Old 07-28-2004, 11:52 AM   #1
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
Default How accurate is the factory boost gauge compared to other gauges?
OK - BESIDES having to convert from mpa to psi, how accurate is the factory gauge? My top stock boost levels according to the gauge are right around .09 - maybe a little higher, so 13 psi if you convert it. Isn't stock supposed to be at least 13.5? I am wondering if the gauge is accurate.
Anybody compare the stocker w/ other gauges?
snvin is offline   Reply With Quote
Old 07-28-2004, 12:13 PM   #2
spacenut999
Member#: 40307
2004 WRX Sport Wagon
My stock gauge is off a little bit as compared with readings I get from my AP. I'm not sure which one is more accurate. I would assume the AP is since it's going off of information from the ECU, but that's just a guess.
spacenut999 is offline   Reply With Quote
Old 07-28-2004, 02:30 PM   #3
rockt104
Member#: 19111
^^^ same as what he said.
rockt104 is offline   Reply With Quote
Old 07-28-2004, 02:31 PM   #4
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
Was the factor one running higher or lower than the AP readings?
I have an AP on the way.
Old 07-28-2004, 03:46 PM   #5
spacenut999
Member#: 40307
For me the OEM gauge is reading slightly lower.
Old 07-28-2004, 04:10 PM   #6
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Me too...and it got worse the longer i had the gauge. The "zero" point got lower and lower.
Omori > OEM.
Pop the gauge out and put a 45mm omori in the pod.
mexicanpizza is offline   Reply With Quote
Old 07-28-2004, 04:12 PM   #7
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
Does it connect to the existing wires/etc...?
Old 07-28-2004, 04:44 PM   #8
xtrred
Member#: 23237
2002 wrx wagon - bye
07 yaris - 45mpg so far..
yep.
you can clip the wires and soldier,
plug in the hose and you're good to go.
Hardest part is getting that 45mm guage
into a 42mm housing. I think J-spec tuning's
web page has directions on the install....
xtrred is offline   Reply With Quote
Old 07-28-2004, 05:58 PM   #9
cnk
Member#: 10757
2013 BRZ Limited 6MT
My factory gauge is pretty accurate. This was the case with a Blitz SBC-iD, Blitz BLM boost gauge, and now my Greddy boost gauge. Also matches up with what I'm seeing on DD. There are some that aren't accurate though. You can tell when the engine is off, the needle won't point directly in the middle of the 0 hash mark.
Calvin
cnk is offline   Reply With Quote
Old 07-28-2004, 08:06 PM   #10
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
ok so who makes the most accurate boost guage??
Bishop is offline   Reply With Quote
Old 07-28-2004, 09:00 PM   #11
ej20wrxdex
Member#: 54776
2004 BLUE & GOLD
APV2 protuned
mines hangs low as well
ej20wrxdex is offline   Reply With Quote
Old 07-28-2004, 09:33 PM   #12
zavala
Member#: 44371
mine hangs almost one line lower than 0. i had to take this into consideration when setting my boost controller. when i've got $100 extra dollers i'm gonna buy a omori gauge
zavala is offline   Reply With Quote
Old 07-28-2004, 09:49 PM   #13
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
Installing the Omori into the Lamco pod looks like a real PITA.
Old 07-28-2004, 09:52 PM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i have been VERY happy with my autometer electrical boost gauge.
auto zeroes every time you start the car... readings match the utec logs very closely,and i use the peak recall function WAY more than i thought i would.
Old 07-28-2004, 10:00 PM   #15
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
This will be my setup once I have the money. Omori 46mm in the OEM pod.
MB38 is offline   Reply With Quote
Old 07-28-2004, 10:56 PM   #16
Bishop
Member#: 59993
Ass, grass or cash
thx
anyone else? who makes the most accurate boost guage?
Old 07-28-2004, 11:34 PM   #17
Davenow
Member#: 23676
My Greddy is DEAD ON and was a whopping 125 bucks shipped from WorldOne
Old 07-28-2004, 11:51 PM   #18
Rich10
Member#: 14934
Within the error of reading the small boost gauge, it seems as accurate as logs from my UTEC.
Rich10 is offline   Reply With Quote
Old 07-29-2004, 01:07 AM   #19
AlboWRX
Member#: 37719
2003 WRX
So,anybody has fitted the Omori gauge in the stock boot.
AlboWRX is offline   Reply With Quote
Old 07-29-2004, 07:04 AM   #20
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Also would like to find a gauge that reads psi to fit the factory steering column boot.
When I tested my OEM gauge:
.05 = 7.03psi(should be 7.25)
.07 = 9.87psi(10.15)
.08 = 11.28psi(11.60)
.09 = 12.82psi(13.05)
.10 = 14.35psi(14.50)
WRX03 is offline   Reply With Quote
Old 07-29-2004, 08:04 AM   #21
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
I thought that .10 was supposed to be 14 psi ?
And by the way, the only 45 mm gauge I've been able to find is the Omori. This would be a lot simpler if there was a 42 mm aftermarket gauge.
J-Spec Tuning does have the instructions on how to put the Omori in the factory column-mounted pod on the website. CirrusWRX is the one who first posted them. They might be on scoobymods also.
Like I said though, it looks like a real PITA.
Old 07-29-2004, 09:33 AM   #22
T Deneka
Member#: 50637
2002 WRX Wagon
WR Blue
1 bar = 14.50377 PSI
T Deneka is offline   Reply With Quote
Old 07-29-2004, 09:49 AM   #23
WRX03
Member#: 20744
05 Baja Regal Blue
I have found 43mm but not in psi.
Old 07-29-2004, 10:41 AM   #24
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
Yup. Thank you - I found a conversion calculator.
http://www.onlineconversion.com/pressure.htm
For everybody's reference, here are the calculations:
.1 mpa = 14.5 psi
.09 mpa = 13.05 psi
.08 mpa = 11.6 psi
.07 mpa = 10.15 psi
.06 mpa = 8.7 psi
.05 mpa = 7.25 psi
.04 mpa = 5.8 psi
.03 mpa = 4.35 psi
.02 mpa = 2.9 psi
.01 mpa = 1.45 psi
Old 07-29-2004, 11:30 AM   #25
WRX03
Member#: 20744
05 Baja Regal Blue
Thanks one on order. Doesn't look that bad - that a little water base silicone lube wouldn't take care of.
what is the factory boost gauge for STI suppose to be at hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-18-2005 07:34 AM
How big is the 04 WRX rotor compared to the 04 STi rotor? chopaholix Brakes, Steering & Suspension 2 06-17-2004 09:11 AM
How accurate is the factory boost gauge? DJDaizzy STi Forum Archive 3 07-14-2003 10:08 PM
How accurate is SBC-id boost gauge? Subi-fied Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-08-2003 11:03 PM
Is the factory boost gauge accurate? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-02-2002 11:04 AM
