Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 07-28-2004, 08:27 PM   #1
red86aw11
Member#: 67210
1988 GL
maroon/red
Default 88 subaru GL crankshaft pulley bolt size
anybody know the size of the crankshaft pulley bolt? All I know is that it is bigger than 20 mm, cause that is the biggest socket that I have currently.
the car is an 88 front wheel drive FI 1.8L automatic 4 door sedan
Also anything I should know before attempting to remove it ?
thanks any info appreciated.
red86aw11 is offline   Reply With Quote
Old 07-28-2004, 11:39 PM   #2
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Its 22mm
Need to find a way to lock everything in place before turning it, or you will just turn the motor over.
Since its an auto, you can just jam a scrediver or something down into the flex plate/starter ring.
Calebz is offline   Reply With Quote
Old 07-29-2004, 12:32 AM   #3
red86aw11
Member#: 67210
1988 GL
maroon/red
thanks Calebz
going to buy socket and try later
Old 07-29-2004, 01:37 AM   #4
Calebz
Member#: 54398
1980 CB400 Hawk
Another thought
I believe 22mm is very close to 7/8.. seems I saw someone use that and they are more common in the average tool set
Old 07-29-2004, 01:38 AM   #5
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Since you have an automatic... yes its a 22mm, but look into the access hole to the flywheel/flexplate. Rotate the engine by hand with the socket looking for a hole in the flexplate... when you find it jam a big burly screwdriver down into it, you can now hold the engine from rotating and get the crank bolt off. (you may need alot of force to do it)
Flowmastered87GL is offline   Reply With Quote
Old 07-29-2004, 10:14 AM   #6
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
There's another way, too. My XT's clutch isn't much longer for this world, and since I'm such a big burly guy , that when I tried to loosen the bolt with the car in gear in 5th, I actually managed to make the clutch slip. So I put the wrench on the bolt, and put an extension on the ground on the right side of the engine. I cranked the key for maybe a quarter of a second, and BAM! the bolt came loose. You can do this with an AT or MT.
DerFahrer is offline   Reply With Quote
Old 07-29-2004, 10:52 AM   #7
Calebz
Member#: 54398
1980 CB400 Hawk
I am always hesitant to recommend that way.. never know when someone is going to do it wrong and put an eye out or something.
I figure thats one of the ways that some one should just kinda find out for themselves.
Old 07-29-2004, 08:10 PM   #8
red86aw11
Member#: 67210
1988 GL
maroon/red
I will try it tommorow when I get around to it
thanks for all the help guys
crankshaft pulley bolt install question kmook Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-17-2010 09:29 PM
ej25 Crankshaft/cam bolt size? 83Rabbit Normally Aspirated Powertrain 5 09-11-2005 10:10 PM
Crankshaft pulley bolt removal? Kayakertom 'Old School' Subaru Forum 5 02-07-2005 12:49 PM
88 subaru GL auto transmission cooler lines location red86aw11 'Old School' Subaru Forum 3 09-05-2004 02:07 AM
Broken crankshaft pulley bolt alent Normally Aspirated Powertrain 1 05-31-2004 09:27 PM
