Old 12-22-2011, 09:24 PM   #601
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Got it figured out. My tmic hose come off the turbo outlet lol.
07wrx84 is offline   Reply With Quote
Old 12-23-2011, 11:30 AM   #602
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Cool glad you got it figured out!
Mike
GrimmSpeed is offline   Reply With Quote
Old 12-23-2011, 11:42 AM   #603
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Mike
Ya so nice to have 23.5 pounds of BOOST lol.
Old 01-29-2012, 09:33 PM   #604
ScoobyNub
Member#: 269662
bringing this thread back . just wonder if medamullet ever tried this way.
ScoobyNub is offline   Reply With Quote
Old 02-07-2012, 10:04 AM   #605
quizno73
Member#: 299835
2002 wrx wagon
Midnight pearl blue
Default Grimmspeed wastegate compgate 40 (38mm)
just got in a Grimmspeed compgate 40 (38mm) and up-pipe. does anybody have a diagram how to hook it up to a GM boost selenoid ?
quizno73 is offline   Reply With Quote
Old 02-07-2012, 10:26 AM   #606
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
You might have to search this thread but I'm pretty sure there are a few diagrams for EWG's and another few diagrams using GM BCS's.
I believe that the hybrid hookup pattern for an EWG is the same as an internal gate actuator in respect to the MBC and EBCS, the only difference of the overall setup is where the hose from the output nipples of the MBC and EBCS go and the tune.
Just remember, you're running a manual boost controller and electronic 3 port controller in parallel. You're splitting the hose from the compressor outlet fitting/nipple and running it to both the input nipple on the MBC and on the EBCS. You're also merging the hoses coming from the output nipples of the MBC and EBCS to a single hose going to wherever the waste-gate actuator is.
BrandonDrums is offline   Reply With Quote
Old 03-13-2012, 08:57 PM   #607
chadb
Member#: 198179
2007 STI
UGM
How gain did u see on this. I did the grimmspeed one toady and notice a big difference
chadb is offline   Reply With Quote
Old 03-19-2012, 04:04 PM   #608
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Originally Posted by medamullet View Post
I made some improvements to my setup. I ran a 1 way valve at the end of my MBC so air doesn't come back up from the "T" and out the bleader hole on the MBC. I also want to run a stiffer spring in my EWG. no matter how you hook it up you are loosing the good quality of the EBC holding the wastegate shut, so a stiffer spring is in order. Mine opens at 14.7 psi no matter what, considering how you have to hook it up.
I'll bump my own setups. I actually have just gone back to MBC only. Much simpler design and really does everything I need it to. I also added a 22lb spring to my EWG, best way to control my boost (~27psi) boost is solid, simple, and spools quick.
This duel boost safety is not a good reason. Out of all the cars I have tuned. only seen 1 EBC failure. Which didn't work right out of the box and have had zero MBC failures. I have had both EBC and MBC not work so well but only the 1 hard failure. Drivability with the hybrid is great but you can learn to drive "normal" with even a MBC. My over all assessment is it's a waste of $100.00 if you ask me
medamullet is offline   Reply With Quote
Old 03-19-2012, 05:41 PM   #609
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Nice.
Old 03-19-2012, 11:36 PM   #610
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I don't think you really want that line that runs parallel to the MBC in the "thinking this is right" drawing. That line basically just circumvents the MBC, so it no longer plays any role in the system.
I don't know how you'd make an MBC work with a BCS and a dual-port actuator... I'm not saying there isn't a way, though. And I hope there is because I really like the hybrid setup and I want to try tuning with a dual-port actuator. I hope someone figures it out for me before Perrin releases their dual-port IWG actuator.
Old 03-20-2012, 05:53 AM   #611
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
certainly you didn't pay $100 for a GM solenoid...
Old 03-26-2012, 11:46 AM   #612
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I didn't end up even trying that picture. I just put in a 22lb spring in the wastegate and called it good spring pressure is 22 and peak boost is 27. Works pretty good for fast spool and stiff spring pressure.
and yes a boost controller is 100 to 105 with out tax or shipping....
Old 03-27-2012, 05:54 AM   #613
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
http://forums.nasioc.com/forums/show...1#post36727481
Old 03-27-2012, 11:22 AM   #614
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
People spend their money on diferent things I know for different amounts, I get that great. I posted in that other thread you linked me to. I used that solonoid back in 2006 and it's ****. The wire harness is complete garbage. Not worth the $60 savings to me. I tried to find some pictures to show you what I am talking about but can't be bothered. I don't really care that much.
