#1 |
Member#: 40705
If I use a hydraulic jack (those that u use for swapping of gearbox) to prop up some part of the engine.....
Will I be able to remove my crossmember and swap it for another one without disconnecting the engine from the gearbox? Currently running the turbo crossmember + stock WRX everything. Having problems with the turbo inlet clearing the block so gonna swap back to the NA crossmember + custom piping.
#2 |
Member#: 39936
Vehicle:99RS TWE&SCAT EJ257 Hydra+HMist+PPG+35R=DEATH |
doubtful
its very hard dont use the na crossmember just use the wrx one w/ custom piping |
#3 |
Member#: 40705
So is the WRX header setup really better than using the stock NA headers?
Seems like alot of people giving me conflicting views on this matter |
#4 |
Member#: 39936
well i dunno for sure but it doesnt make sense theyd make poor headers if they already had a design that worked half way decently
#5 | |
Member#: 37196
However, if you do the Turbo Xmember, you leave yourself open to use aftermarket headers that are dyno proven to increase power, and reduce lag. If you have RS heads, you should be able to use turbo Xmember w/ WRX manifolds, but I would use an aftermarket one if possible, as the cats are very restrictive. invidia makes a beautiful one for only 1100 bucks . -Jake |
| Thread Tools | |
| Display Modes | |
| Valve seals, possible without removing heads? | Splinter | Service & Maintenance | 5 | 09-29-2009 10:12 PM |
| Is it possible to replace WG actuator without removing turbo? | gopsu | Newbies & FAQs | 12 | 09-05-2009 12:43 AM |
| Can the tranny crossmember be removed without removing the downpipe? | PhastEddie | Factory 2.0L Turbo Powertrain | 2 | 07-23-2007 08:54 AM |
| Oil change without removing drain plug... | Konvict | Alaskan Impreza Club Forum -- AKIC | 15 | 09-30-2006 12:44 AM |
| Subaru 4-pot: can you change pads without removing calipers? | Orson | Brakes, Steering & Suspension | 5 | 11-26-2005 12:24 PM |
