Old 07-30-2004, 11:48 PM   #1
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Default ECU reset question.
Does it matter if I disconnect the negative or positive terminal from the battery? My negative terminal is a lot harder to get to than the negative. Also, is there just a fuse I can pull that would do the same thing?
KEVIN
FatCatTurbo is offline   Reply With Quote
Old 07-31-2004, 12:14 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
There's no fuse as far as I know of. Not sure about the - or + terminal. You could try the + and if the odometer goes dead, then you know it worked.
Calvin
cnk is offline   Reply With Quote
Old 07-31-2004, 09:32 AM   #3
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
It is ok to pull the positive, just a lot more dangerous. All the metal around it is ground, and all the capacitors in the car will still be charged, so arcing is possible.
I assume your battery is not in the stock location (judging by your car description).
brizey is offline   Reply With Quote
another ecu reset question suby ej25 Newbies & FAQs 3 08-06-2001 12:38 PM
GanzFlow aftermath and ECU reset question heatseeka Normally Aspirated Powertrain 16 06-19-2001 02:21 PM
ECU reseting question! Blindeye_03 Normally Aspirated Powertrain 6 04-05-2001 08:36 AM
Different ECU reset question Jonathan_Yi Newbies & FAQs 5 02-03-2001 06:32 PM
ECU Reset Question (But not "How do I?"" Eric SS Technical Forum Archive 4 08-03-2000 10:23 AM