Old 03-27-2012, 11:38 AM   #615
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you're free to use whatever parts you want on your car, and not every mod/solution works for everyone, but let's be clear: a hybrid setup was a waste of YOUR $100.
by contrast, MY $30 has been working with 100% reliability for 8 years.
Old 03-27-2012, 11:44 AM   #616
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
agree to disagree I guess. I used the $30.00 boost controller and spent hours trouble shooting and fixing it before I just threw it away. That was easily more than $100.00 in my labor wasted.
Old 03-27-2012, 01:01 PM   #617
02RexWI
Member#: 165141
My GM BCS has been working for 4+ years without a problem too.
02RexWI is offline   Reply With Quote
Old 03-27-2012, 02:26 PM   #618
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
most people think soldering is easy.
you can tell who those people are by the ****ty solder joints.
there's never enough time to do it right, but there's always enough time to do it again!
Old 03-27-2012, 02:34 PM   #619
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
It wasn't my solder joints where it would break. it was the actual wire where it went into the solenoid. The shielding didn't even go all the way in. You could move the wire back and forth and see exposed wires. The GS has a rubber grommet where the wires meet the solenoid that prevents this. It's just a poor design on their part. I believe I have seen some later models where the used a different wire harness to fix that issue.
I am far from a novice when it comes to any car skills.
Old 03-27-2012, 02:45 PM   #620
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
look.
i bought a $30 dollar part, soldered two wires to it, squirted some RTV sealant into the plug around those joints, and crimped two fully insulated quick connects to those two wires.
i then cut the plug off my oem bcs harness, crimped two mating quick connects to those two wires, smeared some dielectric grease on them, and plugged in the solenoid.
finally i bolted the gm solenoid to the car through an oem rubber bushing, pushed on the hoses and zip tied them....
... and haven't touched a single thing in 8 years.
now, you seemed to have an issue with the wiring to your solenoid. in my case, i pulled my wires from a scrap heap, made my own pigtail, and never had an issue.
you want to shrug it off and blame the solenoid, that's fine.
i know better.
Old 03-27-2012, 04:28 PM   #621
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
you sound awesome
I just plugged my gs in and tuned it.
Old 04-05-2012, 11:08 AM   #622
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Thanks medamullet! Plus, on the off chance that something ever does happen, we always have your back.
Mike
Old 04-24-2012, 02:11 PM   #623
caramall2
Member#: 213979
1) Is everyone tapering down their boost from, say, 5500 or 6000 on? That is, kicking the EBCS back in above these RPMs? I'm sure it depends on the turbo.
2) What happens on a smaller turbo if you don't taper down? Obviously it stops being able to produce the boost, but other than that, does it hurt anything? It might maintain the boost but be highly inefficient...I guess that would be bad (affect EGTs, etc.).
3) Last, does anyone have a map they can post (hex file, etc.)?
caramall2 is offline   Reply With Quote
Old 04-24-2012, 04:15 PM   #624
MRF582
Member#: 48219
. Always drive
the race line .
Mike
Ken, you have to understand, some people are either too lazy and/or incompetent to undertake simple tasks such as these. To each his/her own. I enjoyed saving the $100 and using an OEM part.
MRF582 is offline   Reply With Quote
Old 06-21-2012, 04:15 PM   #625
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
I have a new turbo - 18g-xt. Been dialing in closed loop fueling for a WHILE. Boost though, took me 5 min to dial in.
However, as per another post way back where a guy with a 10cm^2 22g wanted to improve spool used the OEM EBCS to bleed away pressure from the MBC in 1st and 2nd gears, I decided to play around with having the 3rd port in my 3port ebcs uncapped.
I get quicker spool for sure, but 1-3 psi of overboost for a second. No knock, just more torque and less accuracy with the MBC setting. Turbo dynamics comes into play to dial down boost during that spike then it's rock solid.
If I figure out a way to prevent the overshoot but achieve the higher boost in 1st and 2nd I'll post. I'm hitting 18psi in 2nd from a roll which is awesome. Could be the turbo though...
What kind of boost control solenoid/boost controller is this? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-01-2007 10:24 PM
If the pill is your primary method of birth control, learn from my mistake George71 Off-Topic 59 03-15-2005 12:00 PM
mbc/ebc and peak boost in lower gears? chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-02-2004 09:29 PM
Joe P. MBC XZ Turbo Manual Boost Controller (ebay no reserve) lstepnio Private 'For Sale' Classifieds 0 03-22-2004 06:43 PM
Need Help: An analysis of boost control methods smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-07-2002 03:12 PM
