Old 07-31-2004, 09:58 AM   #1
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Default From a GT28 to a TO3/TO4 Ball Bearing
I recently purchased a TO3/T04 Ball Bearing Turbo. My current GT28 spools quickly but dies at high RPMS. Has anyone hade any experience with the TO3/TO4 BB in their RS-T??? Did I make a good move from one to the other???
saludos,
Mariano
Mariano is offline   Reply With Quote
Old 07-31-2004, 10:06 AM   #2
markus
Member#: 438
2004 STi
White on Gold
I know of an RS-T in my area with a BB t3-t4 hybrid and it runs VERY strong. Not sure about the turbo specifics though. It most certainly does not die at the top end though.
markus is offline   Reply With Quote
Old 07-31-2004, 10:45 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
how much boost are you trying to run?
ColinL is offline   Reply With Quote
Old 08-01-2004, 08:16 PM   #4
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Impreza GC8
I'll be running same amount of boost as I do now: 10-12psis. The thing is that the other day I was driving on a highway and I realized that my GT28 it's great for "light to light", short runs, etc... and not for top end driving. I got spanked by a 2001-04 BMW M3...
saludos,
Mariano
Old 08-04-2004, 10:13 PM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
sorry about the slow reply, but you're going the wrong way my friend. you maybe have already figured this out on your own if you've installed the turbocharger.
a GT28 of any trim will spool to only 12psi on a 2.5 SOHC pretty damn fast and easily hold it to redline. all you gain with a t3 is the ability to run more boost, which you can't do without lower compression (and hopefully better rods also).
your GT28 dying at high rpm is probably the cams or your tuning. get bigger cams and a standalone ECU and you'll be a happy man.
Old 08-05-2004, 07:52 AM   #6
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Impreza GC8
Colin,
I haven't installed the T3/T4 yet. I figured that since most of the turbo kits sold for the RS were based on using the T3/T4 hybrid that it would be even better to have one ball bearing (I might be completely wrong but that's why I'm looking for comments/answers in this forum). I've been in a RS-T with a "regular" T3/T4 and it was great at top end. Another experiment that I've not done is install my AVC-R. My guess is that with the AVC-R the 12psis will hold completely till redline, if so I'll sell the T3/T4.
I got the T3/T4 brand new at $422 (ebay) and even If I don't install it I know I can make a couple of bucks locally selling it.
thanks for your input
saludos,
Mariano
Old 08-06-2004, 01:09 AM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
the 'dying at high rpm' also could just be a consequence of your strange torque curve as you make a lot of boost right away, and stay there. a dyno plot would help a lot obviously.
also, check for boost leaks if you're not holding 12 psi to redline especially in higher gears. tighten all your hose clamps with a socket they have the typical hex head with phillips in the center-- you want more force than can be applied with the screwdriver.
Journal bearing non-wc to ball-bearing wc jpwrxtr06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-30-2008 06:05 PM
Anyone know where to get a good ball bearing turbo? AntiochCali Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-08-2003 12:56 PM
What would be the benefit of ball bearing turbo compared to other ?? setiawani Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-28-2002 12:02 AM
TO3/TO4 Ballbearing "ballistic" Mariano Normally Aspirated with bolt-on Forced Induction Powertrain 0 01-15-2002 11:51 AM
Where to find ball bearing for mbc wagonbeast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-23-2001 05:11 PM
