#1 |
Member#: 40337
BAIC
Vehicle:95 L Coupe Swapped 99 Outback |
***Edit*** I have since painted the whole intake (to hide the jb weld). Aswell as, replaced the rag with somthing more suitable.
A few people have asked me what my CAI looks like, so here are a few pics of what I started with, to where I'm at now. First is a pic of what I’m using now, 3 inch pipe and a modifiedy stock air box. It’s very loud, and is a HUGE improvement over stock. Forgive me for the rag, is for stopping rattles until I find the right piece of foam. ![]() Here is my first version, its 2.5 inch pipe with a rubber peice, that attatches to the stock air box. PM me if you want to take this off my hands. Stock - Version1 - Version2 ![]() ***Updated pic*** ![]() More pics to come.
#2 |
Member#: 51642
TXIC
Vehicle:2001 Impreza RS BRP |
I'll be the first to say 'Nice DIY CAI'
I built a 2" intake tube with a similar design, but didn't like the change over the stock setup. So I eventually got the Ganzflow and its great. However, a 3" intake is always worth the R&D. What did you notice different from stock? Sound, throttle, mileage... |
#3 |
Member#: 1134
Vehicle:2007 BMW 328xi wagon Silver |
Instead of the rag, maybe you could consider something like the rubber piece that PDM-Racing uses for their CAI (www.pdm-racing.com). I have one of their intakes, and it's just a piece of blue rubber sheathing, split down the middle, that you wrap the fender hole with.
=S2= |
#4 |
Member#: 51282
Vehicle:98 RS black & blue from parking |
Nice rag... I've still got a coke bottle box blocking my snorkus hole! |
#5 | |
Member#: 40337
BAIC
I bet 2 inch was is too small, stock is 2.5. The sound is sweet, very loud at WOT. Idle is louder than stock by a hair, crusing is a lil louder too. Here is a pic of how the fender had to be opened up a few cm. I need to find gromets to cover the holes the masking tape is covering...lol ![]() This is a picture of how I slighly rerouted the crusie control cable for a little more clreance for the intake. ![]() ![]() Photo bucket made these last pics kinda nasty...sorry. Last edited by RS_to_WRX_swap; 12-20-2004 at 02:06 AM. |
#6 |
Member#: 40337
BAIC
more pics now ^
edit; I forgot to mention that i have a K&N drop in filer too. Last edited by RS_to_WRX_swap; 07-31-2004 at 05:08 PM. |
#7 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
u can also use fuel/vacuum/whatever hose instead of that cloth
#8 |
Member#: 40337
BAIC
That just gave me an idea...
#9 |
Member#: 3102
NESIC
Vehicle:2012 Sport Limited Ice Silver |
I took this idea and simplied it, instead of cutting up the airbox, I put a 2.75" silicone sleeve over the stock 90 degree bend and then used a 3" 45 degree ABS plastic elbow, 3" ABS straight pipe and a 3" sleeve over the elbow and 2.75 silicone sleeve. It's a tight seal, not as loud as my other intake and with a K&N panel filter it can only get better.
#10 |
Member#: 67180
Vehicle:1996 OBS(GFC) 94 Mitsu Diamante LS |
What are the chances of a puddle splashing into your hose from the fender.
#11 |
Member#: 3102
NESIC
Well, its not like Hoover suction in there so the car could be submerged to the point of the pipe inlet and it would still take a few minutes of WOT to pull any water in.
#12 | |
Member#: 51642
TXIC
Recently here in Texas we had some crazy rainstorms that caused flooding around most of town. The water that was shallow enough for me to drive through was enough to spray water up very well into the fender. I never had a problem and others on this board have had the same experiences. If your car is sitting in a deep puddle and you WOT, it would give you the best chance of water ingestion. If your cruising along and hit a puddle (generally we all slow down for puddles), then you'll have no problems. This is coming from a RS owner with a 2" drop. |
#13 |
Member#: 51282
Looks good Bry.
#14 | |
Member#: 40337
BAIC
BrysImpreza - Your intake is just like my first version. But yours looks cleaner. The only bottle neck in your intake is the bend on the air box. But you can always fix that later.
#15 | |
Member#: 40337
BAIC
You must have never put your hand infont of the intake and opened the TB. Motors move so much air they make Hoover vacumes look like kazoos. IF the intake is submerged it will only take a few seconds @ WOT before hydro lock sets in. I guess I should take new pics, now that it looks less ghetto with out the rag. |
#16 |
Member#: 44615
BAIC
Vehicle:2002 WRX Wagon 1st Guru Point EvAr! |
Do you have to create any openings into the fenderwell for these intakes, or is there enough air going into it already that it gets enough of it?
#17 | |
Member#: 40337
BAIC
![]() I also cut a hole in the under side of the car (plastic). Last edited by RS_to_WRX_swap; 12-20-2004 at 02:11 AM. |
#18 | |
Member#: 51642
TXIC
Edit: In relation to the first picture posted by RS-WRX-Swap |
#19 |
Member#: 33901
Vehicle:04 04 STI No AWD, Not interested |
Sweet DIY"S. I have the Ganz CAI and because I got it used, the plastic segment for the fender well was missing. I used(1) of the plastic housing that covers the spark plug wires to line the hole and place the intake there with no problems.
#20 |
Member#: 40337
BAIC
Updated pics!
As you can see its now painted, and has a rubber gromet in the fender. ![]() ![]() All washed and waxed up. |
#21 |
Member#: 45273
Vehicle:2002 Impreza 2.5 RS Aspen White |
I have the 3 piece silicon reducers from COBB CAI (new) offer me a price and it's yours.
#22 | |
Member#: 44887
NESIC
Vehicle:00 GC6 Silver |
#23 | |
Member#: 40337
BAIC
| Thread Tools | |
| Display Modes | |
| My DIY intake silencer / snorkus delete (part 2) | Punk In Drublic | Interior & Exterior Modification | 4 | 03-27-2010 10:41 PM |
| an update regarding my DIY intake for 05RS | silver-RS | Normally Aspirated Powertrain | 28 | 07-31-2006 11:25 AM |
| My DIY Intake pics (long) | Reciprocity | Normally Aspirated Powertrain | 23 | 01-17-2001 07:55 AM |
| Some pictures of re-badging and DIY intake | Reciprocity | General Forum Archive | 8 | 08-31-2000 09:04 PM |
| My DIY intake tested in heavy rain... | 8Complex | Technical Forum Archive | 6 | 07-21-2000 09:36 PM |
