Old 01-23-2001, 12:18 AM   #1
Saw Jai
Member#: 716
MY00 Impreza 2.5RS
Blue Ridge Pearl
Post Kumho 225/45/16 fit on GC/AGX
This post is my report on how the Kumhos fit on a lowered car and I will not go into how well they stick since thats been covered many times...
I just got Kumho 712's (225/46/16) mounted on my stock rims. I'm running the Ground Control with AGXs at about 1" lowered. No rubbing so far, took some corners really hard to test the tires and didn't get any rubbing. The place scared me the most is the inside of the tire. Right now I suspect there's about 2 credit card worth of space between the tire and the strut body. The spring perches are of no problem because of the reduced diameter of the tire. The tires seem like they might rub against the fender under some extreme loads but I think removing the rubber protector off the fender might fix that. If not then a slight rolling of the fender should.
There's an autocross this Saturday and I will post about it if I experience any rubbing then...
Saw Jai is offline   Reply With Quote
Old 01-23-2001, 12:20 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
Keep us posted. I am thinking of doing the same thing!
Eric
Eric SS is offline   Reply With Quote
Old 01-28-2001, 10:03 PM   #3
Saw Jai
Member#: 716
MY00 Impreza 2.5RS
Blue Ridge Pearl
Post
Just like to report that even after today's autocross...there is still no rubbing...=P
Old 01-28-2001, 10:39 PM   #4
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
Wow, that 5% makes quite a difference. My 225/50-16 V700 do rub in the rear (I have a similar setup in the suspension as well AGX/GC lowered an inch or so, but probably a different spring rate) and are auful close to the spring perch on the rear struts. So close that there are marks on the perch from the pebbles that the tires picked up.
Strepto is offline   Reply With Quote
do 225 45/17s fit on a 17x7 rim? topgrinder Tire & Wheel 5 10-11-2004 05:38 AM
17x7.5 torques w/225/45/17s fit on WRX wagon? linkbeat Tire & Wheel 2 08-31-2004 02:16 AM
215/45/16 fit on stock WRX Wagon wheel? 5-speedfreak Tire & Wheel 7 03-07-2004 04:54 AM
225/50/16 fit on stock rim? bluestone Tire & Wheel 10 01-09-2004 07:30 AM
Kumho 225/45ZR/16 are on! RallyGuy2k Brakes, Steering & Suspension 10 12-30-2000 07:46 PM
