Old 07-27-2004, 12:25 PM   #1
SupraScooby
Member#: 52123
05 WRB STi
04 AW STi GT30R [RIP]
Default Help! HU won't work after replacing battery!
my headunit won't light up or work since my car died and replaced the battery...any help would be appreciated...i checked the wiring to see if its hooked up correctly but anything further than that is out of my electronic knowledge...thx in advance!
SupraScooby is offline   Reply With Quote
Old 07-27-2004, 12:28 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
stock headunit or....what?
Old 07-27-2004, 12:31 PM   #3
SupraScooby
Member#: 52123
05 WRB STi
oh its a sony xplode
Old 07-27-2004, 01:32 PM   #4
Pallendo
Member#: 65831
91 Miata. Hey you
can f* short girls in one
Check the fuse on the HU. When you replaced the battery, you might have gotten a small arc when connecting the second battery cable. This might have blown the fuse to the HU. Also, some people are known to wire power for the HU directly off of the batt with small wires with inline fuse holders. When replaceing the batt, this wire might have been left off (If this was the used install method). Also this HU might be just dead.
Good luck!
-Peter
Pallendo is offline   Reply With Quote
Old 07-27-2004, 03:33 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Yep, check the fuses, the one on the head unit, and the one for the stereo/headunit/lights etc for the car. Most likely that is your problem.
fibuz is offline   Reply With Quote
Old 07-27-2004, 07:27 PM   #6
bemani
Member#: 5673
02 bug eye, 05 LGT
Check your battery?
bemani is offline   Reply With Quote
Old 07-28-2004, 03:57 PM   #7
Speedhabit
Member#: 64718
Maybe it Xploded.....Known to happen
Speedhabit is offline   Reply With Quote
Old 07-28-2004, 06:20 PM   #8
DreddRS25
Member#: 51642
2008 WRX
Did the same thing here and it was the "constant power" fuse that blew. Should be 30amp blue fuse.
DreddRS25 is offline   Reply With Quote
Pioneer D1 screen stopped working after mini battery went. perrin247 Interior & Exterior Modification 3 10-05-2009 05:21 PM
Driving lights won't work after body shop removed and painted bumper? PhilJensen Electrical & Lighting 1 09-01-2005 04:29 PM
HELP - Car won't start after turbo install Needles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 06-30-2005 08:23 PM
Cruise Control Won't Work After Bad Weather jikhead Electrical & Lighting 0 12-27-2004 05:30 PM
HELP! STi won't run after bad storm T3RMIN4L Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 07-26-2004 03:04 PM
