Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 08-01-2004, 11:56 PM   #1
SpeedyWRX02
Member#: 53623
WRX 318 WHP
PE1820
Default RalliSpec, NJ HP #s?
Everyone knows that different tuners make different numbers. I'm getting rid of my UTEC and getting flashed to the EcuTek because it's safer and I'm just wondering if anyone else here has gotten flashed by them and their experiences and HP #s. My engine mods are: uppipe, turboback (cat-less), BOV, colder plugs, FMIC, PE1820, 6500ccs, short ram intake. With the UTEC tuned by Nathan at TurboXS I made 308 WHP and 280 WTQ which I was very happy with. So what kind of numbers am I going to see?
EDIT: Also after I was tuned I installed an exedy flywheel, ACT clutch and STi RA gearset.
SpeedyWRX02 is offline   Reply With Quote
Old 08-04-2004, 12:23 AM   #2
SpeedyWRX02
Member#: 53623
WRX 318 WHP
PE1820
No one has been to RalliSpec??
Old 08-11-2004, 05:03 PM   #3
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.7 @ 102, '09 spec.B
Dave @ RalliSpec is a great guy with ALOT of experience. I am sure he will do you well.
As for the EcuTek reflash being safer... I don't really agree with that. ANY engine management in the wrong hands can kill a motor. Also, if tuned to the same degree, no engine management can CREATE more hp without more fuel and air. All things equal, all engine management will produce the same numbers. Like you said, its the tuner that makes the difference and what HE considers safe.
BTW- isn't 6500cc's quite abit of fuel? lol! Just pulling your chain...
def
dug-e-fresh is offline   Reply With Quote
Old 08-17-2004, 12:35 AM   #4
SpeedyWRX02
Member#: 53623
WRX 318 WHP
PE1820
Uhh, yeah they are... ummm.. "modified" PE650s I'm making THAT MUCH power that I need the 6500ccs
Getting the EcuTek on Wednesday from RalliSpec, I'm excited. The reason I went with the EcuTek is because I've stopped modding, have no need for the user tunability. Plus even on a custom tune by TurboXS in MD I'm getting bad partial throttle hesitations and random engine knocks all over the RPM range. With the EcuTek I believe it's safer because it still utilizes the stock ECU's lookup tables and uses the IAM for knock correction adjustment.
Old 08-18-2004, 09:21 AM   #5
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
You can't go wrong w/ either tuner. Did you get some lower octane gas to get the Utec knock events? The hesitations are a PITA, but I feel the multiple Utec maps to deal w/ weather, octane, valets, theft, etc. are invaluable.
Subahaulic is offline   Reply With Quote
Old 08-18-2004, 09:28 AM   #6
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
I am scheduled to get a Ecutek flash tomorrow at Rallispec. I have a UTEC but it was off my old EJ205 and was told it wouldn't work with my EJ207 swap. So I am getting a flash and after that I am probably going to put the UTEC on(was told Ver6b will work) with a C16 map for the WRX vs EVO meet @ E-town on 9-11.
2002WRXSTi is offline   Reply With Quote
Old 08-18-2004, 12:14 PM   #7
SpeedyWRX02
Member#: 53623
WRX 318 WHP
PE1820
All of my maps had that hesitation unfortunately and I didn't want to butcher maps that I paid good money for just to get it to run right
Also, I"ll probably be at RalliSpec tomorrow depending on if they are finished with my trans or not. If they are then tomorrow I'll be getting an EcuTek reflash also Maybe I'll see ya there!
why are there variances in exhaust hp #s? IgotWRXed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-14-2004 04:35 PM
RalliSpec in NJ? YonkerzImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-10-2003 05:45 AM
Rallispec in NJ? EJ22 Normally Aspirated with bolt-on Forced Induction Powertrain 4 07-12-2002 12:56 AM
Just returned from the Rallispec Meet in NJ paultg New England Impreza Club Forum -- NESIC 17 03-04-2002 01:59 PM
Northern NJ Caravan to RalliSpec. Pinochle Tri-State Area Forum 84 03-02-2002 10:32 AM
