Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 08-03-2004, 12:21 PM   #1
The Modaholic
Member#: 35632
2004 WRX sedan
Red/ECUTek Stage IV
Default Installing the Escort ZR3 behind the glove box: Where is the easiest place....
So where can I find ground and juice without lighting up like Vegas?
Hey, there are a lot of wires here!
Holy ADHD, Batman!
So where behind the glove box can I find ground and juice for this thingy?
Thanks!
The Modaholic is offline   Reply With Quote
Old 08-03-2004, 12:52 PM   #2
grknss
Member#: 44592
2004 WRX STI
Platinum Silver Metallic
you can get power at the lighter, and there is a ground there as well.
there are places to modify brackets to hold that unit back there. your security system is back there (10mm bolt).
--John
grknss is offline   Reply With Quote
Old 08-03-2004, 05:20 PM   #3
The Modaholic
Member#: 35632
2004 WRX sedan
Red/ECUTek Stage IV
Thanks, guys.
Grknss--the 10mm, bolt you refer to is where?
If I am not soldering, then what type of connectors would you suggest I use for the power lead if I cut into the line going to the lighter socket?
Whit
Old 08-03-2004, 10:08 PM   #4
Hoffman
Member#: 64125
2007 WRX
Urban Grey Metallic
You can put them behind the glove box... wow... how well do they work there??
*edit* Ooops... i was confused with a different model....
Hoffman is offline   Reply With Quote
Where is the best place to get an Up Pipe installed in East TN? tblackgt350 South East Region Forum 8 01-05-2007 11:16 PM
To the local's who've done a gauge install: Where is the front oil gallery plug? Schleppy New England Impreza Club Forum -- NESIC 12 01-14-2006 08:33 PM
Just got the Escort ZR3 and Passport 8500. Your thoughts on the product. Chandy69 Tri-State Area Forum 13 05-09-2005 05:58 PM
[EGT,OIL]Where is the best place to install the sensors to my gauges in the engine? west Interior & Exterior Modification 2 05-06-2005 09:04 PM
Where is the best place to install hood pins? Vinnie Interior & Exterior Modification 9 08-08-2002 06:23 PM
