![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 1838
NWIC
Vehicle:2000 Impreza RS BRP Vishnu Turbo/Tec3 |
I have the Whiteline antilift/caster kit KCA319 for Subaru Impreza. I also am installing the Aluminum control arm that is in the attached picture.
I see in the installation instructions it says: "Note: STi use forged control arms and have a remountable flange face washer that must be retained. Using STi arms on other models is possible only if face washer is used." I don't know if the control arms I have are STi or not, but they are aluminum forged. There is no remountable (whatever that means, removable? ) face washer. Do I need this washer with the arms in the picture? If so, where can I get this washer? what does this washer look like. If I need the washer, I need it in a hurry. Thanks, Dave
#2 |
Member#: 296
Hi there,
I run the arms with ALK.. ![]() I dont know of any aftermarket alloy arms.. so I'll assume they are STI items. The re-usable face washer is just a big fookin washer that goes over the back bolt that goes into the ALK mount. You dont have any other parts than just the arms ? Looks like you are missing it then ![]() J. |
#3 |
Member#: 64
Vehicle:1999 Impreza 2.5RS Rally Blue Pearl |
Jay, is the washer anything special? I mean, will a quality AN washer of appropriate dimensions work for this purpose?
#4 |
Member#: 1838
NWIC
Here is a picture of the washer I am missing. (thanks to Jim Gurieff @ Whiteline AU)
If this is just a flat washer I can just go buy a washer and alter the diameter. Anyone have the dimensions? |
#5 |
Member#: 716
Vehicle:MY00 Impreza 2.5RS Blue Ridge Pearl |
If thats a picture of the ALK then that yellow thing you're pointing to is not the washer...its the urethane bushing...the washer is hidden between the bushing and the arm...and its huge...
#6 |
Member#: 2808
He obviously knows what he needs, and it's the washer, not the damn bushing. Did you even read the whole thread? Give the guy some credit!
[This message has been edited by Bottom Feeder (edited December 22, 2000).] |
#7 |
Member#: 1838
NWIC
No problem guys, I just got thru fabricating the two washers 60mm O.D. forget the I.D. $1 of materials.
Oh by the way, Saw Jai, I think you should make an apointment with the eye doctor to crank up the prescription. The washer is not hidden just the same color as the arm. |
| Thread Tools | |
| Display Modes | |
| sedan alum control arm with wagon struts on wagon | chimchimm5 | Brakes, Steering & Suspension | 2 | 01-11-2010 02:42 PM |
| Help:Question about the sti lower control arm and whiteline roll center | lemon19mmm | Brakes, Steering & Suspension | 1 | 09-04-2009 02:27 PM |
| wtb alum control arms & whiteline roll center kit | SubeSTIle | SWIC Private Classifieds | 5 | 06-21-2009 11:33 PM |
| FS: SC 05 sti alum control arms and 05 shocks springs top hats | mesa50w | Suspension/Brakes/Handling | 3 | 04-10-2009 12:47 PM |
| Difference between spec C and GD alum. control arms? | solbey11 | Brakes, Steering & Suspension | 5 | 11-12-2005 12:02 AM |
