Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-02-2004, 03:59 PM   #1
Aethyrial
Member#: 21247
1999 BG (Outback)
1989 GL 4WD Coupe
Default 89 GL rear drum brake info needed (adjustment cam)
Anyone have information reguarding the adjustment cam assembly (preload adjuster?) for the rear drum brakes on an 89 GL (such as purchase locations or part numbers).
Aethyrial is offline   Reply With Quote
Old 08-03-2004, 01:17 AM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Are you trying to buy new parts for your rear drums??
If so I suggest simply converting to rear disk brakes. A complete setup can be had for $50-60 + cost of turning rotors and replacing pads if you want.
Once you get rear disks you will never miss those drums
Flowmastered87GL is offline   Reply With Quote
Old 08-03-2004, 10:29 AM   #3
Aethyrial
Member#: 21247
1999 BG (Outback)
1989 GL 4WD Coupe
for that much...sounds better than fiddling with the small stuff. Where is the best place to look for the whole disc brake assembly to do the conversion? (from what I understand also, the parts are simply interchangeable?) Let me know.
Old 08-03-2004, 01:49 PM   #4
subaru__styles
Member#: 53144
94 turbo legacy
OEM-JDM
if you car is 2wd you will need disks off a 2wd, 4wd to 4wd.
just grab the whole backing plate/rotor/claiper assembly and you're set
subaru__styles is offline   Reply With Quote
Old 08-04-2004, 12:34 AM   #5
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
What styles said... get the parts off a Turbocharged GL / GL-10 / RX.
Get the brake line too.
WTB: 89 GL Rear Disc Brake Assembly (convert from drum) Aethyrial Private 'Wanted' Classifieds 1 08-03-2004 05:50 PM
Rear Drum brake to Disc Brake Conversion scoobyimprza Brakes, Steering & Suspension 7 03-23-2003 07:07 PM
Need Rear Drum Brake Shoes for 98OBS jersey judge Brakes, Steering & Suspension 0 06-17-2002 01:42 PM
about rear drum brake to rear disk brake SYMSWRX Brakes, Steering & Suspension 2 01-13-2001 03:13 PM
Rear drum brake to disc brake conversion eicbal18 Technical Forum Archive 5 08-16-2000 11:23 AM
Message Board Statistics All times are GMT -4. The time now is 06:54 AM.
