Old 03-23-2009, 11:17 AM   #176
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
^^^ thanks man, comments appreciated
FleaDog is offline   Reply With Quote
Old 03-23-2009, 01:26 PM   #177
Rodwrx23
Member#: 170948
Originally Posted by eminehart View Post
A signal lock occurs that can cause pressure to build between the wastegate solenoid and the boost controller. It won't function properly. You will probably cause the wastegate to open prematurely and it won't behave reliably or consistently.
With a parallel setup this is less likely to be noticed. If you were not running this setup you will be running in circles trying to tune boost.
Good to know. I've tried running that port VTA, returned to the intake post MAF, and now blocked off and noticed no discernible difference.
Rodwrx23 is offline   Reply With Quote
Old 03-23-2009, 09:18 PM   #178
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
I would run it just like the normal Parallel setup. use the side nipple of the EWG in place of the wastegate actuator. Leave the top of the EWG VTA
^^^thanks
I picked up a grimmspeed ebcs in the GB, slick mounting bracket and clip to oem harness:
OK, so heres my crude diagram:
per the grimmspeed instructions (06-7 sti)
port#1 - routed back to intake (where factory BCS mounts) OR, no connection
port#2 - wastegate actuator arm or EWG bottom nipple
port#3- Boost source
Old 03-26-2009, 01:38 AM   #179
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
with the #1 port on the grimmspeed ebcs routed to the intake:
Old 04-11-2009, 12:07 AM   #180
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
This is incorrect
The grainger ports are marked differently than the Perrin but on the grainger
Port 1 is VTA or return to intake they work the same.(perrin port2)
Port 2 is for Wastegate (perrin port1)
Port 3 is for Charge side of turbo. (perrin port3)
The grainger is the same as the perrin so check these instructions for clarity
Perrin Boost Control solenoid PDF
You want the fast response setup. Slow response is bleed type like the Factory. I believe you may have set it up to be this way so you basically did nothing but mimic the factory BCS. The factory BCS doesn't work with this setup because of the bleed. Just change your connections around and you'll be fine.
PM me if you have any questions or want some WGDC tables to start with. Just let me know your Target boost and I can get you in the right direction.
saw this good postearlier eminheart re: grainger vs perrin
Old 04-11-2009, 01:26 AM   #181
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
Re-did my diagram, looks a bit cleaner, shows 3-port grimmspeed EBCS, hallman evo rx MBC better in their parallel configuration:
Old 04-24-2009, 09:43 PM   #182
HOLLYW00D
Member#: 44954
2004 FXT
is it possible to incorporate the top port of the EWG using this method? i currently have it set up like above (13psi spring) and it seems to crack open slightly before actually hitting 13psi.
how would one do so? would i just take a boost source, to a separate MBC, then to the top port of EWG and just bleed a little pressure off?
HOLLYW00D is offline   Reply With Quote
Old 04-28-2009, 09:23 PM   #183
sorrowfulkiller
Member#: 170439
I <3 Lamp
has anyone used this setup with an HKS EVC?
sorrowfulkiller is offline   Reply With Quote
Old 05-25-2009, 11:57 AM   #184
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
has anyone ever quantified the difference between ball and valve vs. bleeder in the hybrid system?
SurfWagon is offline   Reply With Quote
Old 05-26-2009, 01:09 PM   #185
eminehart
Member#: 11205
2015 WRX
Overall ball and spring is far superior to bleeder type MBC. Bleed type MBC are kind of like running one WGDC across the board. This why bleed type systems don't work too well. I doubt that you would see any advantage to a bleed type Boost controller in this system.
eminehart is offline   Reply With Quote
Old 05-26-2009, 01:59 PM   #186
Tgui
Member#: 44771
Here is a diagram I created some time ago. Its a derivation of the boost control described in this thread, but with an added boost bypass for meth failsafe.
Tgui is offline   Reply With Quote
Old 05-28-2009, 04:54 PM   #187
HOLLYW00D
Member#: 44954
2004 FXT
hey Tgui, it looks good! i wonder if the bbk-20 is necessary at all though. perhaps it's needed by the ifs-10?
my 3-port is routed through my dds3 (aquamist) controller. if the flow sensor gets too high/low, it's cuts signal to the 3-port which just goes open and i'm running wastegate boost.
Old 06-09-2009, 01:58 AM   #188
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
I tried this method tonight with a gm bcs and a turboxs dual stage bleed off style bc.... It did not work I first just set the turbos xs to 17 psi and then I hooked the two in parrallel or what ever ( same as ride5000 has his hooked up in the picture on the front) My f'in boost shot straight to 24 psi on my stock map sensor so probably higher...lol and the bcs was set to 17 psi just maybe 2 mins before that.... Wow anyone know anything I don't.... Do I need a ball and spring style bcs or whatever?
TDagen is offline   Reply With Quote
Old 06-09-2009, 02:55 AM   #189
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
It won't work with a bleed style BCS, has to be blocking.
blkscooby is offline   Reply With Quote
Old 06-09-2009, 07:18 PM   #190
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
It will not work at all? No how no way?
