Old 07-28-2004, 05:28 PM   #1
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
Default need tuning help
ok i got a full stage 4 vf30 turbo with perrin fmic
i currently have iridium spark plugs one step colder, and i was told to change to copper, but copper i jsut cant change my plugs every 5-10k..........
so what i am asking is is it optimal thing to use platnium one step colder? or shouldi use the copper? is there any diff between copper and platnium on the dyno? or in drivability?
thank you
and i did a search couldnt find anything
WRXout is offline   Reply With Quote
Old 07-29-2004, 10:26 AM   #2
hippy
Member#: 36528
2002 Impreza Wrx
What's wrong with the plugs you have?
Old 07-29-2004, 12:23 PM   #3
WRXout
Member#: 52908
ASPEN WHITE
iridium where not suggest for me with the mods i have
Old 07-29-2004, 12:54 PM   #4
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Did the teller tell you why? I'm running Irids with a heck of a lot more power than you have, on a much higher-revving engine, and it's just fine so far. Lots of people have run them. Unless you are actually having a problem, relax and don't do anything.
Sparkplugs do not, despite the splitfire claims, make power. As long as you are cleanly igniting the mixed gasses and are not too cold, too hot or suffering from blowout (all of which are fairly easy to spot with gauges and experience), don't mess with success.
That said, I would suspect, given the conductive properties, irids are going to work out better than platinums.
The book on plugs basically reads like this:
Copper - best spark, shortest life (by a factor of 5-10 vs. P or I), cheapest (by a factor of 4-6)
Platinum - worst spark, longest life (see Copper), expensive, do not use with nitrous.
Iridium - Similar spark properties to Copper, similar life properties to platinum, expensive, potential drawbacks allegedly include a thin element (easier to foul or blow out if mis-gapped). Denso IK plugs use a much thinner element than the NGK -EIX plugs, so they are more likely to suffer from the alleged drawbacks.
If you are having plug problems, check your tips and gaps before blindly buying another set of plugs.
-Sean
big_adventure is offline   Reply With Quote
Old 07-29-2004, 01:00 PM   #5
WRXout
Member#: 52908
ASPEN WHITE
clark a.k.a azscoobie said dont bring irdium most of the time they blow out on dyno runs
need tuning help ajaxlopez Bay Area Impreza Club Forum -- BAIC 4 11-15-2007 01:54 PM
Need Tuning Help 06blksubwrx South East Region Forum 10 12-03-2006 09:30 PM
I REALLY need tuning help Bird61780 Tri-State Area Forum 12 05-01-2005 09:41 PM
New to West Palm, need tuning help!! AK'S REX South East Region Forum 4 04-27-2005 04:29 PM
Need tuning help! Pochebum Southern California Impreza Club Forum -- SCIC 6 04-22-2004 08:22 PM
