Old 08-01-2004, 07:35 PM   #1
Cavadini
Member#: 65601
2004 WRX
World Rally Blue Pearl
Default 4th gear knock??
Hey guys. I have the Stage IV UTEC base map that I used as a base. I retarded the timing a couple degrees as I run good ol 91-92 octane in Nebraska. The boost map is fine, 17.5psi to redline, timing is fine and I'm running the stock fuel map since my EGT gauge/wideband is not installed yet. While I was racing tonight everything is fine in gears 1-3 but in 4th at WOT it would knock. Any ideas as to what would be causing this?? Any way to fix it?
Cavadini is offline   Reply With Quote
Old 08-02-2004, 01:08 PM   #2
sneeky
Member#: 44639
STi
the 35 awaits you...
do you have any logs?? kinda tough to suggest anything if we can't see exactly what's happening.
chris
sneeky is offline   Reply With Quote
3rd. and 4th. Gear knock... bstdwgn UTEC 7 12-25-2007 07:20 AM
02 tranny 2nd gear is fine but 4th gear???? jdem18l Transmission (AT/MT) & Driveline 11 05-24-2006 10:14 AM
4th gear grind, only fast shift from 3rd to 4th VideoGameWrx Transmission (AT/MT) & Driveline 13 12-24-2004 05:14 PM
Grinding in 2nd gear, 4th gear, and reverse Blizwinter Transmission (AT/MT) & Driveline 5 06-08-2004 05:12 PM
Knock at 3000 to 3800 RPM 4th gear... *log inside* tEkkGOD Engine Management & Tuning 12 12-05-2003 03:12 PM
