Old 07-27-2004, 09:53 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Name this Noise (Broken Engine)
Okay so my engine doesn't sound so healthy. I'm not sure what it is. A little back round on the engine. It's a DOHC 2.5 running a stock 2.5 Phase II block MY00 or newer. I had some problems with the valves in the past when I did a headgasket, but they were all eventually put into spec. Two months later when I put the new block in they were still to spec. Since the new block it's been about 12,000miles. I also did a compression check yesterday and all the cyclinders were 180-187. On first crank the pressure on all cyclinders was about 120.
Listen and enjoy.
Sounds of music
Joshua
yebokmj is offline   Reply With Quote
Old 07-27-2004, 11:54 AM   #2
Joncas
Member#: 5349
Have you checked the timing belt tensioner? I can't tell from the recording but it sounds like scraping and knocking. Check the inside of the front timing belt cover for scuffs/wear. Timing belt tensioners can make noises that scare you.
2cents.
Joncas is offline   Reply With Quote
Old 07-27-2004, 11:55 AM   #3
yebokmj
Member#: 2213
Brilliant Red
I'm going to open the cover today. I did put in a new tensioner when I did the new block though. I'll post and update.
Old 07-27-2004, 12:37 PM   #4
yebokmj
Member#: 2213
Brilliant Red
Here is a recording of last summer when my vavles were out of adjustment.
http://www-unix.oit.umass.edu/~jmkobey/Recording1.wav
Old 07-27-2004, 10:03 PM   #5
Unsung Boxer
Member#: 37196
*edit
v
Unsung Boxer is offline   Reply With Quote
Old 07-27-2004, 10:04 PM   #6
Unsung Boxer
Member#: 37196
yeah, the second one sounds characteristic of ticking valves. I can't tell what you got going on in the first one. It almost sounds like rod knock or something, or like the pistons are slapping around in there. Also, it sound uneven, as if its losing compression. I wonder if u blew a piston ring or something?
-Jake
Old 07-27-2004, 10:53 PM   #7
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Wow... that's a pretty scary sound. I'm going to go with something in the lower end, valvetrain noises are very even consistent sounds and not that scary. Do you have a boost gauge? is the needle fluctuating? How much blowby are you getting in your oil?
no-coast-punk is offline   Reply With Quote
Old 07-27-2004, 11:00 PM   #8
yebokmj
Member#: 2213
Brilliant Red
So I found out what it is or at least part of it. I took off my timing belt cover and it was filled with timing belt shavings. The timing belt was missing huge chunks. So I stared the engine with the belt off and I could see play in the water pump pulley. Once I took the belt off I was able to move the water pump pulley 1/4 of an inch up and down side to side. The strange part is that I haven't had any coolant loss or over heating. I am going to replace the pump and I think it will solve all my problems. I think my vavles also my have been out of adjustment slighty due to the timing belt being out of wack. I'm going to check the clearances of the shims while I have things apart.
Joshua
Old 07-28-2004, 11:02 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Check the toothed tensioner while you are in there... the bearings like to fail in them and make the timing belt skip teeth. I had this happen once... had to replace all 4 exhaust valves in the pass. head. :-/
Old 07-28-2004, 12:10 PM   #10
Rickyh
Member#: 40453
I was just about to say that sounds like a water pump gone bad. I had that happen on an old pontiac(not the same as a subie), but it made the same horrible scraping/grinding noises. It didn't overheat or anything.
Rickyh is offline   Reply With Quote
Old 07-28-2004, 03:05 PM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
water pump....change it fast
Old 07-28-2004, 07:45 PM   #12
yebokmj
Member#: 2213
Brilliant Red
How do I gauge if other pulleys should be replaced? I can wiggle some of them a little but how much is to much?
Joshua
Old 07-28-2004, 08:30 PM   #13
Aphex
Member#: 146
'16 WRX Limited
wiggle them and see if they move (with the timing belt off) and also spin them to make sure they spin smooth with no nasty noises or anything like that..... it's just bearings in there, so you're just making sure the bearing is still good.
Aphex is offline   Reply With Quote
Old 07-28-2004, 10:22 PM   #14
yebokmj
Member#: 2213
Brilliant Red
Yeah with the timing belt off the wiggle a tinny bit but spin smooth and don't make noise, so that means they are fine?
Joshua
PLEASE, name this noise imprezkid Transmission (AT/MT) & Driveline 10 08-27-2007 12:21 AM
Please name this broken part!!!!! scooby-stu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-25-2005 12:06 AM
This summer's Broken Engine noises yebokmj New England Impreza Club Forum -- NESIC 16 07-28-2004 08:15 AM
name this noise? (preignition?) yeti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-06-2002 01:41 AM
