Old 07-29-2004, 04:16 PM   #1
HubbieScooby
Member#: 7088
Super Slow
Default tap location for fuel pressure sensor
hey guys
i was just wondering where to put the probe for my fuel pressure gauge...i was told to tap the line right after the rising rate fuel pressure regulator...i was also wondering on what you guys used because my gauge didn't seem to come with a T or anything...looks like i would have to source something out from home depot...thanks
hugh
HubbieScooby is offline   Reply With Quote
Old 07-29-2004, 04:24 PM   #2
Aphex
Member#: 146
'16 WRX Limited
most people tap the line coming right out of the fuel filter before it goes to the fuel rails. Anywhere between there and the FPR should be fine. if you tap it after the FPR, then you'll be getting the pressure as the fuel is going back to the tank.... not much, and won't tell you anything.
Aphex is offline   Reply With Quote
Old 07-30-2004, 08:40 AM   #3
HubbieScooby
Member#: 7088
Super Slow
thanx...the confusing part is that my gauge is just a general pressure gauge from Apex'i....it saids it mainly for oil pressure but fuel pressure is optional....i was wondering what should i use to tap into the fuel line...perhaps i have to find a pre-threaded T somewhere?? cause the probe basically looks like a round tip with threads on it...
hugh
Old 07-30-2004, 11:40 AM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Here is my autometer setup
Old 07-30-2004, 11:48 AM   #5
IowaRS
Member#: 5385
2012 WRX Base
Ice Silver
Also, if you are going to put that gauge inside the vehicle.
It's highly recommended that you get an isolator:
http://store.summitracing.com/partde...23437%20303977
Yes, they are expensive, but the last time I checked it's not real fun to have 40+psi of fuel squirting around in the "cockpit"
EDIT: it sounds like you have an electronic sender, disregard isolator
IowaRS is offline   Reply With Quote
Old 07-30-2004, 12:10 PM   #6
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
^^^ What he said... It shouldn't take you more than 10 mins under the hood and may be 20 mins to make it look nice and wire it. Just get the barbwire NPT adapters from Pepboys, cut the line out of the filter, put the barbwire adapters inline, and you are pretty much done.
maxiav is offline   Reply With Quote
Old 07-30-2004, 01:36 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
u can make that isolator w/ better hose 300psi working higher temp for under 25 bucks
Old 07-30-2004, 09:14 PM   #8
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
Barbwire, eh? Don't you mean hose barb? And yes, that is the easiest place to hook up a fuel pressure gauge.
-Charlie
phattyduck is offline   Reply With Quote
Old 08-05-2004, 06:21 AM   #9
HubbieScooby
Member#: 7088
Super Slow
thanks for your help everyone!!
hugh
WTB: Fuel Pressure Sensor for 2.0L WRX subydude02 Private 'Wanted' Classifieds 10 02-12-2010 04:45 PM
best location for fuel pressure sensor subypal Newbies & FAQs 3 02-08-2010 02:08 PM
WTB: Fuel pressure sensor adaptor for defi gauge. WRX_Aruba Private 'Wanted' Classifieds 2 01-06-2009 07:11 PM
Source for Fuel Pressure Sensor Aus_RS Normally Aspirated with bolt-on Forced Induction Powertrain 3 03-23-2004 11:34 PM
Location of fuel pressure sender Sparks Newbies & FAQs 4 04-05-2002 06:55 AM
