Old 07-27-2004, 07:28 PM   #1
REX8
Member#: 24038
Default A Little Help Needed
Whats up guys...have a few quick questions...
Currently I have Infinity components up front and go between a single 10" in the trunk or a JL 6w0 under the passenger seat (when I need the trunk space). To make a long story short, I need my trunk back for good...and I need a little more sub. I've decided to add a second 6w0 under the driver seat after hearing a friend who has 2. I have a basic alpine 4 channel. My question is, when I go to dual 6w0's (which likes to get thier 75w), should I give each its own channel, or run the two in parrallel on a bridge channel? Is one better option than the other? They're 4 ohm speakers. FWI: College budget and I just need it to sound OK. Thanks
John
Old 07-27-2004, 09:40 PM   #2
02SilvaWagon
Member#: 33933
2011 WRX Limited
Since the 6w0's are 4 ohm you will have to run it so each sub is on its own channel. If you bridged the 2 channels and wired the subs in parellel you will be at a 2ohm load which won't work. You didn't say which Alpine amp you have, but I'm guessing its probably in the 40-60 watt per channel range. I'm not sure if that will be enough power for what you are trying to do. If you can find a place for another amp, you might want to consider picking up an Alpine MRP-M350 amp (350 watts at 2 ohms, retail $200). Then you could bi-amp your components or possibly bridge the amp and give your components more power.
02SilvaWagon is offline   Reply With Quote
Old 07-29-2004, 10:47 AM   #3
tad_02Wgn
Member#: 66426
you COULD wire them in stereo, OR you could bridge the amp, and wire the two drivers in series.
say your amp does 75x2 and doubles power into a bridged load (i.e. 300x1 @ 4 ohms, and [email protected]) like most amps do.
You could wire your 6W0's together in series and get an 8 ohm load, and then get 150w from your theoretical amp. Which is the same as getting 75 to each driver.
I'm not advocating one way or the other here - in fact I would wire them in stereo so you get some separation, especially since they are only 6" so they will probably play some midbass.
good luck.
tad_02Wgn is offline   Reply With Quote
Old 07-29-2004, 04:50 PM   #4
WingNut
Member#: 14951
GDA
first of all, what amp will you be powering them with?
WingNut is offline   Reply With Quote
Old 07-29-2004, 09:42 PM   #5
shadrool
Member#: 59775
09 forester
white
thats the real question we need. just because the speaker's are 4ohm doesnt mean, that they cannot handle a 2ohm load.
i would personally go with 2 8" subs. one under each seat. but if $$ is a issue which i presume it is. go with a 6.5 woofer in each door, and build a sealed enlcoser. stuff the hell out of the encloser with poly-fill and look to cross them over @ or around 40 cycles. stuffing the encloser will tighten up the excursion and make that speaker think? its in a larger encloser.
i had installed a single jl 6.5 woofer into a 04 dodge viper a few months back and powered it by an audison amp. crossed it over @ 45 cycles and stuff the stock encloser until i couldnt get anymore poly-fil in. WOW, thats all i have to say. i was very impressed.....
shadrool is offline   Reply With Quote
Old 07-29-2004, 11:00 PM   #6
fastsubie
Member#: 21999
2012 Wrx
FWIW you can double the rms power on those JL's without a care in the world. Just make sure it is a good amp and feed them clean power. I'm looking for a pair of 6w0's to do the same thing (under the seats). I had a pair of 10w0's getting 500w rms for 3 years and they still sound perfect,they are only rated for 125w rms.(gave them to my bro for his Ranger. JL builds good subs, they can take a beating and are underated by JL power handling wise. Can I ask you where you are getting your 6w0's?? I can't find them anywhere, I want them bad!.. I need my trunk back asap..
Thanks,
Fess
fastsubie is offline   Reply With Quote
Old 07-29-2004, 11:27 PM   #7
IwantONE
Member#: 11720
What kind of box did you guys make to fit these 6w0s in? I literally just measured under my seats and it doesn't look like there is a whole lot of room. Thanks.
Alex
I have a wagon, is there more or less the same amount of room as the sedan?
IwantONE is offline   Reply With Quote
Advice needed from the guys who know -- 07 STi Ltd TURBOvsV8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 03-10-2010 12:23 AM
from the guys who made all those movies that were one big penis joke WrxWonderWagon Off-Topic 3 02-08-2008 11:46 AM
Free $400 in Freeport, NY (zip 11520) - get it from the guy who scammed me mark2249 Off-Topic 19 06-20-2007 10:09 AM
From the guys who brought the juggernaut, bitch... WarHawk187 Off-Topic 1 06-11-2006 07:48 PM
A little help from the SD guys on Sat.? Longitude Southern California Impreza Club Forum -- SCIC 3 05-24-2002 02:21 PM
