Old 11-28-2009, 01:46 AM   #226
LittleBlueGT
Member#: 96204
2013 STI GR
I am now abandoning the hybrid boost control.
Why:
I get extreme temp fluxes, and in only 40 degrees spread (F) I am seeing a 1.5 psi difference. If that holds true, I will be hitting anywhere from 19 psi at 100F and 24.25 psi at -40F!
Maybe it works well for you guys that don't have big temp swings, but not for me.
Anybody else notice this?
LittleBlueGT is offline   Reply With Quote
Old 11-28-2009, 09:28 AM   #227
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you need a better MBC if that's the case.
Old 11-28-2009, 12:18 PM   #228
LittleBlueGT
Member#: 96204
2013 STI GR
What temps have logged in?
Most of the MBCs really do look the same in terms of construction, I am not sure what the differences would be.
I have a new Perrin one BTW.
Old 11-28-2009, 12:43 PM   #229
LittleBlueGT
Member#: 96204
2013 STI GR
I know my MBC is not working properly for me. My Tial EWG leaks a small amount of air (this is normal I hear) through the bottom port, anything that restricts airflow makes the boost rise. That likely explains why the MBC on its lowest setting raised boost from 14.5 to 17.5 psi.
Old 11-28-2009, 01:30 PM   #230
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
How much variation with temperature do you see with your Hallman?
Old 11-28-2009, 06:34 PM   #231
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Our hallman has been pretty steady from 45-90 degrees F. Maybe 0.2 psi difference.
SurfWagon is offline   Reply With Quote
Old 11-28-2009, 08:23 PM   #232
02RexWI
Member#: 165141
I've got an update for you guys on the plugging of the bleed port of the GM BCS. While it is true that we were loosing air through the other port of the BCS when the MBC opened, it actually had an advantage: In the past I also plugged the bleed hole of the MBC, worrying about airflow being lost, as you guys may know, this hole is to bleed some pressure to the atmosphere so that the pressure that is holding open the wastegate can be released when you let off the gas if you were just using an MBC for boost control. So now that all the bleed ports have been blocked off from that system, the wastegate isn't opening until the MBC opens, which is good, except: when the wastegate opens, it opens ALL the way right away.The boost builds up to 20 psi rapidly and then the MBC opens and the boost drops down to about 15 psi, and now that all the bleed ports have been sealed off, the wastegate stays open because the pressure is trapped in there. The boost will then slowly build back up to ~ 20 psi. So to solve this problem I believe the best approach would be to run a bleed port that has a restrictor pill in it, or just ditch the MBC, but since I have an EWG setup coming I'm just going to pull the MBC off and run the 3 port system alone until then.
All of this messing around with the factory boost control system makes me wonder, why doesn't anyone make an aftermarket wastegate actuator for the VF series turbo's'? If someone did, they should make it easy to swap out springs, or at least have some sort of spring preload adjustment built into it.
02RexWI is offline   Reply With Quote
Old 11-28-2009, 08:52 PM   #233
02RexWI
Member#: 165141
^Nevermind, I guess they do sell aftermarket wastegate actuators for the VF series turbo's... That's probably the way i'd go, unless you are concerned with with running that much boost daily...
Old 11-28-2009, 09:55 PM   #234
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
Hey LB, Franz and I are using the Hallman with the cockpit adjuster cable/knob. It doesn't fluctuate very much with temps, maybe a bit higher when it's cold, but with the knob being adjustable from the driver seat it's a non-issue for us. If you'd like to try one PM me.
adeliciouspizza is offline   Reply With Quote
Old 11-28-2009, 10:18 PM   #235
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Yeah I have the hallman with the cockpit adjust cable , I never see big swings in boost, When it was droping down to 35 degrees (and I tuned in 75 80 degrees) I wasn't even seeing .5 psi higher... I think it was about .3 psi... Now my txs dual stage bcs did some wacky **** when I tried to do hybrid boost control with that....could just be the bcs...
TDagen is offline   Reply With Quote
Old 11-29-2009, 09:41 AM   #236
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
well, whatever temp swings you'd see in new england over a period of >5 years.
the material that the tension spring is made out of makes the biggest difference wrt repeatability at various operating temps. the quality of the seal of the ball on it's seat is also an area where it matters.
guys, i can't for the life of me understand why everyone seems overly concerned about this "loss of airflow." it's TINY.
if nothing is present for the system to bleed pressure from the WGA when the MBC is closed and the solenoid is energized, then it will not work properly: as soon as target boost is reached then boost will disappear (ie, the boost will "crowbar").
in my experience this bleed does not need to be large at all, nor should it be.
why don't you just add a helper spring? have you seen the price of an "upgrade" wga for a VF? no thanks, i'll keep my $5 home depot spring on there.
Old 11-29-2009, 05:47 PM   #237
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
because we're bored? ^^
yeah, we found this out the hard way lol.
agreed.
