Old 08-01-2004, 01:40 PM   #1
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Default Prodrive Performance Packs
Does anyone have these packs installed on your WRX? If so, was it difficult to install and what do you think about it? I am planning on doing stage 2 in the spring. Thanks.
Acostafan is offline   Reply With Quote
Old 08-01-2004, 07:32 PM   #2
1984
Member#: 16461
WRB w/paintchip flake
I'd imagine the hardest part of the prodrive packs would be the up-pipe.
1984 is offline   Reply With Quote
Old 08-02-2004, 09:52 AM   #3
coolblue05
Member#: 39169
2008 Cayman S, 335xi
Tuned Perfection
For the money, you can have much better power going elseware, there was big controversy a while back in regards to prodrives kits not producing their advertised power.
coolblue05 is offline   Reply With Quote
Old 08-02-2004, 10:40 AM   #4
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
^^^^ Yeah, what he said. ^^^^^
Old 08-02-2004, 11:36 AM   #5
Rallycarperson
Member#: 53971
#35 SP Rally Car
MAP-RALLY.com
^ I second that. ^
Try www.turboxs.com, www.vishnutuning.com, www.cobbtuning.com, and other web-sites I cant name for performance packages. For Prodrive products, you pay for the name....much like Mercedes Benz.
-Mark
www.MAPmotors.com
Rallycarperson is offline   Reply With Quote
Old 08-02-2004, 04:10 PM   #6
2Stroke
Member#: 36712
2003 WRX Wagon
Only the Stage 3 replaces the uppipe. Stage 2 replaces the intercooler hoses, 3rd cat, and muffler. Nothing difficult there.
2Stroke is offline   Reply With Quote
Old 08-02-2004, 04:24 PM   #7
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
I suspect the hardest part is being able to afford it. Prodrive packs cost the most and offer the least performance.
MB38 is offline   Reply With Quote
Old 08-02-2004, 04:36 PM   #8
2Stroke
Member#: 36712
2003 WRX Wagon
Search the 'Car Parts' forum under 'Nasioc Reviews" for 'Prodrive". Titles instead of full text will reduce clutter.
Edit: Click 'search', then 'advanced search' to see these options.
Old 08-02-2004, 06:38 PM   #9
capecod_wrx
Member#: 43277
'08 VDub R32
I've got the PPP2 on my '04 Wagon - and so far I'm really pleased with the increased performance. Acosta fan - here's a link to a good PPP2 review:
http://forums.nasioc.com/forums/showthread.php?t=548269
capecod_wrx is offline   Reply With Quote
Old 08-02-2004, 10:52 PM   #10
waveskidude
Member#: 17007
MBP
Post
I had PPP2 on my WRX for about 4 months and then just upgraded to PPP3 about 2 weeks ago. You can read about all the other threads on these kits, but personally I really like them. The PPP2 is very easy to install. The PPP3 kit is more involved due to the uppipe replacement. Thanks to the wealth of info on these forums it ended up not being that difficult. These are pretty much 'plug and play' systems. I have not had one single problem with either kit. No running problems and, no check engine lights. As far as power goes, I ran the car at ButtonWillow HPDE with the PPP2 kit and had no problems keeping up with two M3's (E36 and E46) down the front straight.
waveskidude is offline   Reply With Quote
Old 08-03-2004, 07:07 AM   #11
capecod_wrx
Member#: 43277
'08 VDub R32
waveskidude - i'm also thinking about the PPP3 upgrade. how much louder is your car with the prodrive up and down installed? also - have you had any emission testing trouble w/only a high-flow cat?
thanks...
Old 08-03-2004, 10:28 AM   #12
steveson
Member#: 25153
2003 WRX Wagon
I too have the PPP2 on my 03 wagon. I have no complaints in the desert southwest at 6500 ft. No check engine, improved drivability, no pinging on hot days, 27 mpg while commuting etc. During track events the car has had no problems running with more exotic and more powerful cars. That being said, you can get more horsepower for the same money elsewhere. I might go stage 3 in the next month, then again I might go with a Ver. 8 swap in the next month also
steveson is offline   Reply With Quote
Old 08-03-2004, 01:24 PM   #13
thrdeye
Member#: 24569
2011 Impreza WRX
I have a PPP3 I've got a review of it floating around here somewhere.
edit: here it is http://forums.nasioc.com/forums/show...ive+power+pack
I like it a lot. No issues. Plenty of power for me. No CEL. Quality is second to none. If you are looking for big power numbers, this is not for you....but if you want better throttle response, drivabilty, etc., this is what you want. I recommend buying a boost gauge.
The PPPs are under warranty in the UK. Won't really do you any good here, but you get some peace of mind that they are warrantied somewhere. Additionally, I have heard that prodrive has PPP3 ej20s on an engine dyno with over 100K miles on em and no problems.
thrdeye is offline   Reply With Quote
Old 08-03-2004, 08:59 PM   #14
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
I installed a PPP3 at 40k miles; got ~65k now - and still love it. (I'm using the Stromung twin tip muffler instead of the Prodrive; I already had it, and couldn't bear to part with it)
What do I like about it?
  • It's a complete, well engineered, kit; install it and go, no further tuning necessary. As long as you're happy with the results you just drive...
  • Very nicely designed and constructed bits. (Full disclosure: I had some early parts, and a few fitment problems which I reported to Prodrive. Presumably long ago resolved...)
  • Excellent power, from off idle to the top; boost max well below 3k under most conditions.
    Note: this is the only system I'm aware of that actually makes full use of the stock turbo's compressor map: under optimum conditions the reflashed ECU's boost max is ~19psi in the heart of the midrange, tapering down to follow the map above ~5k. (This is actually a bit conservative compared to how far the map looks like you could push it, but I like that for longevity.)
