Old 11-06-2007, 09:46 PM   #76
WeldingHank
Member#: 98645
2002 WRX Wagon
yep, they will work just the same.
WeldingHank is offline   Reply With Quote
Old 11-07-2007, 01:14 AM   #77
0deucedub
Member#: 148030
2002 PSM Bugeye
:-o
Man i just did this with my turbo xs boost controller and holly crap its smooth!!!
0deucedub is offline   Reply With Quote
Old 11-09-2007, 06:00 PM   #78
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
what about the wastegate iat comp table, seems like if I set my wgdc to 100% in the 100% tps column that it will still drop when I have low iat in the winter (like now) so wouldnt that cause the bcs to still pass air or no?
clemsonteg is offline   Reply With Quote
Old 11-09-2007, 11:07 PM   #79
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Has anyone had any problems with their boost levels being too high.
When I had this on my 16g, I didn't have any issues- now, with the 20g, I can't run any less than 22 psi with my MBC at its minimum setting.
Weird....
crazymikie is offline   Reply With Quote
Old 11-09-2007, 11:13 PM   #80
The Deliverator
Member#: 42376
2006 92x Aero
Weird....
This doesn't make sense to me.
If you use the just the EBC, does that work better?
I'm inclined to think it's boost creep.
The Deliverator is offline   Reply With Quote
Old 11-10-2007, 06:37 AM   #81
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
what's your wastegate boost, mikie? hose straight from compressor to actuator gives you what?
Old 11-10-2007, 08:36 AM   #82
crazymikie
Member#: 56321
Green
It was like 10-12 psi when I ran it straight from the wastegate.
It's definitely not creep- it hits 20-22psi and then just holds like a rock.
Old 11-10-2007, 12:07 PM   #83
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
any thoughts on the wgdc iat comp table when it comes to setting the 100% throttle column to 100% wgdc so that boost will be regulated by the mbc?
Old 11-10-2007, 09:32 PM   #84
WeldingHank
Member#: 98645
2002 WRX Wagon
i'd say set your 100% TPS boost targets to something slightly above what your MBC is set to. that way, the ECU is always trying to acheive target but can't.
Old 11-11-2007, 07:27 AM   #85
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes. set the target at 100% tps to something like 30psi, for example. the intention is to peg the electrical solenoid at 100% duty.
depending on the setup, getting close to 100% may be sufficient, but 100% is the only way to be certain it's JUST the mbc in the loop.
Old 11-11-2007, 09:51 AM   #86
clemsonteg
Member#: 134610
2003 WRX
SONIC YELLOW STG 4
Yeah thats what I figured, my only concern was that as of right now when I do datalogs I see a reduction in wgdc because of the temp outside. So I assumed that I would see the same thing when its set to 100% and the temp drops, so I thought maybe I should change some stuff around in the wgdc iat comp table. So if I set the target boost to 25 psi, but I am shooting for 22 psi with the mbc and I set the wgdc to 100% in the 100% column it will still hold if the wgdc comp table drops the wgdc to something like 97% or 94%?
Old 01-07-2008, 02:36 AM   #87
0deucedub
Member#: 148030
2002 PSM Bugeye
:-o
Ok so i just redid this mod but im back to the stock EBC and using the halman. I reflashed my stock ecu with a stage 2 map thats slightly tuned. But how would i tune it for this???
Old 01-07-2008, 06:36 AM   #88
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you just need to make sure that the boost control solenoid runs 100% duty cycle when at WOT, leaving the MBC as the only device in the loop.
Old 01-07-2008, 12:54 PM   #89
0deucedub
Member#: 148030
2002 PSM Bugeye
:-o
gotcha...do i set my MBC to hit target boost or just above it?
Old 01-07-2008, 01:34 PM   #90
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the mbc should be used to set your target boost, since nothing else will be limiting boost while at WOT.
Old 02-21-2008, 05:06 PM   #91
Suby Steve
Member#: 170322
04 wrx
ok so i gm bcs (in 2port operation) and a protune for 18.5 psi. if i were to do this setup would i see any improvement and would i have to get another tune? also a buddy of mine sold me a hallman for next to nothing. so i have all the parts at hand.
Suby Steve is offline   Reply With Quote
Old 02-21-2008, 11:19 PM   #92
WeldingHank
Member#: 98645
2002 WRX Wagon
you will need to run in 3-port mode and will require a complete retune.
Old 03-11-2008, 05:18 PM   #93
TrRex06
Member#: 170472
2006 WRX TR
Allright guys, I need some help. I installed the GM silinoid/Hallman MBC setup on my car about a week ago, and cannot seem to get it to work right. Its hooked up Compressor nipple to tee, one end of tee to MBC and other end of tee to BCS. (Yes I have tripple checked to make sure they are hooked to the corect ports on both the BCS and MBC) Port two on BCS runs to tee, one end to Wastegate, other to output port of MBC. port 3 on BCS (originally the one with small filter) runs bact to intake. Now with it hooked up in this manner and the stiff spring in the MBC cranked all the way down, and the BCS at 100% duty, I can still only make about 16lbs of boost, and I don't get it till about 5500rpm. To me it seems like the MBC is not holding pressure. Has anyone ever heard of a Hallman MBC failing? It seems unlikely do to the simplisity of the design, but I suppose it is possible. Sorry for the long winded post, but my question is, does anyone else know why, essentially, to much air is getting to the wastegate.
