Old 10-02-2011, 12:23 PM   #551
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Originally Posted by mistagreenthumb
Hey guys, I have a date booked to head over to my tuner in a few weeks.
I know I won't see the full potential until I'm tuned for it, but would it be bad for my motor if I stuck the MBC on before I get tuned? I'm already tuned for a 3 port, so I don't really see how it could be bad.... but better safe than sorry, so I figured I'd ask.
I'm not sure but just drive like a grandma 2 be safe. Better safe then sorry right??
07wrx84 is offline   Reply With Quote
Old 10-02-2011, 12:49 PM   #552
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Probably wouldn't matter too much besides adding a little more tubing and such for the pressure signal to fill so you might see some boost oscillation on the highway/high gear. You certainly won't see the benefit.
It's really so easy to install that I just say you have the t fittings and tubing ready and you and the installer can take the 5 min to splice it in at the shop.
It would be pretty hard to set the MBC when you just have a standard 3 port boost control map on there anyway. You'd never see enough wgdc for the MBC to take full control.
BrandonDrums is offline   Reply With Quote
Old 10-03-2011, 06:20 AM   #553
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
OK gona try this this week.
gaby is offline   Reply With Quote
Old 10-03-2011, 01:57 PM   #554
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by BrandonDrums View Post
Not too shabby! I might try that although, my WGA is only 9 psi so I'll run 0% where my target is 9 psi and below.
That's a pretty solid technique, I wish romraider had interpolate. I hate using ECU Flash for modifying maps except for that one feature.
Look at the wgdc table I posted last week, especially the column headers. I only set 3 columns by hand, and the ECU does the interpolation for me. You could just set two columns if you want, I doubt the difference would be noticeable. I was using 3 columns for EBCS-only tuning, and I plan to go back to that at some point, I kept them.
I share ride5000s view, FWIW. Fixing PTFB takes almost no extra work at all, like 5 minutes tops, so I see no reason not to. It's nowhere near as much work as regular EBCS tuning, you just need to ramp down WGDC at low throttle.
EDIT: Here's the table I was referring to:
Old 10-05-2011, 02:07 AM   #555
gaby
Member#: 94097
[email protected]
Wow it works. No more 0-450hp unless I want to.
Old 10-07-2011, 05:42 PM   #556
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Nice!
Anybody here have any pictures of their current set ups? We have been curious about different ways guys are doing this!
Will
GrimmSpeed is offline   Reply With Quote
Old 10-07-2011, 11:01 PM   #557
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Will[/quote]
I'll get some
Old 10-12-2011, 01:04 PM   #558
twonb1
Member#: 129163
2011 evo x
Phantom Black
Anybody have a how to on this
twonb1 is offline   Reply With Quote
Old 10-12-2011, 01:27 PM   #559
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
http://forums.nasioc.com/forums/showthread.php?t=602674
Old 10-12-2011, 01:40 PM   #560
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
That's a new one, someone asks for a how-to in the how-to thread itself. Forget the search bar just read...you're sitting on top of it.
Now someone tell me where I put my sunglasses. Oh yeah, I'm wearing them
Old 10-12-2011, 04:08 PM   #561
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
meh - forget what I said here too
Old 10-12-2011, 04:50 PM   #562
Phatron
Member#: 36033
CEO PhatBottiTuning
im gonna have to go try this again.....i dont remember it making a difference.
i dont think i drive like other people though. I dont think i ever just hold the throttle at anywhere between 40% and 95% throttle. if im cruising around its <40%....if i wanna go fast its 100%. plus my throttle mapping is aggressive so that 75% is 100% anyway....
Old 10-12-2011, 05:36 PM   #563
MRF582
Member#: 48219
. Always drive
the race line .
^ So you've effectively reduced the stroke of your accelerator pedal. I'm guessing you are mostly interested in straight line WOT? That's too bad. The steering wheel is fun to play with too.