Old 06-09-2009, 07:52 PM   #191
JSarv
Member#: 163445
l33t *******
[email protected]
Just so absolutely everyone knows/does their own tuning - DO NOT clear your Turbo Dynamics tables - this will cause your WGDC to stick and do crazy things....
Otherwise 24psi by 3450 @90*F on a 2.0/18g/110k miles.
-Jerod
JSarv is offline   Reply With Quote
Old 06-09-2009, 08:39 PM   #192
blkscooby
Member#: 44422
2009 G8 GT
-Jerod
What do you mean "clear your TD tables?"
Old 06-09-2009, 08:45 PM   #193
JSarv
Member#: 163445
l33t *******
[email protected]
Turbo dynamics tables - IE use 0's in all levels of boost error... This will freeze WGDC or keep it from properly adjusting per throttle position/rpm..
-Jerod
Old 06-14-2009, 03:14 AM   #194
caramall2
Member#: 213979
Just trying to get this all straight in my head. Please see attached diagram. (Note I have a 2005 LGT.)
Questions:
1) Is my diagram the correct set up, including what is normally open and closed?
2) If you run the NC outlet back to the intake, it seems that you could almost never pressurize the MBC because you're bleeding off the air you need to pressurize it (since the system is in parallel). On the other hand, if you cap the NC outlet, while you're under the level of boost that would normally open the MBC, it seems like just changing WGDC won't have much effect because the air/pressure is basically trapped with nowhere to bleed off (trapped between the compressor nipple and the actuator), so the actuator remains pressurized even if the solenoid is cycling open and closed. Kind of like pressurizing a pipe with air, then openning and shutting a valve in the middle of the pipe...the pressure on both side just stays the same.
3) I've read on the stock solenoid, you're not supposed to run over 95% duty cycle. How do you get around this on a N.O. solenoid? At a certainly point (e.g. 100% throttle), you go to 100% WGDC (basically keeping the solenoid closed) so all air is routed through the MBC. Will this "burn out" the solenoid as it happens everytime you floor it?
caramall2 is offline   Reply With Quote
Old 06-14-2009, 08:50 AM   #195
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
my solenoid is often at 100%DC and i have never had an issue. i currently use the GM part but have also used the grainger under the same conditions.
as far as your diagram, remember that at rest, without any current, the system should be wastegate pressure, and the ecu energizes the circuit to raise boost. it seems like that is correct in your diagram.
i capped my NO port and have never seen any issues, but you have to test it yourself as all setups may be slightly different.
hth
ken
Old 06-16-2009, 10:45 AM   #196
Tgui
Member#: 44771
Its not needed really, but I like having a separate system I can easily remove. Which it is now until I get my UTEC 3D mapping my meth injection at some point. I'm disillusioned with meth injection right now, I need a more graceful implementation. Till then 93 all the way!
Old 08-09-2009, 01:19 AM   #197
69subaru360
Member#: 159682
1995 WRX
2015 F150
I'm trying to get my td06-20g 8cm ej205 to spool up faster and stay in boost coming off the lc at 5000-5500. Right now I am just running a hallman mbc. It controls boost fine and spool time is average. Sometimes it comes off lc and drops out of boost and bogs.
This is the configuration I am thinking about trying. I want to use the factory bcs to bleed off the boost signal before it hits the mbc. I would set the target boost to max, set the wgdc to 100% up until 4500 rpm then 0 after and set the td for negative boost error to 100% also. Then zero all the comp tables. Hopefully that would make the factory bcs just dump the boost signal to the mbc until 4500. The turbo spools around 3800-4000. The inspiration for this was that I recently got a big split in the hose leading from the compressor nipple to the mbc and it came off LC awesome until I had to lift when it overboosted.
Think it will work?
Old 08-11-2009, 09:51 PM   #198
69subaru360
Member#: 159682
1995 WRX
2015 F150
^^ This method worked perfectly. I now make 22 psi in first gear with my EJ205 with TD06 20G 8CM2. It comes off the LC and stays in boost!
Old 09-19-2009, 08:27 AM   #199
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I used that same setup tonight (HMBC+OEMBCS) to reduce the boost taper I was getting with an MBC alone. It worked pretty well. My WGDC table has 0% at 5500 RPM, ramping up to 85% at 7000 RPM, so it takes over when the MBC starts to fade.
Old 11-08-2009, 04:50 AM   #200
odin1
Member#: 29362
2008 2008 sti
stage 2
Ride--got a question. 2008 sti stage 2 accessport protuned. I love ptfb! If my cl-ol is zeroed out, is ptfb still harmful to engine? Also do most tuners zero this out when they tune? Lastly, can I use an mbc with an accessport? Thanks. odin
odin1 is offline   Reply With Quote
What kind of boost control solenoid/boost controller is this? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-01-2007 11:24 PM
If the pill is your primary method of birth control, learn from my mistake George71 Off-Topic 59 03-15-2005 01:00 PM
mbc/ebc and peak boost in lower gears? chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-02-2004 10:29 PM
Joe P. MBC XZ Turbo Manual Boost Controller (ebay no reserve) lstepnio Private 'For Sale' Classifieds 0 03-22-2004 07:43 PM
Need Help: An analysis of boost control methods smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-07-2002 04:12 PM