Old 03-02-2010, 05:48 PM   #238
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Is it really necessary to modify your wgdc to 100% at full throttle with this hybrid setup. I have the Grimmspeed EBC with a tial 44 ewg and I want to run the Hallman MBC just to prevent overboosting when I travel since I live at over 6000 feet . Whats the effects if you dont modify the wgdc table.
Murphdog is offline   Reply With Quote
Old 03-03-2010, 12:42 AM   #239
Kjott21
Member#: 116937
2011 WRX DGM
forums.pghsubarus.com
The reason that you make the WGDC 100% is to close the EBCS and push the air through the MBC instead. If you have less than 100% you will be using the EBCS to control the boost.
Kjott21 is offline   Reply With Quote
Old 03-03-2010, 12:53 AM   #240
Murphdog
Member#: 75414
2004 STi
Its the Blue one
If I didnt adjust the wgdc the car would function as if it only had an EBC, right? But the MBC would prevent it from ever going over a set psi. Thats all I'm really wanting the MBC for is to prevent over boost.
Old 03-03-2010, 12:59 AM   #241
Kjott21
Member#: 116937
2011 WRX DGM
The MBC won't prevent overboost if you set it up the way that this thread tells you too. To do that you would need to put the MBC inline with the EBCS, not in parallel. I don't know whether it would be best to put the MBC before or after the EBCS though.
Old 03-03-2010, 01:18 AM   #242
02RexWI
Member#: 165141
Thats not true, if you were to put the MBC in parallel with the 3 port BCS and set the MBC for whatever pressure you don't want to go over then it would work. Think about it this way: if you were spiking over 20 psi to 23 or whatever and didn't have a way to tune your 3 port BCS to solve the problem then you could just put the MBC in parallel with the BCS and set the MBC for 20 psi and the MBC would open up at 20 and open the wastegate thus preventing over-boosting. If you were going to do this setup I would recommend plugging the hole in the MBC, otherwise its may cause a problem with your 3 port BCS's partial throttle boost control.
Old 03-03-2010, 01:26 AM   #243
Murphdog
Member#: 75414
2004 STi
Its the Blue one
So how would I hook up my Grimmspeed ebc with a hallman mbc and my ewg. I found this diagram in this thread, what would I havee to change.
Old 03-03-2010, 01:48 AM   #244
NSFW
Member#: 140444
05 Stage Free LGT
You're mistaken.
Old 03-03-2010, 01:59 AM   #245
02RexWI
Member#: 165141
Without checking the port numbers on the 3 port MBC that looks correct. But like I said, i'd plug the hole in the MBC that bleeds pressure since you're running it like this.
Old 03-03-2010, 02:02 AM   #246
Murphdog
Member#: 75414
2004 STi
Its the Blue one
This is how GrimmSpeed tells you to run their EBC to an EWG. So does the diagram above still look correct?
Old 03-03-2010, 02:21 AM   #247
02RexWI
Member#: 165141
The way that is routed you'd definitely have to be tuned for specially. It is better to run it that way, because increasing pressure to the top of the diaphragm keeps the wastegate shut allowing you to build boost faster, but there is no way of running with an MBC in parallel in that configuration to stop boost spikes.
Old 03-03-2010, 02:32 AM   #248
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Yeah I'm tuned for the GS EBC. Looks like I'll need a retune to do the hybrid setup.
Old 03-03-2010, 05:06 AM   #249
Kjott21
Member#: 116937
2011 WRX DGM
Originally Posted by NSFW View Post
You're mistaken.
I guess I am confused. Setting up the boost controller and solenoid the way that ride5000 shows only directs the pressure signal through the MBC when the solenoid is at 100% duty cycle. How would that solve an overboost problem when the WGDC isn't set to 100%.
This is what I was answering:
In order to get rid of the overboost whether your are at partial WGDC you would have to put the MBC inline with the solenoid so that it worked regardless of the duty cycle on the solenoid. Right?
Old 03-03-2010, 05:51 AM   #250
MRF582
Member#: 48219
. Always drive
the race line .
Ken (the stupid one, not Gilbert), what did I tell you earlier? Google 'path of least resistance'. And let me repeat myself. PLEASE stop posting so damn confidently in technical threads.
MRF582 is offline   Reply With Quote
What kind of boost control solenoid/boost controller is this? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-01-2007 11:24 PM
If the pill is your primary method of birth control, learn from my mistake George71 Off-Topic 59 03-15-2005 01:00 PM
mbc/ebc and peak boost in lower gears? chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-02-2004 10:29 PM
Joe P. MBC XZ Turbo Manual Boost Controller (ebay no reserve) lstepnio Private 'For Sale' Classifieds 0 03-22-2004 07:43 PM
Need Help: An analysis of boost control methods smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-07-2002 04:12 PM