MRF582 is offline   Reply With Quote
Old 10-12-2011, 07:20 PM   #564
Phatron
Member#: 36033
CEO PhatBottiTuning
I drive in twisties and dirt too....steering wheel gets plenty of use. Drag racing is my least favorite
If I can get third place in my class on a 1st n 2nd gear track with a dom4 vs vf'd cars who have a big low gear advantage...i'd say it's working for me
Old 10-18-2011, 03:28 PM   #565
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Anyone had problems setting up this system with EWG?
Old 10-18-2011, 03:36 PM   #566
NSFW
Member#: 140444
05 Stage Free LGT
No, it always works perfectly on the first try when you do it with an EWG.
Old 10-18-2011, 03:43 PM   #567
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Mine was behaving a bit weirdly, although I forget what it was doing wrong and I don't care to think it through again at this point in time. Regardless, I fixed it by capping the port on the solenoid that is normally either vented or recirculated back to the turbo inlet. Accordingly, I had to scale back the duty cycle a bunch(except for WOT) since the only point of release was through the small hole in the output fitting on the mbc. Now the system works exactly as it's supposed to.
573 is offline   Reply With Quote
Old 10-18-2011, 03:45 PM   #568
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Well i think my ewg is faulty then! My car was tuned to 21.5psi ran awesome! I finally found the leak and fixed it. So we tuned it again because the car was running rich, now the car will only hold wastegate pressure!
Its 07 wrx with aps 70mm cai, bigger tmic, 870cc injectors, e85, 38mm tial vband ewg, ported & polished exhaust manifold, tgv deletes, grimmspeed ebcs, turbosmart mbc, hks- hi power exhaust, 3" Bellmouth non cat DP...
Old 10-18-2011, 03:45 PM   #569
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Really??
Old 10-18-2011, 03:57 PM   #570
Phatron
Member#: 36033
CEO PhatBottiTuning
if you think its the ext wg, then simply unhook the ebcs and run mbc only.....this will tell you if its your ext wg or if you just had the ebcs plumbed wrong
Old 10-18-2011, 04:00 PM   #571
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
I did that and it still held wastegate then for kicks we used a brand new mbc and still did the same thing??? Im stumped lol
Old 10-18-2011, 06:22 PM   #572
xsnapshot
Member#: 170973
2004 WRX 4EAT
Just an update. I've been running the hybrid boost control system now for....around a year I think? It still performs great.
Just for reference its a dual wastegate/EBCS/MBC setup on a small 16G, where I see 10 psi spring pressure on the IWG (STI catback exhaust...stealthy) and 17 psi on the EWG. I had been running E85 at 20 psi on the EWG, but switched back to 91 @ 17 psi for the winter months.
xsnapshot is offline   Reply With Quote
Old 11-22-2011, 02:52 PM   #573
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
Originally Posted by Phatron View Post
yes. most of the tables are even named the same now since Bill moved over to cobb from opensource.
Now see that is awesome bravo merchgod/teacups/bill !!!!!
What is the current inexpensive alternative to the gm solenoid now a days?
dm
dwmoss_68 is online now   Reply With Quote
Old 11-22-2011, 03:00 PM   #574
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
dm
Probably the best bet is the Grimmspeed 3 port, it's better than the GM one anyway.
Old 11-22-2011, 04:35 PM   #575
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
It doesn't seem to fit the inexpensive part of the request.
One of the advantages of the gmbcs was it's price tag compared to the alternatives at that time.
dm
What kind of boost control solenoid/boost controller is this? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-01-2007 10:24 PM
If the pill is your primary method of birth control, learn from my mistake George71 Off-Topic 59 03-15-2005 12:00 PM
mbc/ebc and peak boost in lower gears? chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-02-2004 09:29 PM
Joe P. MBC XZ Turbo Manual Boost Controller (ebay no reserve) lstepnio Private 'For Sale' Classifieds 0 03-22-2004 06:43 PM
Need Help: An analysis of boost control methods smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-07-2002 03:12 PM
