Old 07-29-2004, 06:58 PM   #1
mitchwrx
Member#: 59070
Default 111 leaded add timing remove fuel? Ecutek
On race gas how do I adjust for performance? Ecutek is what I'm using.
It's been a while since I ran the 111 and when I do next week I want to make sure I'm not being stupid.
I remember the tuner adding 5 degrees of ignition timing and something about fuel scaling (I think it was lowering it). Am I on the right track here? Any advice will be greatly appreciated.
mitchwrx is offline   Reply With Quote
Old 07-30-2004, 04:11 AM   #2
WRX Harvey
Member#: 13025
1998 RS-T
Rally Blue
Get a wideband! Do you have a catalytic convertor in the exhaust? If so, you may not want to run lead. Also, the lead will shorten the life of your 02 sensors. With a wideband and 110 octane you can tune for 12 to 1 AFR ratio. Tuning without a wideband is suicidal for your engine. You may choose to spend 300 on a wideband or 2000+ on a new motor. You could probably use a deltadash and give your ignition learning 105% on the User Tune function for added timing(if you have the ECUtek reflash). Log and check for knock or low or negative knock correction.
WRX Harvey is offline   Reply With Quote
Old 09-14-2004, 09:09 PM   #3
jaypine
Member#: 50398
2003 WRX Wagon
How much will leaded gas shorten the life of O2 sensors? How much do O2 sensors cost? Is it alright to mix leaded with unleaded?
jaypine is offline   Reply With Quote
Old 09-14-2004, 09:28 PM   #4
wrxdaddy
Member#: 14164
02 Impreza Wgn
95 L Project in progress
On race gas, increase overall ignition adjustment and decrease open loop fueling adjustment in Live Tuning Adjustment window of your DeltaDash. And yes, you still need a wideband to be safe. You will find more info in the Ecutek forum.
wrxdaddy is offline   Reply With Quote
Hyundai Takes the Lead as the Most Fuel-Efficient Automaker in America AVANTI R5 Non-Subaru News & Rumors 6 12-02-2009 10:22 AM
Vinyl adds HP and fuel economy Robson Texas Impreza Club Forum -- TXIC 44 03-01-2006 11:02 AM
Redskins don't blow a 4th quarter lead this time!! richy_21 Mid Atlantic Impreza Club -- MAIC 25 12-06-2005 12:49 AM
should i add utec to my ecutek for nitous or aquamist sr55stiguy Engine Management & Tuning 0 11-21-2005 12:32 PM
Removing fuel tank & Fuel cell foam dbrown Technical Forum Archive 3 08-13-2000 08:16 AM
