting and 17 on the high. I think my hoses are messed up (leaking) or my FBC is broken.
dust12 is offline   Reply With Quote
Old 07-28-2004, 11:16 AM   #9
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Bleeder works fine, getting 17psi now. Car's a beast!
dust, sounds like boost creep. you catless with a vf30/34?
Old 07-28-2004, 01:35 PM   #10
RussB
Guest
Member#: 43667
the bleeder is a form of manual boost control.
RussB is offline   Reply With Quote
Old 07-28-2004, 09:09 PM   #11
dust12
Member#: 13417
wcbjr glad you got it working! No, I have 1 high flow cat with a vf22.
I don't think its boost creep, I think my fbc is going out. Last night I was hitting 20+ in 2nd, 3rd gear, and today nothing changed, I didn't even touch the hoses, and my car is driving like its supposed to hitting 15 in 3rd, 4th gear. If I keep having problems, I'm going to try cleaning it.
Old 07-27-2005, 11:51 PM   #12
BamBooI
Member#: 10945
2006 Evolution IX
can you use a HPMBC with the ecutek? What if you use only a mbc will that work as well? The reason I ask is, when you use an mbc you spool up faster. TXS clames this on their HPMBC.
BamBooI is offline   Reply With Quote
Can you run a "blank" UTEC map over an EcuTek reflash, in which the reflash controls? scooterforever Engine Management & Tuning 42 05-04-2005 11:27 PM
looking for feedback on vf39 ecutek reflash Benjamin Tang Engine Management & Tuning 3 03-29-2005 05:31 PM
Tuning with Delta Dash on an Ecutek Reflash Tuned Factory 2.0L Turbo Powertrain 12 10-04-2004 08:43 PM
Anyone had an ECUTek reflash done at SoG? LiquidForce South East Region Forum 0 04-18-2004 06:56 PM
MBC on an STi Leo has WRX Engine Management & Tuning 4 01-29-2004 07:54 PM
