Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 08-01-2004, 05:10 PM   #1
BoostdScubaru
Member#: 42188
Default i need a base map....
i am stuck now and i cant seem to figure it out.. i tried to set timing in the 0% column and i can hardly get it to idle... im running like 22:1 afr... unless i get to 1000 rpm and hold it for a sec... then it drops down to 14.3:1.... really rough idle... unless it gets warm..oh yeah and the mods i have are: vf-22, modded injectors, FPR mod, fuel rail mod, header,uppipe, 3" turboback, 18 psi , utec....
anyone have any maps that i could at least get an idle so i can begin to tune....???
BoostdScubaru is offline   Reply With Quote
Old 08-01-2004, 08:51 PM   #2
oldbluwrx
Member#: 61677
02 wrx
blue
What size are your injectors modded to? I have a decent map for 800cc's.
oldbluwrx is offline   Reply With Quote
Old 08-01-2004, 09:42 PM   #3
BoostdScubaru
Member#: 42188
well, there are the stocks modded... i also did the fuel pressure mod sothey should be 800cc.... it seems tobalance out on scaling with 800 cc... im getting a real lean condition once the throttle is let off until it gets back to idle. i just need a good base map... i've got a wideband to tune with just need a starter... email is AWD_importdragon@yahoo.com.. send it and i'll give it a try...
Old 08-01-2004, 09:46 PM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
did you mean to say fuel? because there's no reason to futz with the zero column timing, despite your injectors/fuel mods.
no way around the fact that you will need some way to monitor obd2 fuel trims...
ken
Old 08-01-2004, 09:49 PM   #5
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
have you tried over at wrxhackers.com ? they have base maps to download
MikeWRX-NJ is offline   Reply With Quote
Old 08-01-2004, 09:54 PM   #6
BoostdScubaru
Member#: 42188
yeah but i waskinda trying to find one from someone who has experienced this and tuned out of it...
Old 08-01-2004, 10:12 PM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the fact that you have non-oem fuel pressure pretty much precludes you from just getting a map from someone and driving away... that will cause you to have to fine tune your injector parameters at the very least.
Old 08-01-2004, 11:30 PM   #8
BoostdScubaru
Member#: 42188
thats fine... just need a better start than turboxs base map stage 4...
Old 08-07-2004, 12:34 AM   #9
BoostdScubaru
Member#: 42188
anyone have anything to help me....
Old 08-07-2004, 12:59 AM   #10
cronic
Member#: 9749
Not sure the reason why you did the FPR mod on top of the Injector mod for that tiny 22? The modded inj alone give an enormous headroom for the 22..
Good Luck
cronic is offline   Reply With Quote
Old 08-07-2004, 05:32 PM   #11
oldbluwrx
Member#: 61677
02 wrx
blue
Check Your E-mail, sent you a map let memknow how it works.
Old 08-07-2004, 06:29 PM   #12
BoostdScubaru
Member#: 42188
better to be rich than blown up...
Old 08-08-2004, 12:39 PM   #13
BoostdScubaru
Member#: 42188
oldbluwrx check your pm's
Old 08-10-2004, 12:29 AM   #14
BoostdScubaru
Member#: 42188
i really need some help... im running a richened up stage 3 map, and im still hitting knock... gonna get the front mount on and tune it with a wideband... do i need an EGT gauge also to tune...? i really need to tune the thing i got 77 miles on half a tank...
if anyone has a map for 700 cc injectors,vf-22, 18 psi.. i could really use it to start tuning...anyone near the dayton mall area with good utec tuning experience...
Old 08-10-2004, 10:30 AM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
if you're getting 77 miles to half a tank the last thing you need to do is run a "richened up stage 3 map."
it may be time to take it to a professional: you have a LOT of variables to contend with.
jm2c
ken
Old 08-10-2004, 10:52 AM   #16
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
Dude, Take your car to a qualified UTEC tuner b4 you regret it. I dont mean to flame you here but from what you have written it is readily apperient you dont know what you are doing.
1) no timing is needed in 0% column if you are running 20's for AFR's you need to add fuel to the 0% column to bring it to 14.7 AFR
2) the stock ECU cuts the injectors at higher rpm with 0% throttle to pass emmissions. Every time I let off the gas above "X" rpm the AFR are pegged at 25:1
3) If you are running rich and still knocking you have timing issues! STOP driving your car B4 you grenade your motor!
