Old 07-29-2004, 08:29 AM   #1
2000wrx
Member#: 66659
2000 L WRX'd
Default V7 vs V8 questions??
I am just wondering which is a "better" platform. I am not fully aware of all the changes between these two motors. I know the twinscroll on the V8.
My question is at what point does the twin scroll lose its advantage when upgrading to higher power levels?? Is there any kind of selection for upgradeing to higher power twinscroll turbos? Please forgive as I am quite green on theses motors.
How about the heads and cams, any differance between them??
FYI my plans are to swap out my swap (usdm wrx) and go to a JDM motor and 6mt. I want solid low 12 high 11 second straight line performance as a ref. My L weights in at 2780lbs with no weight lose as of yet.
Thanks,
2000wrx is offline   Reply With Quote
Old 07-29-2004, 09:42 AM   #2
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
1820F is the PE twinsscroll turbo.. so yes there is twinscroll upgrades.. just not many. There is some minor head differences in the two motors as well. This topic is discussed elsewhere to great lengths.
http://forums.nasioc.com/forums/showthread.php?t=595513
If you look in the conversions forum there is lots of info.
Subie2 is offline   Reply With Quote
Old 07-29-2004, 10:55 AM   #3
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
The pe1825 is a twinscroll upgrade the pe1820f is just a normal turbo. The head difference would be all V8 motors have the V7 RA spec C cams while normal V7 motors do not. I'd go with a V8's are a little more difficult to swap in and since I assume you already have your car wired up with the WRX motor a V7 is almost a direct swap save for the AVCS. If I had to do it over I would have gone with a V8 motor.
George
SonicYelloWRX is offline   Reply With Quote
Old 07-29-2004, 11:04 AM   #4
snvin
Member#: 50578
2014 Fiesta ST
-=meh=-
George
Do you say V8s are a little more difficult to swap because of the DBW?
snvin is offline   Reply With Quote
Old 07-29-2004, 03:33 PM   #5
2000wrx
Member#: 66659
2000 L WRX'd
Yea... what makes the V8 harder to swap...
Old 07-29-2004, 03:56 PM   #6
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
jdm v8 is not Drive by wire
ImprezaRSfan! is offline   Reply With Quote
Old 07-30-2004, 07:51 AM   #7
2000wrx
Member#: 66659
2000 L WRX'd
I didn't think it was, so what makes it a harder swap? Also is the twinscroll really worth the extra cost??
V7 vs V8 dyno chart mudbug Proven Power Bragging 36 02-11-2010 09:32 PM
V7 forged VS V8 cast? jdmej20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 05-30-2005 11:50 PM
V7 Sti Strut vs V8 STI struts -any diffrent? DickWRX Brakes, Steering & Suspension 3 02-08-2005 06:10 PM
JDM V7 vs V8 Suspension Dong9mong Brakes, Steering & Suspension 7 07-08-2004 12:47 PM
JDM V7 vs. V8, AVCS hookup questions dwx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-25-2003 03:26 PM
