Old 07-28-2004, 07:10 PM   #1
Blennophobic
Member#: 25886
2003 WRX Rally Blue
- sold, waiting for 2015s
Default UTEC Knock Correction
I have the default values for knock correction parameters which is supposed to retard 2deg for every knock count I believe. When I see a 1-count knock event in the log the timing is pulled back 10 degrees... what's up with that?
Blennophobic is offline   Reply With Quote
Old 07-28-2004, 09:19 PM   #2
eightballrj
Member#: 18520
2005 L GT Limited
The utec logs are only samples of what the utec is doing every 1/5th of a second. The utec could have "heard" another detonation event and at a higher "count" so it retarded more and the logs just didnt pick it up.
eightballrj is offline   Reply With Quote
Old 07-28-2004, 11:21 PM   #3
TurboXS (Pete)
Member#: 16704
The UTEC retards 2 degrees for every crank cycle it detects knock until knock is no longer detected or it reaches the maximum retarded timing allowed.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 07-29-2004, 12:36 PM   #4
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Pete, in the US, we don't call it "retarded" timing - it's "exceptional" timing. Please be more sensitive to your less advanced sparkplugs.
-Sean
P.S. I'm really sorry about this - too much work this week...
big_adventure is offline   Reply With Quote
Old 07-29-2004, 07:54 PM   #5
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
just never try to explain ignition tuning to a special ed teacher.
MikeWRX-NJ is offline   Reply With Quote
How come I Can't see feedback knock correction, fine learning knock correction? AraSh Open Source Reflashes 23 01-08-2014 07:04 PM
fbkc, knock sum, knock correction advance, help kh15 Open Source Reflashes 7 06-05-2009 12:56 PM
Correlations between Knock Lite and negative knock correction xFactor Engine Management & Tuning 1 01-12-2006 07:36 PM
UTEC knock correction Big Turkey Engine Management & Tuning 30 05-15-2003 08:29 AM
Knock Correction and timing (long!) Ryan23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-28-2002 07:18 PM
