Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 08-02-2004, 08:28 PM   #1
Brian204
Member#: 56528
1989 GL
white
Default wheel noise
I have a wheel noise in my right rear wheel, but when i jack up the wheel and spin it, it makes no noise and there is very little freeplay in it. Its not quite a grinding sound, but isn't a real smooth sound, either. Any diagnoses?
89 GL Dual Range 4WD
Brian204 is offline   Reply With Quote
Old 08-03-2004, 01:13 AM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Try tightening the axle nut.
Pull the cotter pin and then get a big ol socket (like 32MM or something... its huge) and make sure its tight.
That was the problem on one of my 88 GL wagons (225K)
Flowmastered87GL is offline   Reply With Quote
Old 08-03-2004, 10:31 AM   #3
Aethyrial
Member#: 21247
1999 BG (Outback)
1989 GL 4WD Coupe
You say there is very little freeplay...but is it possible it could be the wheel bearings?
Aethyrial is offline   Reply With Quote
Old 08-03-2004, 01:43 PM   #4
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Old-school Subaru wheel bearings aren't permanently sealed like the new ones, they need to be re-greased every 30k or so. Maybe that's all it needs...
DerFahrer is offline   Reply With Quote
Old 08-04-2004, 12:28 AM   #5
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
They do?? I think my rears are original! (293,900 miles!)
Fronts are new sealed units though.
Old 08-04-2004, 11:59 PM   #6
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
Not replaced, just repacked with grease...
At least that's what the oh-so-accurate Haynes manual says...
Old 08-05-2004, 12:30 AM   #7
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Either way I havn't touched mine ever. I'm not trying to say its right to ignore your bearings, but I feel that most GL owners do ignore their rears.
Old 08-06-2004, 01:28 PM   #8
bill123
Member#: 36088
1990 Loyale
Default Rear Bearings
Be careful about that rear axle nut. Overtorquing can lead to failure.
The spec and procedure on mine is: torque to 30 ft. lbs (about half the recommended torque for a lug nut), then back it off a quarter turn, then hand tight. So these nuts really aren't supposed to be torqued down solid.
bill123 is offline   Reply With Quote
Old 08-07-2004, 10:29 PM   #9
Brian204
Member#: 56528
1989 GL
white
Update: I removed the wheel via the castle nut, greased up the spindle and on the wheel where it meets it...tried to further tighten the castle nut, although it was already very tight. Now the wheel has been silent for two days.
However, i noticed where the spindle meets the assembly on the wheel, there is no machine finish...it looks like its been hammered. So there must be some sort of movement/hitting between the two.
Feeling the other wheels in comparison, there is just a tad more freeplay in the wheel than the others...its hard to detect...however, i did seem to take about half the freeplay out by the things mentioned. Perhaps the bearing is on its way out?
At least, for now, its silent.
Old 05-19-2007, 02:41 PM   #10
sepharad
Member#: 148739
Default wheel bearing tutorial?
Anyone Know of a wheel bearing tutorial for a GL? I am a total noob and think the grindy/rotational sound from my front end may be a wheel bearing.
I am big on pictures with short sentences.
Seph
sepharad is offline   Reply With Quote
Old 06-07-2007, 02:08 PM   #11
synik
Member#: 150565
The unmachined part could simply be rough cast metal where no machining was needed.
Make sure your wheel hube is not getting hot which would be an indication that the bearing is now too tight.
synik is offline   Reply With Quote
Old 06-16-2007, 06:42 PM   #12
bgd73
Member#: 125088
They are very sealed... in fact old school is my fav. I am still laughing once and awhile at the 3/4 ton pickup and subaru axle compared (I tore into a 89 gmc 3/4 ton and got a look around- the 87 subaru is bigger)
subaru oem grease is a tragedy- even that problem goes into the newer ones. I am still on 20 year old seals and driving through deep puddles. Regrease/pack with the best you can get recommended, there is lots of choices. My latest repacking was trailer wheel grease that was resistant to salt and corrosion (boat trailer- heavy duty).I forgot my valvoline synthetic. Once that is done, you may even notice more power and fuel savings if it was real badly packed. I am on my third old sube and at least half a dozen axle changes- none of them by subarus standard had anything worth a lick for grease. the original crappy grade wax looking stuff that dissipated in what must have been the old subes first hundred feet 20 years ago- and most are still running, hot as heck and bending hubs /rotors- eating axles but turning sealed.
That is my number one chore, aside from exhaust- the bad grease I know is lurking sometimes (most of the time). after repacking I went 60k on a 2wd bouncing the axle all over the place (somer may know what I mean with a 2wd) and it never needed an axle- I am certain it was the step away from subaru grease into better.
bgd73 is offline   Reply With Quote
Old 06-17-2007, 12:10 PM   #13
noisycricket
Member#: 148043
I would just like to point out that, for a 4WD model, this is incredibly wrong! The rear drums spline onto the axle similar to the fronts.
The torque spec is something outrageously high, like 200lb-ft or something. The 3 second IR234 method always worked for me, though
noisycricket is offline   Reply With Quote
Old 06-17-2007, 12:37 PM   #14
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
Tightening torque for 2wd rear axle nut is 36 ft-lbs.
4wd is 145ft-lbs.
FSM says that after tightening to specified torque(4wd) tighten further within 30deg to align holes on nut and spindle for cotter pin install.
TurboneX is offline   Reply With Quote
Old 06-23-2007, 09:36 AM   #15
faithless88
Member#: 152168
What about all 4 wheels sounding like their filled with rocks in the tread. I have checked the threads, pressure, going to balance this coming week. Anyone have an idea on what it could be?
faithless88 is offline   Reply With Quote
Rear Wheel Noise? Wheel Bearing? ezzzey Brakes, Steering & Suspension 6 04-20-2008 11:33 AM
Steering Wheel Noise GAMARRA Tire & Wheel 1 07-05-2005 12:38 PM
Steering wheel noise? wrxfanboy Newbies & FAQs 2 11-22-2003 12:19 PM
Rear wheel noise WRX 555 STi Brakes, Steering & Suspension 4 10-30-2003 03:45 PM
Group think remote diagnosis for wheel noise blaster88 Brakes, Steering & Suspension 3 10-13-2001 02:22 PM