For the love of the subi gods please get some help!
bikerboy is offline   Reply With Quote
Old 08-10-2004, 08:34 PM   #17
BoostdScubaru
Member#: 42188
well im not stupid... im not driving it at all i simply took it out for a test run after injector mod, and TGV delete mod... it idles fine... but runs really lean as soon as i let off the throttle... is that ok? i mean it takes a half second or so on the throttle for it to come back out of the lean and start running rich...
if i richen up the 0%column will that help?? also the knock is light knock i think its actually drivetrain noise fooling the sensor... afr is good and timing is nothing crazy when it happens... i have a lot of drivetrain noise from the sti v6 ra gearset...also i want to get one of the torque stabilizers for motors... on timing during knock do i raise the number(30 up to 32) or lower it...im somewhat understanding it but also mainly just waiting for the wideband, front mount, and someone to ride with me that knows what they are looking at to help me tune it...i got the basics down... im going through the whole car at once and I definitely dont have the time for everything... should be freeing up some time within the next two weeks to fix all the bugs...
Old 08-11-2004, 08:13 AM   #18
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
A big mistake people are making with modded injectors is putting 420 as the injector size, then approx 850, for the scale size. Remember these txs base maps are done using STI pinks, so when using modded injectors on a txs stage 4 base map you must put 550 in as stock injector size to get good results. I know, I've done it.
I'm now running 550 in the stock slot and 850 in the other slot, a/f ratios are great, NO knock, and beautiful idle.
Kent
wrx plus is offline   Reply With Quote
Old 08-11-2004, 09:13 AM   #19
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
but runs really lean as soon as i let off the throttle... is that ok?.
That is the ECU cutting signal to the injectors. This is done to pass low speed emissions and is perfectly normal and no changes are needed.
See above, no changes are needed as long as the idle is 14.7 +/-
I would check what WRX PLUS said, make sure you values for scaling are set properly. 550 for stock and scale them to 810. I dont know why he chose to run 850 but that is not that far off.
As for you knock ?'s I would reload the map that is closest to you set up and run that. Once these steps are done then pull some logs (log #1) and post them so we have a bit more to go on. If you have logs with the knock events in them, then post that as well.
M
Old 08-11-2004, 06:53 PM   #20
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
log it and post it. With out some good info it is hard to say if it is knock or a over active sensor.
Russ
WRX1 is offline   Reply With Quote
Old 08-11-2004, 09:15 PM   #21
BoostdScubaru
Member#: 42188
well my A/F is way off at idle... im going to try the injector sizing...i'll let you know what happens... anyone know how to save the log into a file...? thanx for all the help so far...
Old 08-11-2004, 09:20 PM   #22
cronic
Member#: 9749
yea hit logger 1 pause it with space bar then go up top and on the pull down menu go to transfer then capture text then start.. then hit the space bar again to start it.. then just make sure u stop the capture after the log is done..
Old 08-12-2004, 12:04 PM   #23
SmoknWRX
Member#: 44983
2003 impreza wrx
aspen
boostedscubaru............expect to make minimal progress until you hook up a WBO2. i run the modded injectors on my car, and i tried it with out a WB so i know. good luck
SmoknWRX is offline   Reply With Quote
Old 08-16-2004, 06:01 PM   #24
oldbluwrx
Member#: 61677
02 wrx
blue
Did you get my E-mail I sent you my map?
Old 08-16-2004, 07:43 PM   #25
BoostdScubaru
Member#: 42188
no my email isnt working... could you possiby host it somewhere and send me the link thru PM
I need hydra base map subabusa Other Engine Management 1 08-17-2006 11:08 AM
need a base map for heavily modded sti wrxtuner02 Engine Management & Tuning 4 04-29-2005 09:33 AM
need good base map one wicked wrx Engine Management & Tuning 2 04-07-2004 03:11 PM
LINK Plus -Need a base map for N/A 2.5rs Marcin Engine Management & Tuning 7 11-12-2002 11:49 PM
Attn: Shiv! I need a base map. Could you hook me up? hayscoob Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-24-2002 11:20 PM
