Old 07-29-2004, 03:37 AM   #1
stisp33d
Member#: 45122
5xtra hp for sti in name!
Default after AVCR install running lean at full throttle
I've just installed an AVCR and left the boost setting a little over 1 bar (14.5 - 15psi) and adjusted the duty to hold the boost through out the RPM range
When I'm giving her full throttle, i noticed my air fuel gradually running lean from almost rich....
is this normal, or am I gonna risk detonation???
mods are:
Air Intake, Catback, Apexi AVC-R
stisp33d is offline   Reply With Quote
Old 07-29-2004, 11:19 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um wow.. of course it will do that espically at partial throttle
thats why people get a reflashes. they have the fuel and timing maps to match the increased boost
not saying an avcr isn't a good product just that the wrx/sti ecu is not set up to deal with the boost in stock form
and hopefully your not using the rear o2 sensor for any kind of valid information
running lean at idle stijames2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-05-2008 12:24 AM
running lean at idle, pig rich at WOT BrandonWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 10-22-2006 09:54 AM
Hear a chirping noise at full throttle afte EL header install? Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 09-19-2006 07:08 AM
wrx stalls at full throttle at high rpms bluesubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-23-2005 05:50 PM
Running Lean at full boost tdorlando Engine Management & Tuning 13 09-18-2004 04:38 PM
