Old 07-31-2004, 01:49 PM   #1
hnasko
Member#: 26163
2011 E90 M3
Jerez Black
Default Green test Connectors already connected
I am trying to install my accessport, but the green test connectors were already installed and the car does not go into diagnostic mode...cannot reflash.
I hear there are other connectors in the passenger side.
Please tell me where to find these connectors.
rob.
hnasko is offline   Reply With Quote
Old 07-31-2004, 03:14 PM   #2
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
They are on the driver side underneath the dash. Get a flashlight and crawl underneath your dash and they should be to the left of the steering column. Plug them together then do your reflash
dsmperformance is offline   Reply With Quote
Old 07-31-2004, 03:51 PM   #3
hnasko
Member#: 26163
2011 E90 M3
Jerez Black
The green ones under the steering column were already connected, probably from when Subaru pulled a CEL for me a month ago.
If these were already connected, there must be an open somewhere else? right?
Old 07-31-2004, 05:21 PM   #4
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
They should not have been left connected. Not sure what happens if you leave them connected.
Old 08-01-2004, 01:34 AM   #5
TreyS
Member#: 42478
2004 WRX STi
White/Gold
look again. there are a set of plugs for the alarm up there that can be plugged together and look simular.
Look again...harder and higher up in there.
TreyS is offline   Reply With Quote
Old 08-01-2004, 05:48 PM   #6
KJY9
Member#: 66264
Originally Posted by dsmperformance
.... Not sure what happens if you leave them connected.
Flashing CEL
KJY9 is offline   Reply With Quote
Old 08-01-2004, 07:25 PM   #7
jugger
Member#: 64228
mine were connceted too....and when i tried to flash base map i kept geting error....so YES i had to tear the sill apart and disconnect the green ones in there to get it to work...check it out>>>> http://www.wrxforum.com/cgi-bin/ulti...;f=11;t=000517
jugger is offline   Reply With Quote
Where is the 05 Legacy GT green test connector? bboy Commercial ECU Reflashes 2 10-03-2007 05:37 PM
Green Test connectors bdon22 Commercial ECU Reflashes 47 05-04-2007 01:44 PM
where are the green test connectors (lgt) vogun16 Commercial ECU Reflashes 6 04-30-2007 10:11 AM
Green test connector and white connector...AP Q styng88 Mid Atlantic Impreza Club -- MAIC 6 03-06-2006 03:08 AM
Accessport and green test connectors zojirushi Engine Management & Tuning 0 06-24-2004 02:59 PM
