Old 08-02-2004, 08:14 PM   #1
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Default An idea for my intake
http://cgi.ebay.com/ebaymotors/ws/eB...category=33659
I was looking for 3 vacuum hose inlets. It looks like it could work.
NeaD is offline   Reply With Quote
Old 08-02-2004, 10:28 PM   #2
klug
Member#: 4133
'01 2.5RS Sedan
'05 LGT Wagon
If it's the right size, I suppose it could work.
If you're still MAF, I'd be tempted to stick with the stock air box and MAF mounting (with a snorkusectomy, of course) and custom piping with the correct amount of vacuum fittings, from the MAF to the turbo. That way you'll pull cold air from the fender and not run the risk of shaking the MAF into failure. I'm really no expert, but that would be my approach. Might even be cheaper, too...
klug
klug is offline   Reply With Quote
Old 08-02-2004, 11:00 PM   #3
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
The 98 MAF isn't nearly as touchy as the 99 MAF so using the stock box isn't necessary. It is always a good idea to anchore it down a little so its not bounchin all over the place tho. Let me know how that turns out if you do use it...I need to rework my intake also
Kyle
Andursun0013 is offline   Reply With Quote
Old 08-03-2004, 12:12 AM   #4
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Just get a bunch of chromed mandrel bends from JC whitney. It's what I used for my intake ('98 RS)
no-coast-punk is offline   Reply With Quote
Old 08-03-2004, 04:34 PM   #5
Andursun0013
Member#: 11616
1998 2.35RS-T
Well then what did you do with your vaccum lines, thats the reason he was looking at this piece.. . Catch can would work nice I guess
Old 08-03-2004, 06:29 PM   #6
NeaD
Member#: 43371
Hydra User, Blue
I went ahead and bought it.. It's only 40 bucks. I'll end up getting a better filter anyways.
Old 08-04-2004, 07:42 AM   #7
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Vacuum lines? The only place you get vaccum is from after the throttle body.
Those connections are for breather lines.
ChicksDigWagons is offline   Reply With Quote
Old 08-04-2004, 10:08 AM   #8
Unsung Boxer
Member#: 37196
Brad is right. I used a piece of mandral bent u-pipe, and some silicone couplers. For the breathers i drilled holes and welded in some tubular steel.
if ur not using MAF, your intake can be much shorter.
-Jake
Unsung Boxer is offline   Reply With Quote
One of my friends has had an idea for doing a book to raise money for Cancer Charity RS Grant Off-Topic 4 03-30-2010 01:48 AM
I'm an inappropriate uncle. I need gift ideas for my nephew. kbcr3 Off-Topic 59 12-03-2008 09:03 PM
Help me come up with an idea for my charity auction plate... JoD Off-Topic 9 10-31-2006 12:24 PM
An idea for my new gearset. BGPunk2001 Transmission (AT/MT) & Driveline 11 12-19-2005 11:01 AM
An Idea for Logging my new AP (using my old UTEC) TROLL Engine Management & Tuning 11 07-05-2005 05:05 PM