  • Lovely sound; I rarely even turn on the radio/CD anymore (of course I can't vouch for the difference w/ the Prodrive muffler, but I'm told it's much the same).
  • You can use the stock heatshield, albeit with some modification. (Search for posts with my name and "heatshield" for pics and description).
  • No CELs; O2 sensors in stock locations, EGT sensor moved to DP where it can't affect the turbo if it physically fails; the reflash (presumably) takes care of any adjusted parameters.
  • Driven from sea level to over 11k feet, and from ~-30F to ~100F. No hiccups; boost does adjust for conditions, as expected (I would hope so!).
Do I want more power? Of course! But I'm not willing to compromise long term reliability, nor daily drivability, to get it. Hmmm...maybe PPP4 someday...
GravelRash is offline   Reply With Quote
Old 08-04-2004, 12:49 AM   #15
waveskidude
Member#: 17007
MBP
Cool
thanks...
Capecod -
I've only had the system on for about two weeks or so and haven't had to do any emission testing. That said, one of the things I like about this kit is the nice downpipe cat. I can't say for sure that it will pass any US emissions tests, but it is the same cat they put on the UK PPP kits and include an emissions warranty on those systems. As far as noise,the PPP3 does not make it any louder per se. It sounds a little deeper at idle and a tiny bit noiser on acceleration (due to the new uppipe). Its just as quiet as the PPP2 kit on the highway (hard to hear anything over my worn Azenis.....).
Old 08-04-2004, 10:01 AM   #16
thrdeye
Member#: 24569
2011 Impreza WRX
From what I understand, they are thinking about it.
Old 08-04-2004, 06:22 PM   #17
orichard
Member#: 43952
2004 WRX Wagon
San Remo Red
I've still got to add my little orifice thing, but i finished everything and put the ECU back in a few minutes ago... Seemed fine, it's hot as ***** here today, so I'm sure I won't see 19 psi on the way home, but it worked... apparently no exhaust leaks yet!
I concur... not much, if any noisier...
I've heard rumblings of PPP4 also...
orichard is offline   Reply With Quote
Old 08-05-2004, 12:15 AM   #18
waveskidude
Member#: 17007
MBP
Must ........ resist ...........
Old 08-05-2004, 12:32 AM   #19
|Thrax|
Member#: 52350
2004 WRX Sedan
Alpine White
what would ppp4 be? vf34?
|Thrax| is offline   Reply With Quote
Old 08-05-2004, 12:47 AM   #20
thrdeye
Member#: 24569
2011 Impreza WRX
turbo, intercooler, fuel pump, injectors is what i heard.
Old 01-09-2005, 11:29 PM   #21
jester5
Member#: 57274
2004 WRX
my prodrive performance pack stage 2 is on its way to be installed cant wait
-Jeff
jester5 is offline   Reply With Quote
Old 01-22-2005, 10:03 AM   #22
jester5
Member#: 57274
2004 WRX
its in and its a very nice upgrade
-Jeff
Old 01-22-2005, 07:36 PM   #23
2Stroke
Member#: 36712
2003 WRX Wagon
jester5 - Did your car have any issues with bucking on throttle let-off at ~5000 rpm? Just wondering if the PPP2 fixes that on the MY04's.
Old 01-25-2005, 07:27 AM   #24
Simon Lines
Member#: 1540
92 JDM GC8 WRX
2004 2.5 twin scroll 6MT
Hi Guys
Nice to read some good thought / feelings about PPP's! To the chap who's just fitted his, make sure you put the new jet in, it's important
About PPP4, we have done a couple of iterations of PPP4, one has been running for about 30k miles on Dan's car (dan@prodrive.com) with no problems (and I mean NO problems, he's still on stock original clutch and transmission) and it's only ever seen 91 pump gas and will eat a stock STi
Current spec is - turbo, full exhaust, up-pipe, injectors, pump, intercooler, intercooler pipe, intake, zip tube, scoop and scoop internals
We have not made the decision to supply it yet, we are concerned about warranty issues (clutch and transmission) as some US Impreza drivers seem to have clutch / transmission problems with almost stock cars we feel that PPP4 might be too much for them. We also feel that PPP4 may not be a "100,000 mile solution" to explain everything we sell is from the point of NOT effecting your warranty (even if it's not officially covered). The PPP4 pushes this envelope and may not be 100,000 mile safe, we have to consider our position on this as it's a new area for us.
Assuming all the points get covered we may offer it as an up-grade path to PPP3 owners or something like that, the one final issue is cost of course but we're working on that.
Cheers
Simon
simon@prodrive.com
Simon Lines is offline   Reply With Quote
Old 01-25-2005, 08:33 AM   #25
Lonederanger
Member#: 40184
2005 WRX
Obsidian black
Do the prodrive packs work well w/ California pee fuel?
Lonederanger is offline   Reply With Quote
Prodrive Performance Pack (stage 2?) review from Top Gear Orson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-10-2005 06:26 PM
Prodrive Performance Packs Stage 2 - In Stock at Daddy's Daddy's SCP Vendor 'For Sale' Classifieds 4 09-04-2003 01:29 AM
Prodrive Performance Packs and hats!` Z1 Performance Vendor 'For Sale' Classifieds 1 08-15-2003 01:49 PM
Prodrive performance pack FloridaWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-22-2001 09:17 AM
I really hope SOA brings over the Prodrive Performance Pack for our WRXs... Mr. Ixnay Mid Atlantic Impreza Club -- MAIC 10 05-24-2001 08:34 PM
