Old 08-03-2004, 12:30 AM   #1
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Default gas flowing out of my downpipe
BTW.. im running open downpipe.
I just got done installig my injectors and the car won't start.. we looked under the car and there is a lot of gas on the floor. So.. i look at a sr20 injector and a stock injector.. and there is another small ring at the bottom of the stock injector that I didn't have on the sr20 injector. Could this be why I have gas flowing out of my downpipe.. or could it be somthing more?
I can post a pic if anyone is confused.
I need help ASAP.
NeaD is offline   Reply With Quote
Old 08-03-2004, 01:03 AM   #2
NeaD
Member#: 43371
Hydra User, Blue
It was the rings.. i just put them on. Now my motor is flooded.
Old 08-05-2004, 09:30 PM   #3
NeaD
Member#: 43371
Hydra User, Blue
Well.. I put new oil in it.. new spark plugs. tried to start it up with the sr20 injectors and gas was still flowing out of the downpipe.
So, I installed my stock injectors once again. Gas was still flowing out of the downpipe.
Old 08-05-2004, 10:44 PM   #4
NeaD
Member#: 43371
Hydra User, Blue
anyone?
Old 08-06-2004, 01:14 AM   #5
NeaD
Member#: 43371
Hydra User, Blue
BTW... i'm getting spark.
Old 08-06-2004, 02:01 PM   #6
NeaD
Member#: 43371
Hydra User, Blue
tttttttttttttttttttttttttttttttttt
Old 08-06-2004, 04:35 PM   #7
NeaD
Member#: 43371
Hydra User, Blue
humm. time to push the car into a lake?
Old 08-06-2004, 05:36 PM   #8
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
i'll push mine in with you...
thats a very odd situation... i dont understand why it would still do that after you put the stock injectors back in...
good luck..
I on the other hand keep blowing coils!
masiolli is offline   Reply With Quote
Old 08-06-2004, 08:38 PM   #9
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Go Hydra...
benjaminetanyahoo is offline   Reply With Quote
Old 08-06-2004, 08:40 PM   #10
NeaD
Member#: 43371
Hydra User, Blue
Originally Posted by FutureSTIer
Go Hydra...
I really don't think it's the hydra.
Old 08-06-2004, 09:09 PM   #11
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Go Injectors...
Go Coil Pack...
Go RS-T....
Old 08-06-2004, 09:12 PM   #12
NeaD
Member#: 43371
Hydra User, Blue
I never had an Coil Pack go bad on me as of yet.
Old 08-06-2004, 09:26 PM   #13
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Go AFI....
I'm just busting balls, good luck man, it sucks you are having so many problems
Old 08-06-2004, 11:39 PM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Check your wiring of the injectors... I'm assuming you had to splice in injector pigtails, which really should be straightforward, but if somehow something got crossed and they're firing all the time, they would just dump fuel into the cylinders, causing massive flooding, which would just come out the tailpipe (headers, downpipe, whatever it manages to leak from in the exhaust).
I would also check after a few seconds to see if the injectors are getting hot after the car is on a bit... this could indicate that they're shorted open all the time, too.
Last thing you could try is unplugging all the injectors and cranking it over a bit, then using some starting fluid sprayed into the throttle body to see if you can get her to turn over. Kind of a far-fetched idea, but it should work just fine, no worry if the MAF is bypassed, you don't need it metering air at that point.
Gas is just pouring out of my car ramoh Newbies & FAQs 25 08-04-2009 11:23 AM
I got a family of Gypsies evicted for siphoning the gas out of my RS brucelee Off-Topic 64 02-22-2008 11:17 PM
Gas leaking out of exhaust flp_sde Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 12-13-2005 04:15 AM
can oil actually flow out of the crank vents/block vent <ej257> White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 7 11-02-2004 03:25 PM
please hold of what is left of my brain while i bang the numbness out of my head sweetsuby Mid West Subaru Owners Club Forum -- MWSOC 23 09-18-2002 03:08 PM
