Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 07-31-2004, 05:30 PM   #1
NitrouStang96
Member#: 67367
Default Low power in 1984 GL 10 ??
Girlfriends brother just bought one.
Let me tell you what I have gone through with this thing.
This thing is very very slow, going up a hill it doesn't go past 35, it shifts into 2nd at 2700rpm, and into 3rd even lower. It is perfectly smooth, like it's just a low powered engine. No sputtering, no hesitation, it just feels like it's only got like 50-75hp - the car supposedly only weighs 2000lb. Failed smog test. Smog test dude said it was a clogged cat that is causing the power loss and the failed test.
____________
I removed the back cat, still no power. Removed the Y-pipe from the manifolds along with the front cat, still no power. So I don't think it's a clogged cat.
I retarded the timing some (turned the distributor), no power gain. Advancing the timing only caused detonation, so the timing is set correctly at the distributor.
Even though it's smooth power, I decided to look at the carb. Dinky little two barrel, the back barrel appears to be a vacuum secondary. With the car in park, I floored it and made the front barrel open all the way up, the rear barrel only likes to open about 20 degrees max instead of the full 90 degree open position. I don't know if this is the cause or not. Also, there is only one choke looking type butterfly on the top - in the front barrel. In the back barrel there are threaded screw holes with nothing in them, maybe something is missing - do you know? I have no idea what this carb (and the entire engine is supposed to look like).
_____________
Beyond that, I have no idea what to look at on this car. If it was a Ford, I would check to see that the timing belt was put on properly, but I don't have a Subaru book, nor do I know how to adjust the timing there with the belt, or if it even needs it on this car.
Any help?
NitrouStang96 is offline   Reply With Quote
Old 07-31-2004, 08:12 PM   #2
NitrouStang96
Member#: 67367
Update:
Took off the air cleaner and disconnected the 5 vacuum hoses connected to it and the exhaust recirculation hose as well. Took her out for a run, and she revs all the way to 5 grand, pulls well. 81mph uphill on the interstate, when before she wouldn't run much past 35mph.
Old 07-31-2004, 08:48 PM   #3
NitrouStang96
Member#: 67367
Put all the stuff back on, still works. Turns out that when I was playing with the throttle linkage, I freed it up and now the throttle is opening wider.
My question is: If the throttle linkage didn't permit the carburetor to get fully open when floored, say only 75-80% or so - would that cause it to fail a smog test?
Old 08-01-2004, 12:48 AM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
OK, so I missed your crosspost from NA.
More advice : Remove engine, insert EA82T. Only about $500, about 50% more power or so, IIRC.
jamesfacts is offline   Reply With Quote
Old 08-01-2004, 03:24 PM   #5
JWX
Member#: 28990
JWX is offline   Reply With Quote
Old 08-04-2004, 02:07 AM   #6
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
If only it were just that easy
Calebz is offline   Reply With Quote
Old 08-04-2004, 02:09 AM   #7
Calebz
Member#: 54398
1980 CB400 Hawk
It DOES only have about 75 hp
and it weighs about 2400 pounds
Old 08-04-2004, 09:24 AM   #8
jamesfacts
Member#: 51282
98 RS
Sure it is....
Old 08-04-2004, 10:12 AM   #9
Calebz
Member#: 54398
1980 CB400 Hawk
Sure it is....
Psssst.. hey.. over here...
What about the wiring harness? I've had one out.. its a mess.
front mount in a gl-10 mm88swrt Pre-2002 Factory Turbo Powertrain 2 02-22-2009 09:50 PM
1984 gl wagon dies for no reason?? twitch88 'Old School' Subaru Forum 3 11-20-2005 10:46 PM
1984 gl clutch repalcement dentedfender 'Old School' Subaru Forum 2 11-19-2005 01:56 AM
1984 gl clutch replacement please help dentedfender Transmission (AT/MT) & Driveline 1 11-09-2005 10:44 PM
Low power in 1984 GL 10? NitrouStang96 Normally Aspirated Powertrain 3 08-01-2004 12:33 AM