Relivent mods are UTEC, TD0518G with frontmount, no restrictor pill. (although tested with and without) TXS catless turboback exaust, and K & N intake.
TrRex06 is offline   Reply With Quote
Old 03-12-2008, 07:34 AM   #94
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
are you sure you're plugged into the normally open pneumatic port on the solenoid?
get a hemostat or a small pair of locking pliers and clamp off the feed to the solenoid completely to remove it from the equation entirely.
also, are you SURE you have a stiff spring in the hallman? mine came with a soft spring installed and i had to swap it out.
finally have you EVER made more than 16psi with this turbo? what is the wastegate tension set to?
Old 03-12-2008, 01:20 PM   #95
TrRex06
Member#: 170472
2006 WRX TR
Yes, tried taking the MBC out of the equation, and put lower numbers in my map and easily hit my targets, so the solenoid is working properly.
Did that as well, and only hit 10psi with just MBC.
Yes, tried both to be sure, but definatly have the stiff spring.
Yes, turbo has made over 20 (first test with restrictor still in place)
I talked to hallman yesterday, and they told me that sometimes the MBC can stick. I think that even though I cranked the knob with both hands till it stoped it was only about 6 turns from fully open with the heave spring, so today after work I am going to try a few drops of pneumatic oil in it and see if I can loosen it up and crank it down somemore. That is about the only thing left that I can think of. Thanks for the quick reply, and Props for comeing up with this setup.
Old 03-30-2008, 08:53 PM   #96
Joey_BagZ
Member#: 169493
so of all this hybrid talk, could you run a dual stage MBC in line with the stock BCS with a stock EM tune? let stage 1 of the MBC open so that it doesnt touch boost, and allows the BCS to do all the work and cure PTFB, then set stage 2 of the MBC to your max boost ( lets say 16 psi) take over once at WOT and the BCS is no longer in control. so it would be routed..... compressor nipple----> dual stage MBC------> stock t fitting----->BCS. the other end of the stock t fitting goes to the wastegate. hows this setup sound
Joey_BagZ is offline   Reply With Quote
Old 03-31-2008, 07:17 AM   #97
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you might have to partially disassemble the dual stage mbc so that you could ensure that the pressure signal is in no way obstructed from the WGA while the 1st stage was active, but otherwise i don't see a reason why it wouldn't work.
you could probably save money by just using a discreet solenoid (grainger/perrin/gm) and separate mbc though.
Old 04-15-2008, 10:18 PM   #98
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Ken, you are THE MAN. I just ordered a Hallman unit and can't wait to put it in.
Also, I'm interested in your thoughts as to what RPM that you think the EJ20x is starting to reach the point where exhaust gasses are better routed through the WG instead of the turbine with the TD04. Your reasoning is solid in that at some point the turbine becomes the flow limiting factor and excessive back pressure results with no manifold pressure gains. I just wonder what that point is.
Buck
bucket7788 is offline   Reply With Quote
Old 04-21-2008, 04:55 PM   #99
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
buck, i don't really know.
i know there is some point at which you get much diminishing returns, but i do not bother tapering boost. i played around with boost tapering when it was the "hot topic" around here like 4 years ago, but i tired of it. for the amount of time i actually spend at 6k rpms and up it is just not worth my trouble... ie, i've got everything i need for a very nice ADI rig but i have no time to install it! i'd rather spend my time elsewhere.
that said i know crazymikie has an ej207 and the last time he was on the dyno he picked up a little bit of power by reducing duty cycle/relaxing wastegate tension on the high end. this was ~7-8500 rpms and with a td06 w 8cm housing iirc.
Old 04-21-2008, 05:17 PM   #100
bucket7788
Member#: 124263
2004 WRX Wagon
Ok. I think that I'll experiment a bit. I installed the ceramic ball and spring Hallman MBC. It's the same one that you have minus the remote. I'm loving the rock solid boost.
Anyway, I guess I'll start out by keeping WGDC at 100% till redline, then comparing Vmaf at lesser WGDC to see what how they compare. If Vmaf actually goes up at lesser WGDC, I'll keep reducing it until Vmaf starts going down.
What kind of boost control solenoid/boost controller is this? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-01-2007 10:24 PM
If the pill is your primary method of birth control, learn from my mistake George71 Off-Topic 59 03-15-2005 12:00 PM
mbc/ebc and peak boost in lower gears? chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-02-2004 09:29 PM
Joe P. MBC XZ Turbo Manual Boost Controller (ebay no reserve) lstepnio Private 'For Sale' Classifieds 0 03-22-2004 06:43 PM
Need Help: An analysis of boost control methods smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-07-2002 03:12 PM
