Old 01-15-2001, 10:52 PM   #1
Jim Gurieff
Member#: 389
Post Whiteline parts list for Impreza RS
Hi everyone.
Have just put together the first list of our part numbers suitable for the North American spec RS 2.5 Impreza.
BSF19 20mm Front Swaybar
BSF19X 22mm Front Swaybar
BSF19Z 18-22mm Adjustable front swaybar
BSR20 20mm Rear Swaybar
BSR20X 22mm Rear Swaybar
BSR20XZ 20-24mm Adjustable Rear Swaybar
KLC20A Front Heavy Duty Link Kit
KLC19 Rear Heavy Duty Link Kit
KSB551 Front Strut Brace
KCA319 Front Caster/Anti-lift Kit
KCA414 Rear Camber kit
KBR20-** Rear Heavy Duty D-bush Mount (** add size of swaybar)
83028 Front Super Low Coil Springs 1 to 2
83029 Rear Super Low Coil Springs 1 to 2
80066 Front Low Coil Springs 1 to 1
80067A Rear Low Coil Springs 1 to 1
Would appreciate any feedback from anyone disagreeing with the suitability of any of these part numbers as we'd like to finalise a fact sheet for this model.
Best regards.
Jim Gurieff
Whiteline.
Jim Gurieff is offline   Reply With Quote
Old 01-16-2001, 12:23 AM   #2
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Smile
Hi Jim,
Does your company make a rear strut tower brace for the RS as well as the front strut tower brace?
Thanks,
Aaron
AaronB is offline   Reply With Quote
Old 01-16-2001, 12:36 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Jim - Thought you had a rear sway bar that adjusted up to 27mm...
Old 01-16-2001, 04:57 AM   #4
ecfitzgerald
Member#: 1472
2001 2.5RS
BRP
Post
Jim,
I thought you also made a 18-22 Rear swaybar?
Ed
ecfitzgerald is offline   Reply With Quote
Old 01-16-2001, 06:20 AM   #5
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Post
Don't you have some Strut & Spring combo's for the RS/WRX too?
What suspension kits do you have/offer that will fit our cars?
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 01-16-2001, 02:29 PM   #6
Jim Gurieff
Member#: 389
Post
Thanks everyone for your response.
Some answers to the questions:
Strut tower braces - The front part number is listed above as KSB551. Rear upper is on the drawing board along with a rear lower.
Extra heavy duty rear bar - We do actually have a 22-27mm rated rear adjustable bar, part number BSR20XXZ but we are sensitive to promoting it as a road solution. It is listed on our Impreza fact sheet as "race only" due to the potential problems through innapropriate use. It is really too big for road use and requires a proportionately large front bar to avoid snap oversteer along with extra heavy duty mounts.
Good point re 18-22mm rear bar, part number is BSR20Z using a 20mm base material.
Suspension kits and combos - I guess part of the point of this post was to try to get closer to finalising the similarities and differences between the Aust. and US spec Impreza. We do not have a listing for the North American RS 2.5 in any of the shock catalogues we have access to so we are hesitant to assume that they are the same as our Impreza/WRX. There is a good chance that they are but we need to confirm prior to cataloguing a spring/strut/shock combo. Perhaps someone would like to trial some part numbers first to confirm.
Once we know what suits, we can put together a fact sheet specifically for the RS 2.5.
Cheers
Jim Gurieff
Whiteline.
Old 01-16-2001, 03:59 PM   #7
rosss
Member#: 1841
1999 Impreza RS
Thumbs up
The suspensions should be exactly the same. People import all sorts of japanese spec suspensions for use on the RS (CUSCO, SYMS, etc.) I can't imagine why the aussie stuff would be any different... The RS might be a tad heavier...?
The chassis are identical, except for some minor cosmetic differences, and some missing "cool" stuff, like aluminum control arms and such.
Bring on those kits!
Sean
rosss is offline   Reply With Quote
Old 01-16-2001, 07:40 PM   #8
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Post
Jim Gurieff
Send me one of your base kits, or ride height adjustable.. which ever you choose.. I'll pay shipping and then I'll tell you if it fits. Then you'll know.
Sound like a deal??
e-mail me if interested [email protected]
Old 01-16-2001, 09:31 PM   #9
Overtime
Member#: 1346
Post
I'm down with the guinea pig thing too. And if I like it, I'll start a groupbuy.
Overtime is offline   Reply With Quote
Old 01-16-2001, 11:29 PM   #10
Jim Gurieff
Member#: 389
Post
Thanks for the offer.
This is something normally handled by our dealers as we need to supervise the fitting process to ensure we accurately collect all the data we need.
We hope to be able to report something soon.
Cheers
Jim Gurieff
Whiteline
Spec sheet and parts list for 04 Spec C? Subaristi Newbies & FAQs 19 01-26-2007 04:27 AM
I need a complete part list for... 2000wrx Brakes, Steering & Suspension 2 09-01-2006 07:06 AM
Is there a detailed parts listing for the WRC cars? I seek the side mirrors... kaisersouse General Community 16 03-16-2006 09:54 PM
Subaru STi parts list for GC8's?? Tokay Normally Aspirated Powertrain 3 07-16-2002 06:38 PM
part list for my 00 wrx conversion shtboxracing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-29-2001 09:04 PM
