Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 05-30-2001, 04:02 PM   #1
christoph1371
Member#: 1090
Post Way too HOT...heat minimization
ok ,here is what i am looking for: Ways to alleviate the heat from my turbo all the way to the exhaust.
This Thing Gets WAyyyy to HOT.
suggestions?
and no dumb stuff danny or joe!
christoph1371 is offline   Reply With Quote
Old 05-30-2001, 08:59 PM   #2
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post
Dumb enough for ya?
Necromancer is offline   Reply With Quote
Old 05-30-2001, 09:03 PM   #3
bobski
Member#: 413
2006 VF-39 WRX Wagon
Post
Killer set up Joe. Is that activated by the windshield spray switch?
bobski is offline   Reply With Quote
Old 05-30-2001, 10:41 PM   #4
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Post
Yep, it's plumbed off the rear wiper motor. I need to get off my lazy butt and do the write-up. The real gains will be had when I can find the time to rig up an automatic controller for it. Anybody know how to program PIC's???
Old 05-30-2001, 11:05 PM   #5
kaminari
Member#: 1781
2000 2.5RS
Blue Ridge Pearl
Post
i think mrt sells some auto activation kit, but i'm guessing it'll be more expensive than coming up with something on your own.
kaminari is offline   Reply With Quote
Old 05-30-2001, 11:42 PM   #6
Philip
Member#: 1934
2002 WRX Sedan
Post
If you haven't read through it, I recommend these articles on water spray kits....
http://www.autospeed.com/A_0527/page1.html
Philip
Philip is offline   Reply With Quote
Old 05-31-2001, 09:08 AM   #7
christoph1371
Member#: 1090
Post
THANKS JOE. You are a real Pal. Anyway, I'd like to attempt this minor mod. Any chance of you holding a "Class" ooooo Yoda?
Old 06-01-2001, 09:38 AM   #8
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Talking
1. Digital + analog approach
How about getting one old pc, with say, an intel 8080 or 8085 ($50?), a simple digital i/o board ($150?), and a simple thermometer kit ($10). Get the voltage reading from the thermocouple of the thermometer, connect it to the digital i/o, and write some assembly code to do the simple switching, and generate the output to the i/o, and to the switch to the spray. ^_^
2. Analog approach
Or, maybe get the voltage reading from the thermocouple, pass it through some analog voltage divider with adjustable resistance, say, a potentiometer (so you can tweak the threshold of the temperature/voltage activated switch), and then to the collector of a simple transistor. The base and emitter of the transistor is connected to the switchin circuit for the spray.
With the potentiometer you can adjust the amount of voltage from the thermocouple that will activate the spray switch.
Ok, so I'm leaving out a lot of deatils, but if I didn't I could've just attempted this on my own subie ^_^
Just my 2 cents
Erwin
1995 Red Impreza L Coupe
2002 Yellow Impreza WRX Sedan
satrya is offline   Reply With Quote
Old 06-01-2001, 09:50 AM   #9
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Post
Erwin -- Yupyupyup, that was along the lines of what I was thinking as well. Like the article Philip posted says, I don't agree with using boost detection as an activator for the water spray. Ideally it should come on when the difference between I/C temp and ambient exceeds a certain value. Also the operation should be pulsed, not continuous. All of this is really a job for a microcontroller.
And since I've been meaning to learn how to program PIC's for quite some years now ... and since I'm presently unemployed ... I guess now is a good time to learn.
Anyway, Chris, if you want to rig up the manual version I can hook you up with the plumbing. You're going to have to figure out where to put a switch and stuff for it. I think you should be able to use any aftermarket windshield washer pump tied into the extra connector for the wagon. Then you need to figure out where the other end of that wire comes out (probably near the steering column). Give me a call and we can meet up...
Still too hot after heat wrap the DP weggy Newbies & FAQs 12 08-29-2007 07:14 PM
Oil Temp - how hot is too hot? wastintime Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-18-2006 12:20 PM
I;m way way , wAY!!! too drunk!# Stroke Off-Topic 10 01-01-2004 02:05 PM
how hot is too hot (computers) IggDawg Off-Topic 22 08-10-2003 01:34 PM
2002 WRX...too little....too late...for way too much $$$ WRX-1977 New England Impreza Club Forum -- NESIC 54 01-11-2001 12:44 AM
