Old 12-11-2000, 09:50 PM   #1
grimlock
Member#: 2683
2011 STi 5-Door
Post Rear Sway Install: As easy as they say!
I installed my new Whiteline 18-22 adjustable sway bar at 10:00 PM tonight, and it only took me 45 minutes. This was in the dark, by myself, no jacking the car up, and never having done any suspension work on a car before.
The only problems I had were loosening and tightening the passenger-side mount (learned that those hoses push out of the way easily), trying to close the mount clamps on the new bar/bushings (learned that pulling the bar to the rear helps to get the bolt started), a shoulder cramp while loosening the endlink on the driver's side (learned I'm out of shape ), and what I shall forever call "The Subie Twist", figuring out how to get the old bar out and the new one in without removing the muffler. Heck, I even remembered to grease the new bushings. Body roll is much less pronounced now, and the cornering feel is great.
So, to all you Impreza owners out there who haven't upgraded your rear bar, what are you waiting for? If I can do it, so can you!
Ross N.
grimlock is offline   Reply With Quote
Old 12-12-2000, 12:08 AM   #2
markus
Member#: 438
2004 STi
White on Gold
Question
Grim,
Did you get the end links and upgraded mounts as well?
What did you set your bar at?
I was blown away as to what a difference my bar made set at 18mm. Can't wait to set it at 20 or 22.
markus is offline   Reply With Quote
Old 12-12-2000, 05:44 AM   #3
grimlock
Member#: 2683
2011 STi 5-Door
Post
No end links or mounts yet, that would turn out to be a bit too much for a Christmas present. The word on the street is that the stock plastic end links will support up to a 19mm bar, so mine's set at 18 for now. It'll probably go to 20 when I get enough dough for new suspension. I'll be getting the endlinks then, but I may never get the mounts unless I start competing.
Ross N.
Old 12-13-2000, 08:32 AM   #4
SuBaRu-ImPrEzA_RS
Member#: 2053
Post
how much is a whiteline adjustable swaybar???
SuBaRu-ImPrEzA_RS is offline   Reply With Quote
Old 12-13-2000, 10:18 AM   #5
grimlock
Member#: 2683
2011 STi 5-Door
Post
I got mine from CTC Motorsports on clearance. $140 + $20 for shipping.
Ross N.
Old 12-13-2000, 11:35 AM   #6
Keith
Member#: 191
2012 J train
Brown
Post
who is CTC??
keith
Keith is offline   Reply With Quote
Old 12-13-2000, 11:44 AM   #7
grimlock
Member#: 2683
2011 STi 5-Door
Post
I dealt with Kyle. Their website is www.ctcmotorsports.com. Quite a pleasant buying experience. The clearance I got mine in was posted in the Vendor Classifieds a couple of weeks ago.
Ross N.
Old 12-14-2000, 12:12 AM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
Wait'll you try 22mm. Talk about oversteering delight! The car is completely flat and is sooo solid. I couldn't get the car dialed in properly with my kyb agx's so I turned it back down to 20mm for the winter.
Old 12-14-2000, 12:44 AM   #9
sbsnyder
Member#: 2440
Post
Any idea if you can use the Whiteline upgraded mounts with an FHI 20 mm rear bar?
I'd really like to get them, but don't know if they will work.
Stacey
sbsnyder is offline   Reply With Quote
Going Green isn't as easy as they say it is. Mud Pig Off-Topic 18 09-08-2008 10:46 AM
Oil change in '06 not as easy as before quynce Normally Aspirated Powertrain 2 02-25-2006 07:58 PM
it's as easy as falling off a roof.. Fish Off-Topic 12 07-17-2004 09:49 AM
Would the EJ22 bolt into an EJ18 as easy as the EJ25 bolts in? Max Umbarger Subaru Conversions 16 02-27-2004 11:51 AM
Is stripping a gear as easy as it sounds? bluebaru wrx Transmission (AT/MT) & Driveline 3 12-11-2003 12:04 AM
