Old 07-29-2004, 10:33 PM   #1
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
Default HELP: High beams won't work with Sti Headlights '02
i got sti headlights for my 2002 wrx. i am using an HID kit. so this is what i did. connected the postiive from the ballasts to the stock harnesses and grounded the negative directly to the battery. so to wire the high beam bulbs on the new headlights, i connected the negative to the ground slot on the stock harness and the positive to the 3rd and only slot left. i cannot get the high beams to come on.
now when i connect the positive on the high beams to the positive that the HIDs are using, my high beams work, but they are on with my lowbeams as well but only half as bright. i don't think the high beam bulbs are supposed to be lit at all with the low beams correct?
what did i do wrong?
btw, high beam indicator is bright and glowing all thet ime so it is an electrical issue dealing with the voltage.
dennis
datdudedennis is offline   Reply With Quote
Old 07-29-2004, 11:20 PM   #2
DeBlueSoobaru
Member#: 60683
04 Wrx
Engine Management & Tuning .......
DeBlueSoobaru is offline   Reply With Quote
Old 07-30-2004, 01:09 AM   #3
salem
Member#: 56143
Fit is Go
You posted in the wrong forum. You'll probably get more answers in the Electrical & Lighting forum.
salem is offline   Reply With Quote
Old 07-30-2004, 01:21 AM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
you need to understand that the WRX lighting system is wacky in that it's a switched ground setup.
Meaning: of the three pins inside the factory 9007 plug, two of them are grounds (low beam ground and high beam ground) and the middle pin is +12V.
So, basically you are trying to wire a ground to a ground or a +12 to a +12 and getting nothing.
Are you trying to put the HIDs on lowbeams or on highbeams? You would have FAR better luck and FAR better actual performance if you wire them like this:
In this setup, simply replace the lowbeams with the HID kit and then, when you have the lowbeams selected, the HID lows are on and when you have highbeams selected, both the HID AND the highbeams are on.
I have seen and tried the wiring diagram that somebody posted on scoobymods.com for the UK300 lights and it just plain is a piece of crap. This diagram is much simpler, much more electrically sound, and less susceptible to circuit gremlins.
nhluhr is offline   Reply With Quote
Old 07-30-2004, 05:38 AM   #5
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
thanx nhlur, i put the positives on the high beam bulbs to the 15A headlamp fuse b/c when i connected it stragiht ot the battery, the highb eam indicator remained on even with the car off. grounded the grounds to one of the ones on the harness, works goodn ow. thanx a lot!
04 Sti - (hid) left light low beam won't work lowridnwrx Electrical & Lighting 4 03-17-2010 07:26 AM
high beam won't turn off!! Gordata Electrical & Lighting 0 08-20-2006 10:25 PM
low beam out, but high beam still works? pogomonkey Electrical & Lighting 2 12-08-2004 02:13 AM
High beam won't stay on w/ my Morettes Soya Electrical & Lighting 6 09-04-2003 12:23 PM
Really need to get high beams to work with fogs DEVO Interior & Exterior Modification 5 01-30-2001 07:25 PM
