Old 07-28-2004, 05:57 PM   #1
Works
Member#: 32339
02 WRX
325whp / 300wtq
Default Suggestions on what to do so i can get to turbotrix to get tuned...HELP
Hey guys i just put all my stuff in but i need to drive to this place on tuesday and was wondering what you guys think i should do so i can get there in one piece...I have a laptop so making changes is easy. Please Help me out so i can get this car tuned and have a big smile afterwords...
Utec
Forced Performance 18g
turboxs v2 tmic
walbro fuel pump
740cc modded injectors
perrin inlet hose
tial 35mm external wastegate
all 3 inch exhaust no cats
Gauges(egt,boost,oil pres)
rfl bov
Noah Hewitt
Works is offline   Reply With Quote
Old 07-28-2004, 06:00 PM   #2
D'sScooby
Member#: 41305
2003 WRX
Doesn't the UTEC have a base map? Run that? If not call TXS they'll be able to help you.
D'sScooby is offline   Reply With Quote
Old 07-28-2004, 06:10 PM   #3
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
In the UTEC ver4.2 open-loop fuelling paramters, there is a setting for larger injectors... this is referred to as your injector scaling. Set yours to 740cc and see if it starts and runs reasonably. Play with this number a bit until you get the smoothest starting. You can drive the car now but you should stay out of boost. You could raise the OLF TPS threshold (ECU-to-UTEC cross-over point) to 50% and that should make it drive reasonably, but once again stay out of boost as you will get high EGT as the ECU is trying to maintain stoich A/F ratio.
Blennophobic is offline   Reply With Quote
Old 07-28-2004, 06:31 PM   #4
Works
Member#: 32339
02 WRX
325whp / 300wtq
Default sweet
thanks guys yea i did that already just wanted to make sure it idles actually pretty nice so ill jsut stay out of boost and be fine then right guys??? By the way what do you guys think will I be happy after the tune any estimates on power
Noah
Old 07-28-2004, 06:41 PM   #5
Blennophobic
Member#: 25886
2003 WRX Rally Blue
I drove around for 2 months on the TXS stg4 base map with injector scaling set to 550cc. It bucked like hell on transition and ran pig-rich, but was safe.
Estimate of power is kinda moot cuz it depends on what kind of dyno you are getting tuned on... likely range is 270 - 300whp.
Old 07-28-2004, 07:51 PM   #6
Works
Member#: 32339
02 WRX
325whp / 300wtq
yea thats true guess ill see hopefully i will like it...what psi should i get done what is not safe for the stock motor
Old 07-30-2004, 09:29 AM   #7
Works
Member#: 32339
02 WRX
325whp / 300wtq
Default Question
So guys i put the stage 4 map and parameters on adn went into open loop fueling and changed to 740cc car actually doesnt idle that bad just when giving it gas at idle drops below 500 and then comes back up to stay around like 600 maybe 500...But anyways i jsut drove it around not going into boost like around 2g rpm i have like 950 egt and seeing 12.4 afr on the utec....Anything wrong with this or no...just getting ready to drive on tuesday just want to make sure im good
Noah
Thanks
By the way what psi should i get this tuned for...what the max i can do i want an aggresive tune but kind of safe ya know
Old 07-30-2004, 10:41 AM   #8
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Noah
Thanks
Like Blen said, stay out of boost and you have nothing to worry about until t-trix tunes it.
As for boost, with the TMIC you should be able to "safely" run 18-19psi or so on pump, and probably 22 or 23 on C16 if you go that route. However, every car is different, so ymmv...
-Sean
big_adventure is offline   Reply With Quote
Old 07-30-2004, 06:20 PM   #9
Works
Member#: 32339
02 WRX
325whp / 300wtq
Default thanks
Thanks guys i appreciate it... We will see how its ends up...can't wait for the drive home when im all tuned and ripping it...ha
Any suggestions on what we can do to improve our service/sales dept's?? Hondaslayer Mid West Subaru Owners Club Forum -- MWSOC 28 10-21-2005 07:18 PM
18g with modded stock injectors what to do so I can get it tuned Works Engine Management & Tuning 2 07-23-2004 12:40 PM
Visiting family in Missouri at the end of May. Any suggestions on what to do. STEALTH-WRX Mid West Subaru Owners Club Forum -- MWSOC 9 02-09-2004 04:37 PM
Any Suggestions on What Intake To Get? ejicon Legacy Forum 12 11-01-2001 04:36 PM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
Message Board Statistics All times are GMT -4. The time now is 03:00 PM.
