Old 07-30-2004, 01:54 PM   #1
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
Default Its factory but NOT :)
I have a 98 rs w/ a factor wrx swap in it, full harness ecu motor etc... im running 3" dp to 2.5" dp back.. no cats/resonators... it was running exceptional untill today, i was driving and normally you cant press the pedal down more than an 1/8 of the way or your flying and the car is pulling hard and strong, i was in 4th and i realized that the car wasnt really going ne where so i put the pedal down slowly and well it did nothing it just felt like the car had lost all power and it revs SOOOO slowly , its still idels fine and sounds good.. so after about 20 mins of driving it that way i said to myself well i wonder if i was to shut it off and start it again whut would happen.. sure enough the car started to run wonderful again pulling great.... then abvout 3 seconds later same thing happened where it had NO and i mean NOOOO power and was blah.... i got home parked it and thats where it stands.. any ideas on whut i should be looking for ? the car was running great and has been built for a week, i dont think its something wireing related because i think it would have been there from the start if it was, and not a week later... two things i should tell you, the car smells like fuel horribly expecailly right after i fill it up.... ne ideas on that ? i was told its prolly my 3" catless exhaust system, and secondly the stock TD04 gets wicked hott i mean really hott to the point that i noticed it melted the tranny plugs so they are now deformed looking, and the tranny plugs are a good 3/4 of a foot away from that turbo it seems to be getting very hott is that normal of this turbo ???????? any and all help greatly apprecaited im sure alot of WRX guys will know whuts up since it is thier motor and ecu running this bad boy
PumpsGOTAWD is offline   Reply With Quote
Old 07-30-2004, 06:33 PM   #2
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
damn Paul, that sucks. The turbo's not blown, is it?
//marcus
marcus12 is offline   Reply With Quote
Old 07-30-2004, 07:03 PM   #3
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
I don't think a turbot shoult be getting hot enough to melt bolts. I would imagine the turbo is getting red hot to be melting bolts that are that far away. I would check out the turbo to see if its maybe the problem I would think anything else would make the car not idle smoothly. Does it seem fine to drive when not try to spool the turbo, i.e just driving easy like you trying to save gas or something
Kyle
Andursun0013 is offline   Reply With Quote
Old 07-30-2004, 10:55 PM   #4
jdchmiel
Member#: 926
ignition being retarded to far wold cause escessive heat and low power.
jdchmiel is offline   Reply With Quote
Old 07-31-2004, 02:38 AM   #5
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
no bolts are being melted.. haha.. just the plugs for the tranny... i moved them tho and they are fine now.. secondly.. whut would cause ignition retardation. ?
Old 07-31-2004, 11:02 AM   #6
Andursun0013
Member#: 11616
1998 2.35RS-T
yea, plugs....I was aparently out of it when i posted that
Old 07-31-2004, 01:36 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
do you have any gauges?
Old 07-31-2004, 07:04 PM   #8
Unsung Boxer
Member#: 37196
did you upgrade your fuel pump to match your WRX engine? the stock fuel pump wont flow enough fuel. This would cause it to run lean and hot.
Also, w/ the ECU, does your CEL Function properly. If so, I would like to know if the CEL is comming on. If the ECU sees something bad, it will pull timing, retard it so much that your engine wont be able to accelerate. If the ECU is causing a "safe mode" like this, it should throw CEL at the same time (assuming its OBD2)
Now that I listen to your symptoms, I think the most obvious hypothesis is that your spark plugs are fouling from running too rich. This explains the gas smell, and the lack of power. Fould plugs acts like retarded timing, as far as power loss goes. Turning your engine off, allows the gas to dissappait, thus when you re-start it, it runs good again, until they get fouled. Pull your spark plugs and see if they have a nice gassy smell... that would be conclusive of a rich condition.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 08-01-2004, 03:11 AM   #9
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
yes i have a boost guage, its shows 15 vacuum at idle, at speed but off gas 20 vacuum and varient boost under 50 percent throttle, and over 50 percent it most of the time pegs at 10psi some times i can ease it a little and then see 12-13psi and hold it there.. its really quick there im going to pull the plugs unsung.. ill let ya know the outcome.. also no the scan plug is not operable yet, or so i dont think ne wayz.. i still have 2 wires that i dont know whut to do w/ that arent hooked up i guess i could try to scan it and see whut happens... yes the cel is on, but i have a feeling that its thrown due to my rear o2 .. i have a hks 3" downpipe.. and if i pull neg cable of bat and reconnect the light will remain off for about 30-50 miles then come back.. or if i shut off the car and restart it again.... sounds like r o2 to me
Old 08-01-2004, 11:57 PM   #10
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
make sure you have enough fuel pressure, and that you dont have any fuel leaks. Running too rich/lean would be a bad thing either way, if your fuel is leaking, that explains the no-power and the gas smell, as well as the heat.
My other theory was that the turbo was broken, wasnt' making boost (no power) and was just restricting the exhaust (heat) but after your last post, if it's still making boost, then that isn't it.
My rule for troubleshooting an engine: it needs 2 things, spark and fuel. If it's not working, it's one of those 2. Figure out which one and work from there.
tooocool49723 is offline   Reply With Quote
Old 08-02-2004, 12:02 AM   #11
imprezaGDA
Member#: 15725
02 KandyApple
DoLuck REX
yah, but it also needs air, the spark to be timed correctly, the fuel to be in the right amount, Those two work as a baseline if the car isnt starting at all....
imprezaGDA is offline   Reply With Quote
Old 08-02-2004, 08:53 AM   #12
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
it was a sensor that was half unplugged, the drivers side front tumble generator valve, and also, the fuel smell is only when i fill the car up it goes away after about 1/4 of a tank is burned, i think i put the top cover of the tank back wrong ?? im going to take it all apart and find out..
Old 08-02-2004, 02:49 PM   #13
IowaRS
Member#: 5385
2012 WRX Base
Ice Silver
Yeah, that tank seal can be tough to get back on right.
Make sure you don't have any wires running under the seal before you tighten it down.
IowaRS is offline   Reply With Quote
Old 08-02-2004, 07:18 PM   #14
Andursun0013
Member#: 11616
1998 2.35RS-T
I'm proud to be an American
Sorry, I screwed up...delete if need be
Not a Suby but not to shabby... IMPORTEDCARS Proven Power Bragging 20 07-04-2009 10:23 AM
18g swap complete- not tuned yet but not getting boost...wtf? evol04gt Factory 2.5L Turbo Powertrain 14 05-20-2009 04:38 PM
as promised: side shot.. and now its all waxed up :) 03boxer4 Member's Car Gallery 11 05-16-2007 01:22 AM
Car says its hot, but it's not. O Stylee Factory 2.0L Turbo Powertrain 17 08-28-2006 10:30 PM
Clutch feeling wierd shaking but not sure if its shudder fedrex Transmission (AT/MT) & Driveline 0 03-14-2004 07:49 PM
Message Board Statistics All times are GMT -4. The time now is 08:17 PM.
